Upgrading to Lithium iron phosphate Battery that new M3 is using?
06-15-2018, 03:34 AM | #1 |
Rep 25
Hi all,
Recently I have come across the Lithium iron phosphate battery(LFP), which is really cool technology to upgrade, its discharge voltage is 12.8 to 13.2 flat, and the bad is cannot overcharge above 14.8V and strangely the new BMW M3 series is already having this options... which charing $1100+ for that battery... Some chart shows even with heavy stress on the car, the car voltage is keep very stable around 13.8V to 14V, the blue line is the LFP battery alone, and red line is LFP use along with some small super capacitor, which i don't consider it as super capacitor will discharge slowly over time. here is the normal lead acid voltage chart, same, red line is attaching some super capacitor: i am assuming the above chart is not cheating and they are doing same stress test, as i don't have equipment to validate but the voltage stability is really different... Somehow I found that the battery here in hong kong is around $500 with 60ah, so with this budget, I am considering to upgrade, however there is quite a few technical issue I faced. ppl here simply install and enjoy, but i would prefer to make my car ready to install first... so i dig deeper in charing method of our car, which basically it only have lead-acid charging profiles Our current E-Series is actually having 2 types of charging profile allow to code in CAS, normal lead-acid or AGM type, that covers from around 50ah to 100ah. However, the charging comparison as stated in F80 BMW technical doc is: AGM/Lead will normally use 14.2V to charge, but up to 16V (according to charging profile stored in DME to control, i believe)... http://f80.bimmerpost.com/forums/att...5&d=1406475520 and the latest charging Voltage with LFP in M3 is using flat 14.4V and +- base on temperature.... so, i think in order to properly equip our existing E90 N52 engine to safely use LFP, a 'hack' should do to our existing alternator to 'force' it output the 14.4V, but i have no idea how I can do that...? I was initially thinking to decode the BMW charging map, say by manually modify the last battery registration km value, and check on the output voltage to see how many voltage will increase per 1000 km, and then do the reset every 1000 km... but i don't know if tool32 can handle that? any idea/comments would be appreciate. thanks all for your time Last edited by yeukfung; 06-15-2018 at 03:40 AM.. Reason: fixed attachment location |
06-15-2018, 08:13 AM | #2 |
3973
Rep 7,215
There are parameters for this under the function LBATTCAL:
Code:
DME Name Description MSV70 CW_BATTCOD Enable hand coding MSV70 K_APPTBATINI Enable Application InitValue battery temperature MSV70 K_BATT_ALFAH Alpha Tau value battery back MSV70 K_BATT_ALFAV Alpha Tau value battery forward MSV70 K_BATT_BETAV Beta value battery forward MSV70 K_BATTHTAUVG Time constant battery back at VFZG> MSV70 K_BATTHTAUVK Time constant battery back at VFZG < MSV70 K_BATTORT0 Battery mounting location No1 MSV70 K_BATTORT2 Battery mounting location No2 MSV70 K_BATTVTAUVG Time constant battery front at VFZG> MSV70 K_BATTVTAUVK Time constant battery at VFZG <Time-constant battery at VFZG> MSV70 K_BATVFZGTAU VFZG switching threshold TAU battery MSV70 K_DTANSKOR Intake air model offset outside temperature MSV70 K_ILMINUMG integrated Air mass threshold outside temperature model MSV70 K_LBATTMAXK Maximum battery charging voltage trunk MSV70 K_LBATTMAXM Maximum battery charging voltage MSV70 K_LBATTMIN minimalistic battery charging voltage to light MSV70 K_LBATTTUMG MSV70 K_LBATTTUMGBA MSV70 K_MCOBATTORT Coding hand Battery mounting location MSV70 K_NMINUMG Speed threshold outside temperature model MSV70 K_OFTUMGCAN Offset ambient CAN MSV70 K_OFULADE Offset charging characteristic Battery Connection MSV70 K_PLBATTUMG Plausibility threshold battery ambient temperature MSV70 K_RLEITUNGK Resistance charging line battery trunk MSV70 K_RLEITUNGM Resistance charging cable Battery in engine compartment MSV70 K_TBATINIMAN Application INIT VALUE battery temperature MSV70 K_TBATTFTAUV Time constant 5 * Tau battery Front MSV70 K_TBATTTAUFH Time constant battery 5 * Tau behind MSV70 K_TIMERDLY Delay Time for starting value calculation MSV70 K_TUMGINI Initialization outside temperature model MSV70 K_TUMGTAU Time constant 5 * Tau outside temperature MSV70 K_UBATTNORM