BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - Rockies / Midwest > 328xi 2007 Body work and painting
      07-08-2018, 12:52 PM   #1
saijin
25
Drives: BMW 328xi 2007
Hey guys,
so the back side of the skirt of my car got bent bad.
I was wondering if you guys know an independent contractor that can help me without taking an arm and leg?
      07-09-2018, 12:09 AM   #2
tlow98
2188
Drives: 2009 E91, 2014 F15 x35i
You could try to pull it yourself with trains, hook and a come-all. I would only worry about the point that attaches to the skirt if you’re trying to do it on the mega cheap.
Also, regarding your valve cover gasket - if you’ve tried more than once on that fix with the same gasket then you’re wasting your time. Buy a new one, read several different tutorials and give it a real go.
      07-09-2018, 04:34 AM   #3
saijin
25
Where can I get those things you mentioned to pull?
the gasket is actually new. Got it from advanced auto. I'm more concerned about the plastic engine cover. Was wondering if I should just try to tighten the bolts.
      07-12-2018, 01:18 PM   #4
tlow98
2188
Hardware store. All you really want to do is pull the sheet metal where the attachments points are out to where they used to be.
On the gasket - it's not new if it's currently on your car and leaking. it's now used.
You can try to tighten the bolts, but this will only work if they were improperly tightened the first time around. Also, they snap easily, so there's that.
      07-13-2018, 02:13 AM   #5
saijin
25
I'll just replace all the gaskets.
Do you recommend an after market made in Germany Valve cover like from URO?
The BMW valve cover will run me $500+
