07-18-2018, 02:08 PM | #1 |
Rep 22
M2C Torque In Low-Rev
I have 2 questions:
1. From the specs, for M2C 'peak torque of 550 Nm is on tap between 2,350 and 5,200 rpm', while for M2 'maximum torque of 465Nm, plus 35 Nm with the aid of the Overboost function, between 1,350 and 4,500 rpm', does it mean the out-going lighter M2 has better low-rev power (better pickup) than the heavier M2C? 2. From the specs, M3 (which has the same S55 engine as M2C), 'Peak torque is available from 1800rpm through to 5700rpm', does that mean BMW purposely de-tune the S55 in M2C to have worse performance than the bigger brothers (M3 & M4)? |
07-18-2018, 02:34 PM | #2 |
4143
Rep 6,926
From BMWUSA site.
2018 M4: HORSEPOWER (hp @ rpm) 425 @ 5500-7300 TORQUE (lb-ft @ rpm) 406 @ 2350–5500 2018 M2: HORSEPOWER (hp @ rpm) 365 @ 6500 TORQUE (lb-ft @ rpm) 343 @ 1400–5560 |
07-18-2018, 03:00 PM | #3 | |
2865
Rep 3,842
http://www.automobile-catalog.com/cu...coupe_dct.html It shows that the M4 at 1400 rpm has 475Nm which I believe converts to 350 ft. lb. of torque. So it looks like the torque of the M4 at 1400rpm is still slightly more than the M2. |
07-18-2018, 08:08 PM | #5 |
21117
Rep 20,741
Drives: 2021 911 turbo
1. Better low rev pick-up? How much time are you spending below 2300RPM when wringing the car? Above that, the S55 M2 trumps the N55 M2 all the way to redline.
2. Yes. They simply detuned the S55 in the M2C to keep it below the M3/4. It's been confirmed that it is the same engine, so a simple OBD tune should easily remidy this.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 07-23-2018 at 06:08 AM.. |
dmboone254972.00 |
Tags |
peak torque |