Battery Standard voltage MSV70 K_UKOMPK Application value compensation voltage Kaffer room MSV70 K_UKOMPM Application value compensation voltage engine compartment MSV70 K_ULADE_TAU Battery charging time constant voltage MSV70 K_VMINUMG Vehicle speed threshold outside temperature model MSV70 KL_BATTLSTR Speed factor battery ambient temperature MSV70 KL_EXPALH Function EXP (-ALPHA * tabst_w) back MSV70 KL_EXPALV Function EXP (-ALPHA * tabst_w) back MSV70 KL_EXPBETAV Function EXP (-BETA * tabst_w) MSV70 KL_LADEKENNL Battery charging voltage characteristic MSV70 S_LBATT1 Application switch1 selection substitute temperature MSV70 S_LBATT2 Application switch2 selection substitute temperature MSV70 S_LBATTAPPL Last edited by hassmaschine; 06-15-2018 at 08:51 AM.. |
06-15-2018, 09:55 AM | #4 | |
Rep 25
For the LFP battery...... after this post, i do a little bit search, in china taobao with an unknown brand, the design seems originate from taiwan (with overcharge/underchange protection and balancing circuit inside, that's what they told me...) and manufacture in china, with the 60AH LFP battery is just RMB1400... what a unbeatable price and i have ordered one a do some test. I will post some result later on this thread to compare any difference, probably it arrives next week |
06-15-2018, 10:12 AM | #5 |
Rep 25
Regarding to the parameter, i have tried to locate any job having name "LBATTCAL" in MSV70, but cannot find...
wondering is that I should use the FLASH_PARAMETER_SETZEN command to overwrite it? like puting the arg with K_LBATTMAXK;14.4 and i can use FLASH_PARAMETER_LESEN to read out the value first? another thought is that, if we can even decode the IPO file and retrieve the default parameter from the M3 DME file, then it's even easier to "migrate" the settings from that... but i have no knowledge in reading ipo files... Last edited by yeukfung; 06-15-2018 at 10:18 AM.. |
06-15-2018, 11:28 AM | #6 |
3973
Rep 7,215
You cant do that with coding, no such jobs exist. Its in the flash of the DME - it has to be tuned for it.
Also, you can only flash whole blocks of memory, you cant just change one or two bytes. Even if you could the checksum and RSA signature would need to be dealt with. Tool32 has no idea where any of the maps are anyway, it can only do things that are pre-programmed. The IPO from the M3 will not help, its a completely different DME. There's nothing in there that will let you change these parameters anyway. I can probably help with tools to do it, but as far as the actual calibrating its all up to you. I'd be cautious with a lithium battery though, you could start a fire especially with bargain chinese cells. Last edited by hassmaschine; 06-15-2018 at 11:35 AM.. |
Biginboca3763.50 |
06-15-2018, 12:08 PM | #7 | |
Rep 25
Thanks for your info and will carefully monitor it in first few weeks once installed. The battery isn't Lithium ion, but lithium iron phosphate (LiFePO 4) battery that seems to be quite safe, as least it won't explore like lithium ion battery, but sure everything may goes wrong. https://en.wikipedia.org/wiki/Lithiu...sphate_battery I have followed your another post in cloning MSV70 DME and i learnt BDM cloning MSV70 from that, wondering how could I provide you my existing DME file and do the modification, say limiting the charging voltage to 14.4V, the temp different in hong kong isn't really high, from 5 degree to 35 degree throughout a year, so maybe variant 0.1V? Another strange request is about the ZB file, currently i am using ZB#7581300 however, when the time i bought this car, it was actually using this ZB ZB#7568990 not sure if you have some backup or able to tune the DME to same as ZB#7568990? the story is back to a year ago, when I bought this car and discovered that this car DME has internal flash error, it goes to indy show and replaced a new DME to me with wrong DME ZB, the car runs like a crap, and then I flash with winkfp but unable locate my old ZB, the only way is to upgrade the ZB to latest version on my variant, which is ZB#7581300, but the car just does not seems to run as good as the old ZB number... this is my full story about a year ago.. http://www.bimmerfest.com/forums/sho...d.php?t=984639 |
06-15-2018, 12:11 PM | #8 |
3973
Rep 7,215
Yeah, I have that file. But it's an old version - I only support the newest version of the DME, but I should have the updated/correct ZB# that matches.
