BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    My brakes squeak.... normal?
      07-14-2018, 12:17 AM   #1
MF Larry
176
Drives: 2018 M5 DONNY GREY
Question My brakes squeak.... normal?
my front brakes squeak pretty loud sometimes when I come to a slow stop, almost embarrassing.. is this normal like the dealer says it is?
      07-14-2018, 12:30 AM   #2
shellbmb
shellbmb's Avatar
Drives: 2022 F90 M5C
Ughh... This is what plagued me with my F10 and I was hoping it was fixed in the F90. There are some other threads on it already. You might check in there. It seems some are affected while others aren't.
      07-14-2018, 12:41 AM   #3
MF Larry
176
my f10 never did it, this is embarrassing, $115k car with loud brakes. dealer said its 'normal"
      07-14-2018, 01:46 AM   #4
Ex_Stig
Ex_Stig's Avatar
2594
Drives: '24 X7 M60i
2024 BMW X7 M60  [10.00]
High performance brakes make noise. That's just how it is.
Think of it this way, the ones who have M5s that don't make noise are the odd ones.
Ex Stig
'25 M5 Touring (on the list, first slot)
'24 X7 M60i
'22 M5 CS - (sold)
flanast148.50
      07-14-2018, 02:26 AM   #5
Phatcat
751
Drives: BMW M5, X5M
Not sure that's true, brakes on my M5, M6, and X5M don't make noises. And my friend's M5 doesn't make noises either.
However, it does happen (to all brands and makes) and there is no easy way to fix it.
      07-14-2018, 02:32 AM   #6
Alberta
Alberta's Avatar
2034
Drives: F90
Have you got carbon ceramic brakes ?
I do , and they don't squeak.
Or very rarely and hardly noticeable.
On my X5M , the "standard' brakes where squeaking like a school bus
      07-14-2018, 07:09 AM   #7
Bimmer6
Bimmer6's Avatar
632
Drives: 458SPY, GT3RS on the way
Depends how you drive the car .....high performance brakes work well when heated up. If you have a safe area take the car up 60 or so and slam on the brakes really hard several times. All my Porsche’s did the same and my old F10 ....did the above gone. See below
Brake pad bedding is an important process that removes impurities from the surface of the brake pad and lays down a thin layer of pad residue on the rotor surface. This is accomplished through repeated heated and cooling during braking. These cycles are like Goldilocks and the three bears: temperatures need to be just right to prevent scarring of the brake pad and rotor surfaces, or uneven pad transfer. Follow these easy guidelines and enjoy quiet, smooth and long-lasting braking. While every manufacturer has a different method for bedding in their brake pads, the basics remain the same—regardless of brand.
Find an open stretch of road that will allow you to safely stop your vehicle multiple times
Accelerate to 35 mph and apply moderate brake pressure to reduce your speed to 5-10 MPH
Repeat this process 3-4 times, the goal is to warm up your brake pads
Now turn up the heat even more by increasing your speed to 45 mph and braking down to 10 mph
Pro Tip: It’s important to avoid coming to a complete stop during this stage as it’s possible to melt brake pads against hot rotors. Of course, should a deer, pedestrian or Sasquatch run onto the road, feel free to mash the brake pedal. Safety first!
Your stop-and-go session is now complete. Park the car and allow the brakes to fully cool for an hour. For best results, avoid pressing down on the brake pedal when parked
While bedding in your brakes can sound like a sensitive procedure, one funky stop isn’t going to ruin your efforts. Gas-off and heat will occurr. Drive safely and avoid emergency stops, if possible.
      07-14-2018, 08:52 AM   #8
neohh
168
Drives: F90 M5
Same here, my brake starts squealing after warming up. No squeal when cool...weird. Going to ask my dealer to see if they can put some anti-squeal paste on it when I go in for service.
