2Addicts
2Addicts
2Addicts | BMW 2-Series forum Classifieds Commercial Classifieds Wheels and Tires Burger Tuning (BMS) Spacers - $99 SHIPPED!
      06-21-2018, 01:30 AM   #1
Sales@wheelsdc.com
Sales@wheelsdc.com's Avatar
Drives: BMW
Order Link
https://wheelsdistributioncenter.com/bms-wheels-spacers-sold-by-pair/
Burger Motorsports wheel spacers are an excellent, cost effective way to improve handling while dramatically enhancing the look of your BMW. Our wheel spacers push your rims and tires outward for an instant "fat" aggressive look, better lateral stability, and handling. Spacers are also great for filling in the wheel well, creating clearance for aftermarket suspension, different wheel offsets, big brakes,' making your winter tires not look so inset or just making your BMW look awesome. BMS spacers are specifically designed and manufactured by Burger Motorsports for your BMW ensuring a perfect vibration free fit. Comes with a packet of anti-size grease to place on the factory hub to aid in later removal.
Build & Quality: Each Burger Motorsports wheel spacer is CNC machined from high grade 7075-T6 aluminum alloy and anodized black for protection. Our BMW Wheel Spacers are sold in pairs (2pcs) with 10 extended lug bolts which exceed OEM standards. To do the whole car you will need 2 spacer kits. They are hub-centric and all sizes including 10mm have the factory hub on them. They are safe to use on iX (all wheel drive) BMW vehicles.
Hub-Centric: Means our spacers center bore matches your factory BMW hub and the factory-like hub on the Burger Motorsports spacers matches the center bore in your wheel for a vibration free fit.
What width wheel spacer should I get?
Spacer sizes are a matter of personal taste so only you will know what size you will like. Use a ruler to measure out from the top of the wheel/rim arch and see exactly where you want the wheel/rim to stick out to and order the appropriate size. What you see on the ruler, 10mm, 12mm out, etc. will be exactly where the rim will sit with the spacer size you choose. Burger Motorsports wheel spacers are only available in 10mm, 12mm, 15mm, 18mm, 20mm thickness. X5/X6 spacers only available in 15mm.
BMS Wheel Spacers for BMW
  • Provide Better Handling by Widening the Wheelbase
  • Provide A Wider More Aggressive Look and Stance
  • Specifically Designed for your BMW
  • Guaranteed for the Life of your Vehicle
  • 10 Super Strong 10.9 Grade Extended Wheel Bolts Included
  • Light Weight Anodized Black 7075-T6 Aluminum
  • Special Pry Tabs on the Back for Easy Removal
  • 1-Piece Spacer with Hub-centric Factory Lip
  • Strong Solid Design & Appearance
  • Available in 10mm, 12mm, 15mm, 18mm, 20mm widths
  • F chassis X5 X6 X5M X6M - 15mm is the only size we make
      06-26-2018, 11:06 AM   #2
Sales@wheelsdc.com
Drives: BMW
bump
      06-28-2018, 11:08 AM   #3
Sales@wheelsdc.com
Drives: BMW
bump
      07-03-2018, 06:13 PM   #4
Sales@wheelsdc.com
Drives: BMW
bump
      07-09-2018, 11:16 AM   #5
Sales@wheelsdc.com
Drives: BMW
bump
      07-11-2018, 11:12 AM   #6
Sales@wheelsdc.com
Drives: BMW
bump
      07-16-2018, 11:14 AM   #7
Sales@wheelsdc.com
Drives: BMW
bump
      07-19-2018, 11:12 AM   #8
Sales@wheelsdc.com
Drives: BMW
bump
      07-23-2018, 06:35 PM   #9
Sales@wheelsdc.com
Drives: BMW
bump
      07-25-2018, 04:55 PM   #10
Sales@wheelsdc.com
Drives: BMW
bump
      07-30-2018, 06:16 PM   #11
Sales@wheelsdc.com
Drives: BMW
bump
      08-02-2018, 06:24 PM   #12
Sales@wheelsdc.com
Drives: BMW
bump
      08-07-2018, 06:36 PM   #13
Sales@wheelsdc.com
Drives: BMW
bump
      08-13-2018, 11:54 AM   #14
Sales@wheelsdc.com
Drives: BMW
bump
      08-17-2018, 11:08 AM   #15
Sales@wheelsdc.com
Drives: BMW
bump!
      08-21-2018, 11:14 AM   #16
Sales@wheelsdc.com
Drives: BMW
bump!
      08-23-2018, 06:28 PM   #17
Sales@wheelsdc.com
Drives: BMW
bump
      08-29-2018, 06:29 PM   #18
Sales@wheelsdc.com
Drives: BMW
bump!
      09-07-2018, 11:12 AM   #19
Sales@wheelsdc.com
Drives: BMW
bump!
      09-12-2018, 11:58 AM   #20
Sales@wheelsdc.com
Drives: BMW
bump!
      09-17-2018, 11:12 AM   #21
Sales@wheelsdc.com
Drives: BMW
bump!
      09-20-2018, 11:14 AM   #22
Sales@wheelsdc.com
Drives: BMW
bump!
2addicts