Most likely, the tune you have doesn't have the correct power class for your car. I'd just need your serial # to find it. edit: actually, 7581300 is the correct new version for your DME. I don't think it's an issue with your calibration, but maybe the power class in the used DME doesn't match your car. Last edited by hassmaschine; 06-15-2018 at 12:37 PM.. |
06-15-2018, 05:47 PM | #9 | |
Rep 25
06-15-2018, 07:50 PM | #11 |
Rep 25
my replacement DME is new from local part store, in virgin state.
at that moment, i have no idea on ECU coding and programming stuff, so I give my car to local indy which he said he could do it he loaded the ZB#7581278 to the replacement DME as what he told me it's the number provided by BMW HK service center, and the car runs like crap, I asked the indy to switch back to my previous ZB#, he refused to and that leads me to learn winkfp myself. and I diy flashed ZB#7581300 and the car runs good, so far has been running over 20000km, but just a bit different to what I feel with the ZB#7568990 at the time i bought this car, it pulled much better... maybe it's not related. |
07-26-2018, 10:50 AM | #12 |
Rep 25
Hi all,
Some updates on my findings playing with LFP battery after 3000km driving over 1 months... with some background info: LFP base voltage: 12.8V, lead acid 12.0V 14.4V constant voltage can charge the LFP to 100%, but with the alternator output, it will only keep the voltage at 14.05V, which means 90-95% of battery capacity can be maintained. For the LFP I used, it's 60AH, so, only around 55AH is inside the battery, for the charging profile, since AGM is more sensitive to overcharge, I have coded to the battery type to AGM 70AH which is the nearest profile to the 60AH battery.. Some testing - CCA Testing within this 3000km, it's varies from 1150 to 1230 CCA, it does not rise or drop much, more or less keep stable in this 3000KM journey, while comparing to 90AH AGM, it was around 900CCA to 930CCA - Internal resistance testing, it's varies from 2.35mOhm to 2.5mOhm , while comparing to AGM, it is around 3.0mOhm to 3.2mOhm - voltage drop during cold start, the MIN voltage recorded is 11.8V - 11.9V , while i didn't record the AGM, but for 60AH battery, it's very strong - alternator output test for cold start, I use inpa and deep obd to monitor the generator AMP from cold start to warm up, there is two case: 1) when the battery is full - the max AMP generated from alternator is around 90-100Amp(14.4V) for around 20 seconds, and eventually drop to 20Amp within 1 minutes, and the charge of battery reach 14.05V 2) when battery is NOT full - the max AMP generated from alternator is 170Amp(14.8V) for over 1-2 minutes, and start to drop when battery voltage reaches 13.8V and then eventually goes down to 14.05V after 2 minutes, and then back to 20Amp. - temperature test, i don't have equipment, just use hand to test several area, I can say... does not feel any heat/warm on the battery, just normal and usual drawback to my car with IBS: - IBS is now partially working, as it no longer able to detect battery state of charge when it's in sleep mode, it can still read the battery terminal voltage when the car is running. ==== For the result and feeling after upgrade the battery, it's real strong, the car pickup the rev much quicker, and rev up much quicker than before, especially from 3000 to 5000 rpm. state of charge when car sitting overnight(over 15 hours, so the surface charge should already consumed): it reads 13.42V, which is around 90%-95% (indicates the car is charging the battery properly) For the charging speed compare, I logged some data with the car during cold start for both AGM and LFP battery: AGM LFP comment: LFP charging much faster than normal AGM, maybe due to it's very small internal resistance. running voltage: so far, when the car equipped with IBS, it will detect the battery terminal to be 14.05V, and maintain that voltage, so for the Generator Voltage output, 95% is using 14.1 - 14.2V with around 25-35Amp output, and it raise to 14.4V only in cold start and slowly drop back to 14.2 when the battery terminal reachs 14.05V... with my observation... seems the AGM charging profile with IBS seems compatible with the LFP battery somehow... |
07-26-2018, 11:20 AM | #13 | |
3764
Rep 2,738
The only realized benefit I can imagine to this swap is less weight which means better acceleration and shorter braking (maybe you save 20lbs of weight so not really a measurable, noticeable advantage IMO). And of course the improved gas mileage as a result of the weight savings likely something to the tune of .0001mpg improvement lol |
07-26-2018, 12:11 PM | #14 | |
Rep 25
