TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > BMW N52 Euro Intake Question
      06-18-2018, 11:14 AM   #1
steelcity94
Drives: '08 328i 6MT
Does anyone know the difference between the part #13717552437 and #13717555287 ? There isn't much online about the #13717555287 but it appears to be the same thing. Any help would be greatly appreciated!
Noir883.00
      06-18-2018, 11:20 AM   #2
david in germany
729
Drives: 118i, 335i and 328i
13717552437 Seems to be for the Asian market only. As they are quite strict on emissions I would lean towards the European model number.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit.
2011 328i Titan Silver M Sport "Franzel" <--Wife's car
Appreciate 2
Noir883.00
      06-19-2018, 07:31 AM   #3
steelcity94
So you do think there is definitely some difference in functionality between the two?
      06-19-2018, 07:35 AM   #4
david in germany
729
I do not know what the differences are but there has to be some physical difference because the different part numbers.
      06-19-2018, 07:35 AM   #5
Noir
Noir's Avatar
Drives: 2006 E90 330i 6MT
If one is restrictive for emissions, it means exactly that... probably not nearly as good a flow as the euro spec. just go with the auto, my fren.
See you, space cowboy.
Supercharged
      06-19-2018, 09:50 AM   #6
atmosphericM
Basic Bimmer
Drives: E92 328i 6MT ///M
I don't think there is any difference between them that matters when retrofitting. When I was searching for mine, I found both, and came to the conclusion that the part number didn't matter. I believe (99% sure) that the different part number is there because the intake came in two configurations which utilized different MAFS/IATS.. the part numbers just differentiate between the sensor, which you will not use anyway with your US Spec vehicle (you'll re-use your stock sensor). Hope this helps. If you search you'll find a thread I created on just this kinda stuff..
Cheers,
aM
Black Sapphire 328i ///M Sport Coupé
Save the Manuals!
Appreciate 2
      06-19-2018, 09:59 AM   #7
david in germany
729
Cheers,
aM
That is good info!
      06-19-2018, 10:40 AM   #8
Noir
Noir's Avatar
Cheers,
aM
thx! :0
Supercharged
Tags
euro intake, intake, performance, performance intake
