07-01-2018, 07:48 PM | #1 |
BimmerPost Supporting Vendor
1999
Rep 6,916
Introducing an exciting super easy way to seal your car - Sonax Spray and Seal
We are excited to tell you that we have tested out Sonax Spray and Seal and we are loving it. We have found Spray and Seal to be a great product to add to your routine maintenance. We have used gallons of the product in our rigorous testing and this has proven to be an easy to use product with great gloss and durability of up to 3 months. The water beading behavior is much like Sonax Polymer Net Shield, which we believe to be one of the best beading products in the industry. Spray and Seal has a a great just waxed feel to it, missing in the Polymer Net Shield and Brilliant Shine Detailer. Spray and Seal can be used to boost your coated, sealed, or waxed vehicles. This can also be used as a stand alone product as well. We recommend everyone to give this one a go. What Sonax says: SONAX Spray and Seal - Instant Shine Coating is a great compliment to any car enthusiasts' product arsenal. The easy-to-use formulation incorporates a unique Hybrid Polymer Technology that provides up to 3 months protection and generates excellent hydrophobic properties. After the car is washed and while it is still wet, simply spray entire car with the product and rinse. Completely dry all areas affected with a clean microfiber towel. Direction for use: - Wash vehicle and rinse thoroughly - Shake bottle before use and turn the nozzle to open. - Evenly spray the sealant on the wet vehicle (approx 4-6 sprays per 4 ft section). - Rinse immediately with plenty of clean water and dry the vehicle. - Dry the vehicle - Remove any leftover remnants with a microfiber towel. Product Attributes: - Spray on, rinse off - and it's sealed! - Quick and easy during the car wash - Enhances the color depth and provides a mirror like shine - Impressive water and dirt repellent effect in no time at all - works on cars with out any protection - works on cars with sealant and waxes - works on cars with ceramic coating - works on cars with paint protection film Please Note: Do not use on hot surfaces. Do not apply in direct sunlight. Do not allow to dry. Always give special attention to the seams of the vehicle while rinsing product thoroughly. Order some up - Sonax Spray and Seal |
07-01-2018, 08:19 PM | #2 | |
724
Rep 929
Drives: 2019 F87 M2C, 2023 G87 M2
07-07-2018, 07:41 AM | #6 |
1999
Rep 6,916
07-07-2018, 07:44 AM | #8 |
1999
Rep 6,916
sure you can use them as a winter set that would be absolute baller!!!
BS FI-R's Specs: Platinum Gloss Size: 19 x 9.5Wt (lbs): 16.5CB: 72.5HW Kit: OE BoltsET: 22 Size: 19 x 10.5Wt (lbs): 17.5CB: 72.5HW Kit: OE BoltsET: 35 |
07-09-2018, 05:50 PM | #9 |
10933
Rep 4,551
Drives: 2015 328d xDrive
07-19-2018, 09:01 AM | #10 |
171
Rep 294
Just tried this for the first time and not a huge fan. Couple things I liked, couple I did not.
Cons: -Maybe I used too much, although I followed the instructions and applied as they DD in their video. I've used about 40% of it in 1 use. -I rinsed the car over and made sure I hit everything and the rear windshield has a haze on it that a ton of elbow grease and even some Nanolex window cleaner could not remove. Additionally my rear quarter window has some as well. This may be user error and if so I understand, that just means the "ease of use" is not as easy. I guess it's easy to miss rinsing some spots. - Slick feel? Good, not great. No comparison to Car Gliss. Pros: - Water beading. Holy Sh.. this water beading is great. I was using Car Gliss and that stuff is great. This is amazing though. - Ease of application. Just spray on, no buffing. (maybe) - Shine and deep color look? Yes! Would I buy it again? No, I'll try Hidrosilex or something else. |
07-19-2018, 09:53 AM | #11 | |
1999
Rep 6,916
Great review. on the cons - did you do this yesterday in the sunlight, if not that would be the issue. did you dry the car completely or did it already dry on the car before you can get to it? I would not compare this to Car Gliss it's a bit of a different product. |
07-19-2018, 12:06 PM | #12 | |
171
Rep 294
Did this yesterday in mostly sunny weather. Once rinsed I immediately blew off excess water with a leaf blower then hit the whole car with microfiber towels from you. Perhaps it was the sun that dried it out just too quickly. |
07-19-2018, 12:30 PM | #13 | |
1999
Rep 6,916
also I know for fact we can get 4-5 M2's out of it, ask me how I know ; ) |
jessetaylor1171.00 |
07-19-2018, 12:38 PM | #14 | |
171
Rep 294
07-30-2018, 06:22 AM | #16 |
1999
Rep 6,916
Update:
Sonax Spray and Seal being used to maintain a ceramic coated vehicle. Using Sonax Spray and Seal for maintenance on a coated Lamborghini Huracan This Lamborghini Huracan was coated about 6 months ago with a ceramic coating, we wanted to test out the ability of the Sonax Spray and Seal and the effects of it over the coating. We are happy to report that it worked extremely well. Sonax Spray and Seal was compatible and showed no issues or side effects with the ceramic coating. We would recommend it as a maintenance product over your cars protected with ceramic coating. |
04-24-2020, 09:22 AM | #17 |
164
Rep 249
04-27-2020, 02:53 PM | #20 |
164
Rep 249
Tags |
bmw m2, sonax spray seal, spray and seal |