For the technical data, i don't think i can give you much as i am not expert, but i think it's mainly related to two aspect: 1) internal resistance is lower than AGM referring to it can discharge much faster than AGM, for this case, it's 3.2 - 2.4/2.4 = 33% less in the internal resistance 2) base voltage is the major difference, in which the AGM/Lead Acid base voltage is 12.0 (full charge is 12.6V) the LFP base voltage is 12.8 (full charge is 13.4V) so when on sudden rev up and demand, LFP will provide faster response to current change with much higher supply voltage when alternator regulator may not be fast enough to cope with the sudden current change, so that makes the car runs smoother with better spark? just my pure guess... |
07-26-2018, 08:43 PM | #15 | |
3764
Rep 2,738
They fire more frequently at higher rpms, so the hardest demands they see is at redline. Full throttle at 3000 or 5000 rpms is no more demanding on them than cruising steady at those same rpms. I’m not saying you didn’t feel the car pulled harder. Maybe your car does respond to the weight loss at a level you can feel. But I don’t think a battery can contribute anything to a sensation of more power outside of its lighter weight and 20lbs of weight loss on these cars is the same as adding less than 2hp. |
07-27-2018, 02:31 AM | #16 | |
Rep 25
your point is well taken Please correct me if i am wrong or mis concept in calculation in power consumption in ignition coil... and assume there are few cycles during quick acceleration which the alternator regulator cannot catch up with the sudden demand of the current draw and most of the current is draw from battery for several milli seconds...... with AGM, let's say it's base voltage is 12.6 (assume full) so the power provided to the spark via coil would be 12.6V * (2Amp (assume each coil draws 2 amp) * 6 (with 6 coil) = 151.2W if with LFP... 13.4V * 2Amp * 6coil = 160.8W the different voltage should has some effect to the spark produced? so far i also don't believe what i feel, ... thus i do so many data logging to see what's actually going on... if you have some suggestions to what data i should log and try to compare, please let me know... but those data are in milli-seconds level... which most obd diag tools cannot really read in that... maybe i should use the OTest to read the data out.. but it's windows app which need to connect to computer while driving... |
05-13-2020, 03:37 AM | #17 |
68
Rep 763
Drives: BMW E90 Dinan stage 3 335I
yeukfung, long term update on teh battery? Coding and alternator working ok?
2007 E90 335i N54 Montego blue with grey Dakota leather interior
Biginboca3763.50 |
06-12-2020, 08:10 PM | #18 |
24
Rep 144
I installed similar LifePo4 12.8v 60aH battery in my 335i.
Engine was replaced from a 135i so the alternator had no LIN interface. In the beginning everything was ok. Car starts ok and quickly charges to 14v. But after week in very cold mornings when car was started, the alternator would try and charge up to 15v which tripped the over voltage protection in the battery and the BMW would throw many codes as the battery disconnected with engine running. Very bad. Anyway seems to be normal function of the alternator internal settings. Got around this buy disconnecting the ignition signal to the alternator. Still charges when car starts but in some other default mode. Voltage slowly rises the 14v. Anyway all ok since running this way in the last month. |
07-07-2020, 12:18 PM | #19 |
79
Rep 250
Drives: E82 N52 6MT A51
I think the performance increase the OP thinks he is seeing is the alternator running at lower load on the engine. This can vary based on how bad the original battery was and how much electronics/options the car is running at a given time. I notice my car is bogged down when running all the heated seats at max. I use this trick to determine pulley noises on my engine. I can see the DME controlling the alternator to put less load on the engine as it is primarily programmed for efficiency and the new chemical battery can hold charge for longer and charges quicker but the DME will disengage all auxiliary load on the engine except power steering when power is requested with your foot.
07-18-2020, 08:26 AM | #21 |
3764
Rep 2,738
Just as another option I recently swapped to a 30ah Antigravity Lithium and it was pretty much a plug and play. They recommended I code the car with Carly to the lowest option, 40ah which I did and then it’s just install and run. This battery runs around $700 though, but it has some added features and is very easy to install and live with.
It’s been about 6 weeks now and no issues at all. The battery has a built in jump start from activated from a remote key fob and comes with a Bluetooth monitor that syncs with my phone and sends me state of charge every 24 hours. After 4 days of sitting the car was still at 99% charge with comfort access and all. Best of all this battery cranks harder than my previous 60a/h AGM ever did and weighs 13lbs.
07-20-2020, 01:14 PM | #22 | |
883
Rep 1,413
See you, space cowboy.
Supercharged |
