2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Windshield Washer Pump
      06-20-2018, 05:19 PM   #1
123Britt
Drives: 15 M235i AT
Pump went out today at 47k miles. Thinking of just replacing it myself being that my typical dealership scenario will be:
Day 1: Trouble shooting & conclusion that the pump has a short to ground
error code.
Phone call from BMW Service ~ need 1 day to order new part
Day 2: Part Arrives at Dealership
Day 3: Part is installed and phone call from dealership late in the day that
car is ready for pick-up around 5pm (rush hour traffic)
50/50 that I get a Loaner --------So - I will just fix it myself ($40.00 VDO Part) as I did on the 335i however that failed around 80k.
      06-20-2018, 05:52 PM   #2
TMatt
Drives: 2016 EB M235i
I'm at 40k miles and my washer fluid system has malfunctioned twice now. I actually just got it back from the dealership yesterday after the second malfunction. Both times they had to replace the entire system including the reservoir because I guess it is all one piece.
      06-20-2018, 06:07 PM   #3
123Britt
Drives: 15 M235i AT
Diagram per REALOEM
http://www.realoem.com/bmw/enUS/show...96#67127302589
#5
      06-30-2018, 02:56 PM   #4
123Britt
Drives: 15 M235i AT
Photo Of Bmw Vs Vdo Pump
Notice the BMW Pump has <POM> stenciled on the pump body.
I think it stands for Piece of Manure.
BMW $60.00 VDO/Conti $17.00 or less if shop around.
Took me 2 hours this morning.
Better than covered under warranty but a 3 day turn around.
      07-03-2018, 08:20 AM   #5
Maynard
Drives: 228iX & M2C
Our local dealership was very active in warning about using certain wash mixes that have silicone (I think it was silicone, or some other additive - I remember that Rain-X was the main brand to avoid). They said it would kill the seals in the pump, and they had already replaced several units (well before the 40k mile point). IIRC, this was under warranty, or sounded like they were footing the bill. I'm guessing that was their motivation to warn us - that from then on they weren't on the hook as we had been warned. Can't hurt for those who don't want to go DIY to try for a covered repair.
Appreciate 2
123Britt287.00
      11-25-2018, 09:53 AM   #6
Unicorn123
Drives: 2016 M235i xDrive
Maynard,
Interesting... I had three Audi's fail for washer fluid level devices due to Rain-X fluid use, but never a pump. The conductivity portion of the sensor would eventually not function due to the chemical properties of the washer fluid.
I love Rain-X fluid and it is all I use, since I typically do not use my wipers... Guess I will need to be prepared for a potential failure. Thank you for the info!
Current Fleet, 16 F22 M235i xDrive, 15 Audi Q5 3.0 TDI (my Wife's), 07 E85 Z4M Roadster, 01 Toyota Tundra 2wd Long Bed
Retired (a few of them...), 08 E60 550i 6M, 01 Audi S4, 70 Fiat 124, 88 E28 M5, 72 Datsun 510 2Dr, 73 TR6
Maynard3830.00
      07-19-2020, 12:18 PM   #7
BigT-65
Drives: 2015 BMW 228i
Is replacing washer pump in a 2 series the same procedure as replacing in a 3 series. There are videos on youtube showing 3 series replacement but I could not find one for a 2 series.
      07-19-2020, 05:23 PM   #8
John in VA
983
Drives: 2015 228i M Sport
It's hidden behind the passenger's wheel well liner like in the 3-series. Check the online repair catalog. Good luck! https://www.newtis.info/tisv2/a/en/
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining
      08-05-2020, 01:19 PM   #9
BigT-65
I got the wheel well panel out and removed the washer tank screw. I see in the manual that I need to pull the tank up and forward to release it from the guides but I can't get it to come out. There's not much to get hold of or get any leverage on it. Anyone have any suggestions for getting the tank to come loose.
      08-05-2020, 08:34 PM   #10
BigT-65
OK, I got it out and replaced the pump. Then the power went out and I had to give it up for the day. Now I hope I can remember how to put it all back together.
