What front end work requires alignment? (re control arms)
06-19-2018, 08:35 AM | #1 |
2197
Rep 1,322
So while doing my water pump I saw what looked like a bit of liquid coming from the front control arm on the right. Guess I should be looking into those as well.
I was going to order them as they are cheap enough and look super simple to swap out but I have a road trip coming up next weekend so I wanted to pre-plan. It looks like the only adjustment I can identify is within the tie rod ends. Would going stock to stock old to new control arms (everything else being stock as well) require I get it in to get it aligned or are those all fixed points? I know in the old days with the 3 point front ends they basically said get it aligned if you sneezed on it but this doesnt look like, save for something being damaged (save for that bad bushing/bearing mine all look pristine), it could end up out of alignment. But if I need to Id like to book now so I know I can get it in ASAP after doing the work. (hoping this isnt like an oil discussion) |
06-19-2018, 09:32 AM | #2 |
103
Rep 1,520
I just replaced the thrust and control arms and left the steering tie rod ends alone. I didn't do an alignment after and it was fine. Better handling feel but no issues with alignment.
06-19-2018, 10:05 AM | #5 |
2197
Rep 1,322
06-19-2018, 10:06 AM | #6 |
2197
Rep 1,322
That is kind of my thought. Im using stock parts replacing non-bent stock parts and its 4 fixed points of contact so Im optimistic it should just be plug and play, just wanted to get experiences from those who have done just that.
