The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > The N51 Struggle :(
      07-17-2018, 05:17 PM   #1
R.Thillman
14
Drives: 2007 e92 328i
The N51 Struggle :(
I had installed aa headers a couple months go onto my n51 with 3SIM with no tune. it ran really good and would purr at around 6k. For about four months it ran perfect and now i have been getting multiple codes and don't know where to start. I have 5 codes that usually are there because of the headers that are lambda/cat/SAP such as 2c3d, 2ca6, 29f5, 29f4, 2a00
The ones im worried about is 2a99/2A98/ 2a87/2a43 crankshaft correlation they all appeared at different times after clearing them i was trying to see if i needed a cam sensor or solenoids; 2a16 DMTL fine leak. I had those for about 2 weeks and it would give me a slight stumble momentary after start up and run fine after and then just yesterday i got these codes 2ad8 EAC sensor, 2aab variable disa.
Still runs good after the stumble on start up but now its time to wrench. I have cleaned the solenoids prior already but didn't swap them. Guessing i need a couple solenoids maybe some sensors and a disa valve forsure. Going to try and test the vanos on INPA tomorrow. where would you guys start thanks in advance?
      07-17-2018, 06:02 PM   #2
Eagle1oh7
Eagle1oh7's Avatar
Drives: '11 328i Sedan
Did you get a tune?
DONE: Seibon CF Hood, M3 Rep, MSport rear w/DD CF Diffuser, M3 Rep Skirts, Seibon CSL trunklid, Forgestar F14 18s w/Michelin PSS, Eisenmann catback, AA Headers, BPC Stage 2, Charcoal Delete+revMotor+AFE Drop In filter
FUTURE MODS: LED headlights, CF rooftop, M3 Suspension Conversion, Dinan CAI Mod
      07-17-2018, 09:03 PM   #3
R.Thillman
14
Originally Posted by Eagle1oh7 View Post
Did you get a tune?
no not yet, i need to maintenance her first although it could solve problems
      07-17-2018, 10:49 PM   #4
Eagle1oh7
Eagle1oh7's Avatar
You will continue to get codes for your cats until you get a tune. That's the only reason why you're getting these codes and a CEL.
      07-17-2018, 11:47 PM   #5
R.Thillman
14
Thanks but I know that I'm not worried about those. I said above I'm just worried about the vanos/ cam sensor codes causing a stumble momentary after start up and disa.
      07-18-2018, 05:36 AM   #6
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
Clean the sensor or replace
Appreciate 2
Noir883.00
      07-21-2018, 12:09 PM   #7
hassmaschine
Drives: "NBO" 330i
Did you email me for help? Because your email address was wrong so I couldn't respond.
      07-23-2018, 03:03 PM   #8
R.Thillman
14
Hey yes i did sorry you can email me here Ryanthillman97@gmail.com thanks in advance! Going to add a project on bimmer labs today as well.
