06 325i Sedan with 20's
06-23-2008, 10:34 AM | #1 |
Rep 171
This question may have been asked but can I put staggered 20's on my car without rolling the fenders? I have been calling rim shops and tirerack and they tell me no but I called Discount tires and they said you can with no problems. I am just trying to find someone with the set up to let me know whats true.
06-23-2008, 11:08 AM | #2 | |
12
Rep 552
Delivered: 10/21/08 | 09 e92 335i|AW|CR|PP|SP|NAV|PDC|CA|6MT|iPod|Logic7
Sold: 06 330i/Mystic Blue|Terra|PP|SP|NAV|CA|6MT|Butt Warmers|Rear Shades|Fold Down Seats |
06-23-2008, 11:11 AM | #3 |
Powered By 36DD
337
Rep 7,369
^ it's all about the offset
staggered 20s.........
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
06-23-2008, 11:38 AM | #5 |
12
Rep 552
depends on how aggressive you want to rears to stick out. On a 10in wide wheel, u could probably get away with offsets as low as et30~ et32 (maybe a little more) without rubbing or fender mods.
06-23-2008, 11:38 AM | #6 | |
Powered By 36DD
337
Rep 7,369
my 20x10 has 38......i'm getting 10 mm spacers
06-23-2008, 11:41 AM | #7 |
Україна
24
Rep 868
sorry couldnt help it
IN THE PASSING LANE - e90 330 JetBlack / 6000k D1S / 40% all around / LED Lic.Plt. / LED reverse lights / 7500k Fogs
06-23-2008, 03:13 PM | #10 |
1569
Rep 29,202
Most of the guys running 20s has that size.
06-23-2008, 04:54 PM | #11 |
Rep 171
i am trying to go with the Avarus AV5 wheel in a 20 inch staggered set but tire rack is telling me i cant do it even though it says it can fit i do not know the offset of the wheels.
06-23-2008, 06:20 PM | #12 | |
12
Rep 552
this web site shows the offsets for 5x120 bolt pattern. looks like they only come in +40 or +45 offsets for 10in wide. it can still work, but you will need to run 10mm spacers to acheive the net +30 or +35 offset.
06-23-2008, 06:45 PM | #13 | |
Rep 171
06-23-2008, 07:10 PM | #14 |
12
Rep 552
shouldn't, you will still have the net +30 or +35 offset if you use the 10mm spacers on a +40 or +45 wheel.
if you really like these wheels and are worried about rubbing, then you should do the +40. mount them first to see how they look. if its not aggressive enough add either 5mm or 10mm spacers later. 10mm ~ 0.4 inches , so you should be able to determine how much clearance you have after the wheels are mounted. just remember adding spacers will push the wheels out towards the fenders and will lower your offsets accordingly.
06-23-2008, 07:32 PM | #15 |
Rep 171
sweet thanks for everything this is my first bmw and just trying to do it right and also i found some oer rims on that site and they had some very good prices
06-24-2008, 12:57 AM | #16 |
Powered By 36DD
337
Rep 7,369
my set is +38 offset........
I tried 5 mm spacers in the rear......now 10 mm spacers are on order.... then i'm moving the 5 mm spacers to the front......... go with the +40 offset..........and if you're not lowered....there should be no rubbing at all if lowered....the front might rubbed a little when you turned hard into corner dip or driveway......
06-24-2008, 05:52 AM | #17 | |
Rep 171
06-24-2008, 10:28 AM | #18 | |
Powered By 36DD
337
Rep 7,369
I did have H&R race.....but the front was rubbing too much on every turn and corner....... if you don't drop it........your ride will look like a SUV
06-24-2008, 11:16 AM | #19 |
Rep 171
good one i am not trying to get that high.. where can i find those at for a good price
06-24-2008, 11:28 AM | #20 | |
Powered By 36DD
337
Rep 7,369
i got my H&R + installation for $350
06-24-2008, 11:37 AM | #21 |
Rep 171
06-24-2008, 10:38 PM | #22 |
12
Rep 552
i have a set of h&r sport for sale. koni fsd shocks too. PM me if interested
