06-16-2018, 11:10 PM | #1 |
Team Zissou
3077
Rep 10,198
Stock Exhaust vs. Stock Exhaust w/ Dinan Midpipe comparison
I just got a Dinan midpipe from mike@x-ph.com and made a quick comparison video. This is with the muffler valve open:
06-16-2018, 11:24 PM | #2 |
35
Rep 83
This is now probably my next mod. Thanks for the video and the comparisons.
2018 440i Gran Coupe (F36), Glacier Silver/Black Dakota, M Performance and Track Handling Package, MHD Stage 2 and xHP Stage 3 flash tunes, Dinan Shockware and mid-pipe, HJS high-flow cat, AP Intake, RW Carbon duck bill spoiler and rear diffuser
06-21-2018, 05:48 PM | #7 |
7
Rep 32
Does installing the midpipe remove the valve functionality? Seems to have on mine, but can’t find anything online that it should. I’d imagine that should stay intact. 🤔
06-22-2018, 12:17 PM | #8 |
21
Rep 57
06-22-2018, 01:26 PM | #9 |
7
Rep 32
06-22-2018, 05:07 PM | #10 |
409
Rep 560
My 2-cents: This has nothing to do with Dinan (if it's simply a midpipe) my guess...is its an issue with your installer that unplugged your valve during install and simply didn't reconnect it / Have you stuck your head under your car to look?
06-22-2018, 09:51 PM | #11 |
7
Rep 32
I feel the same way. Don’t see how the midpipe would affect something like that. I did check and it was still plugged in. I did unplug it and replug it and it fixed the issue temporarily. Maybe I’ll try that again and check the fuses, too
06-28-2018, 02:11 PM | #12 | |
22
Rep 142
06-28-2018, 02:27 PM | #13 |
Team Zissou
3077
Rep 10,198
In Sport+ the crackles and pops are much more noticeable - maybe even more than I'd like. But it still sounds sweet. The car is much louder during a cold start, but under normal driving conditions there isn't too much extra noise. Once you get on it though it's noticeable. I'll most likely get the muffler section at some point. Overall I'm happy with it though.
kern4174449.50 |
07-02-2018, 12:40 AM | #14 |
21
Rep 57
Did you get a burning smell after a short drive when you first installed your? I just did mine today and I’m getting a burn smell. I’m guessing that’s the mid pipe is breaking in?
Took me a good three hours doing it at home. The exhaust cutting tool only cut 80% of the pipe, so I had to take off the exhaust and wiggle it till the last 20% break off. The initial cold start up is loud but quite down like stock after. Reving it in sport + mode at a stand still gives off a lot of burbles and pop. During the drive, it’s doesn’t pop as much as I’d like it too but that’s a giving since it’s only a mid pipe. So I will be connecting it with a Dinan exhaust later on. |
07-02-2018, 09:08 AM | #15 | |
Team Zissou
3077
Rep 10,198
07-02-2018, 12:19 PM | #17 |
Team Zissou
3077
Rep 10,198
07-02-2018, 02:11 PM | #18 | |
21
Rep 57
07-03-2018, 01:33 PM | #20 |
7
Rep 32
07-03-2018, 05:36 PM | #21 |
107
Rep 91
Drives: 2022 BMW M5 Comp
2022 M5: MBB/Aragon Ext Leather/ZCP/ZEC/789M' Wheels/Alu Carbon Struct Dark Trim/Red Calipers
2021 X5 sDr40i: Jet Black/Ivory White Ext Merino Leather/ZP2/ZPK/20'' Wheels (738)/Multi-Contour seats, Htd seats/armrests/steering wheel |
homie276.00 |
07-03-2018, 06:48 PM | #22 | |
21
Rep 57
https://drive.google.com/open?id=1HK...y5YfHSI_iQ7BAk |