123Britt287.00
      09-30-2022, 08:28 PM   #11
carjoy
carjoy's Avatar
Drives: 2016 BMW 228i M-Sport
2016 BMW  [0.00]
Wiper fluid washer stopped today working on my 2016 228i. Can it be a bad fuse? If so, where is it in car, front or back and which number. I have an extended warranty which I purchased when I bought the CPO vehicle. Is this issue generally covered?
Live your best life.
      02-08-2023, 02:45 PM   #12
imolared06
Drives: BMW 230i
My question on my 2018 230i vert is that the reservoir apparently went dry and after topping up the fluid it will only spurt a few drops with each pull. Technically it still works, just not as efficiently as before. The pump still makes noise, so I know it is not dead. Is it possible that it has lost its "prime" or has a clog? Only 31k on clock, but sadly no warranty. Ideas will be appreciated. Thanks.
      02-08-2023, 03:16 PM   #13
aerobod
Car Geek
aerobod's Avatar
3605
Drives: Caterham R500, M2-G87, Macan S
Most likely a clog, especially if windshield washer fluid with additives in it for such things as water beading (such as RainX) have been used.
      02-09-2023, 07:56 AM   #14
MarcoZandrini
Drives: 2018 M240i
The F22 need a special windshield washer fluid from BMW as the underhood temps are too high for the stuff at the grocery story/parts store.
      02-09-2023, 09:54 AM   #15
WolfGTI
WolfGTI's Avatar
Drives: '17 F22,15 E84 M Sport,02 R53
2017 BMW M240i  [0.00]
2002 MINI Cooper S  [0.00]
2015 BMW X1  [0.00]
Where did you get this from? I use generic washer fluid and have had zero issues for the last 6 years and 80,000 miles.
Integrated Engineering engine mounts, Dinan CAI, AA catted DP, Remus resonated cat back.
Rogue Engineering SSK & transmission mounts, WaveTrac LSD.
Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r).
aerobod3604.50
      02-10-2023, 08:23 AM   #16
MarcoZandrini
Drives: 2018 M240i
I think it's in the owner's manual.
      02-10-2023, 09:34 PM   #17
WolfGTI
WolfGTI's Avatar
2015 BMW X1  [0.00]
Interesting.
      02-11-2023, 06:45 AM   #18
cooolone2
cooolone2's Avatar
624
Drives: 20' M240iX B58, 01' 330XI E46
I find it hysterical that a dealer would warn about using silicone fluids that would cause seal issues? Or even sensors for that matter. I call BS because I use and have used RainX since it came out and the only vehicles injad issues on the pump or any part of the washer system were on vehicles that were KNOWN to have issues with them, regardless of actual washer fluid used.
Just saying...
      02-11-2023, 07:37 PM   #19
aerobod
Car Geek
aerobod's Avatar
3605
Just saying...
There have been a number of lawsuits relating to the damaged caused by deposits from the additives in Rain-X, such as this: https://laws.tips/rain-x-wiper-fluid-lawsuit/
      10-01-2023, 11:51 AM   #20
TrboMike
142
Drives: BMW M240ix
First, here is the location of your two fuse boxes:
https://www.youtube.com/watch?app=desktop&v=kZsuPbYj8D0
Second, I recall reading somewhere there is no fuse for the washer motor, its fed by the FEM module (which has its own fuse). That might be why the "fuse location" paper you found shows a car on a lift instead of a fuse number.
If that is true, you need to locate the pump, disconnect, put a meter on the wires and have someone try and activate the pump. If there is voltage, you know the pump is getting power so it is bad. Common causes: you used straight water in the reservoir, which was warmed by the engine and grew mold, which fowled the pump. Or, you used a washer fluid with something that clogged the pump (like rainx). If there is no voltage at the pump, find your FEM module (should be in footwell area) and find the wires that go to the pump and see if you get voltage out when someone activates the pump. If you do, there is a cut wire somewhere between FEM and the pump. If not, your FEM module may be bad (did it get wet?).
Good luck!
Search this Thread:
Advanced Search
2addicts