BMWM5NYC496.00
      07-14-2018, 09:15 AM   #9
MF Larry
176
thanks for all of that
      03-13-2019, 05:43 PM   #10
mdeaneca
Drives: 2018 M5
Angry 2018 M5 Brake Squeal
I have just been informed by my BMW Dealership that there is nothing they can do to fix the squealing brakes on my new M5. Absolutely incredible. A $120k car that sounds like a clunker whenever you stop....
Yes, I have tried the braking hard at speed. Temporary fix.
They told me at the dealership that it's because it's an "M". This is my fourth (and maybe last) M5.....none of the others squealed. I'm wondering if I can declare it a Lemon?
      03-13-2019, 06:09 PM   #11
Pimpsy
420
Drives: 2019 M5C
My brakes have been squeaking lately and I haven't had time to really try to bed them better. The noise actually bothers me a lot less than I thought it would, probably because the insulation is so good.
Retired 2016 BMW 550i xDrive MSport | 2013 BMW 550i xDrive MSport | 2012 BMW 535i xDrive | 1988 BMW 325ic | 1984 BMW 318i
      03-15-2019, 08:50 PM   #12
Neptune7
1433
Drives: M5 CS
Am I correct that this is only for those with steels? That folks with CCBs have zero squeaking?
      03-16-2019, 09:21 AM   #13
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
Aftermarket pads are really the best solution to both dust and noise; went this route on both my F10 M5's and recently did the same on my F90 M5C. Dust and noise is gone.
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
Neptune71432.50
      03-16-2019, 12:20 PM   #14
BURAKUSTA
Turkey
126
Drives: 2011 E92 M3 COUPE
Which pads are you using ?
      03-16-2019, 06:04 PM   #15
josec70
josec70's Avatar
ACG Automotive ... see other thread in this section.
      03-22-2019, 10:27 AM   #16
JOHNBMWM5
Live for today tomorrow never comes
JOHNBMWM5's Avatar
United Kingdom
1989
Drives: 2022 LCI Marina Bay Blue/ Smok
My last 6 M cars must be all odd one's including this M5 CP, I must be odd.
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather
      03-24-2019, 09:36 AM   #17
Rjduff
Rjduff's Avatar
Drives: 2018 M5
I know you have only had these pads for a couple of weeks but I am interested to see if you are seeing any rotor wear. Pads are cheap, rotors not so much.
      03-24-2019, 03:03 PM   #18
josec70
josec70's Avatar
None .... I've gone with aftermarket pads on all of the M5's I've owned (5) with no issues. I've not detected anything on this set and another owner has already done 1500+ miles w/ zero issues.
      03-31-2019, 01:01 PM   #19
leggitt
Drives: 2013 F10 Silverstone
My 2013 M5 squeaked. My current 2015 M5 has carbon/ceramic and they squeak. Interesting during the recent cold and rains in SoCal they did not squeak. Yesterday with the desert winds and 80 temps they have begun squeaking again. Must be temp related. I don’t drive hard but freeways are all stop-and-go.
Has anyone tried aftermarket pads with the carbon/ceramic brakes?
      03-31-2019, 08:01 PM   #20
shawnhayes
1830
Drives: 22M5 CS,23X5E,24M3 CS,24 i4
The better brakes brake at high temp and high speed the more likely they are to squeal. Some won't versus others with similar pads or rotors, but these brakes are fairly good at high speeds.
Shawn
      11-08-2019, 07:10 PM   #21
KennyM340ISouthFLA.
Drives: X4MC
Same issue. I’m geting very annoyed. I just picked up a 2019 M5 comp. car has 170 miles in it. The squeak when I come to a traffic light or complete stop. I went to dealer and he took the car out with me and we did like 40 and slammed on the breaks like 4 times as stated above. It stopped it for a few hours. But then the noise started back up. Very annoyed
      11-08-2019, 08:27 PM   #22
josec70
josec70's Avatar
I swapped out the OEM's for aftermarket really because of the dust but they're also very quiet. ACG Automotive in SD or Porterfield website.
I did this on both my F10 M5's with good results.
