M8 AND 8 SERIES
BMW M8 Forum and 8 Series Forum BMW M8 and 8-Series General Discussion 2019 BMW 8 Series / M850i Official Thread: Information, Specs, Wallpapers, Videos!
      06-14-2018, 05:48 PM   #1
BIMMERPOST / Official Coverage
BMW 8 SeriesG15
M850i xDrive Engine
  • 0-60 mph in 3.6 seconds
  • New 4.4-liter V8 engine with M TwinPower Turbo technology
  • 523 hp from 5,500 to 6,600 rpm
  • 553 lb-ft peak torque from 1,800 to 4,600 rpm
  • Intake ports optimized for higher flow
  • Enlarged twin-scroll turbochargers
  • Electric blow-off valves integrated into the compressor housing
  • Redesigned air intake manifold and connection between air ducts for both cylinder banks ensures even pulsation during gas exchange, resulting in higher torque at lower engine speeds
  • Fuel injectors maximum pressure increased from 2,900 psi to 5,076 psi
  • New aluminium alloy increases engine block strength
  • Wire- arc sprayed iron coating for the cylinder walls
  • Reinforced, Grafal-coated pistons and optimized piston rings
  • Viscous damper on the crankshaft minimizes torsional vibration
  • Thermal shielding and the cooling circulation systems undergone extensive modification
  • Upstream coolant radiator helps manage engine's temperature during extremely spirited driving
Transmission / xDrive
  • Eight-speed Steptronic Sport transmission
  • Weight reducing design
  • Newly developed controller adapts shift parameters by networking with Navigation system (for example, controller avoids unnecessary gear shifts between two corners that follow in quick succession, or controller downshifts early when approaching an intersection to use engine braking to slow car)
  • Wider gear ratio spread
  • Optimized hydraulics control for sharper gear shifts
  • New torsion dampers
  • Shift paddles
  • Launch Control
  • Fully variable distribution of drive torque between the front and rear wheels
  • All torque is directed to rear wheels in situations when all-wheel drive is not needed
  • Electronically controlled rear differential
Suspension
  • Double-wishbone front axle / five-link rear axle
  • Torsion struts on front axle / load-bearing strut on rear axle
  • Independent rubber bearings and additional damping plates at rear axle
  • Special wheel hubs and wishbones allow camber values on both axles to be raised as far as possible
  • Adaptive M suspension standard on all 8 Series Coupe
Active Roll Stabilization
  • Active roll stabilization optional for M850i xDrive Coupe
  • Electric swivel motors on the front and rear anti-roll bars reduce body movement
  • Increases comfort when driving straight ahead by decoupling the anti-roll bar connection between wheels of an axle to counteract road imperfections
Integral Active Steering
  • Integral Active Steering standard
  • Rear wheel steering up to 2.5 degrees
  • Rear wheels steered in opposite direction of front wheels up to 45 mph (up to 55 mph in SPORT or SPORT+ modes)
  • Rear wheels steered in same direction as front wheels above 45 mph (above 55 mph in SPORT or SPORT+ modes)
M Sport Brakes / Wheels
  • 4-piston fixed-caliper brakes front / Single-piston floating-caliper brakes rear
  • Inner-vented brake discs and model-specific brake pads
  • 20-inch M light-alloy wheels in Frozen Cerium Grey metallic with high gloss polished face
  • 245/35R20 tires front and 275/30R20 tires rear
Weight Optimization / Construction / CFRP
  • CFRP (carbon fiber reinforced plastic): center tunnel, optional CFRP roof, other select body parts via optional Carbon Package
  • Optional Carbon Package: CFRP air intake bars, exterior mirror caps, rear spoiler, rear diffuser
  • Aluminum: front and rear supporting structures, roof, doors, hood, front firewall, front axle, wheel carriers, forged control arms
  • Magnesium: passenger compartment bracing tube
  • Lightweight steel: rear axle
Aerodynamics
  • Almost fully covered underbody
  • Active air flap control with adjustable kidney grille slats
  • Air Curtains including Air Breathers
  • Narrow exterior mirror bases mounted directly on the side window weather strips
  • Double-bubble roof (also available in optional CFRP)
Lighting
  • Standard Full LED headlights with BMW LaserLight technology
  • All-LED L-Shaped rear lights
BMW Digital Key
  • NFC technology allows 8 Series Coupe to be locked / unlocked from smartphone by holding it up to door handle
  • Can be shared with up to five other people via BMW Connected App
Interior
  • Standard premium Merino Individual leather with extended leather
  • Decorative contrast stitching
  • Optional upgraded Climate seats for driver and front passenger
  • Optional glass applications - gear selector, iDrive controller, start/stop button, volume button in glass and illuminated '8' visible through glass surface of the gear selector
M Performance / M Sport Exclusive Features
  • M leather steering wheel
  • Anthracite BMW Individual headliner
  • M pedals
  • M driver’s footrest
  • Apecial floor mats
  • Illuminated door sills with M logo
  • Instrument cluster displays M logo
Technology / Driving Assistance
  • 12.3-inch digital instrument cluster
  • 10.25-inch iDrive control display
  • Standard Harman Kardon audio system with sixteen speakers
  • Standard Head-Up Display (HUD) on all 8 Series Coupe with larger projection area and additional content
  • Standard Cruise Control with braking function and Collision and Pedestrian Warning with City Braking function
  • Standard Park Distance Control (PDC)
  • Standard Parking Assistant (can now exit parallel parking spaces also) with Reversing Assistant
  • Standard camera system with Rear, Top View, Panorama View and 3D View
  • Standard Remote Software Upgrade (over the air updates)
  • Newly designed function cluster (containing Start/Stop and Drive Mode buttons) with active haptic feedback
  • Optional Active Cruise Control with Stop & Go function
  • Optional Driving Assistant Professional includes Active Cruise Control with Stop & Go, Steering and Lane Control Assistant, Lane Keeping Assistant with Active Side Collision Protection
  • Optional BMW Night Vision system
Intelligent Networking
  • Transmission controller networks with navigation system to adapt shift parameters intelligently (for example, controller avoids unnecessary gear shifts between two corners that follow in quick succession, or controller downshifts early when approaching an intersection to use engine braking to slow car)
  • Auto Start Stop adapts to driving situation based on navigation data and by use of cameras and radar sensors of the optional driver assistance systems to prevent inefficient engine shutdown – for example when stopping briefly at junctions with yield signs. The movement of vehicles ahead is registered in order to determine the ideal moment for stopping and starting the engine.
  • Coasting function efficient enhanced. When traveling at speeds between 9 – 99 mph, powertrain is decoupled as soon as the driver lifts off the accelerator. The switch to this “sail” mode only takes place in driving situations in which it appears worthwhile and which doesn’t compromise comfort or performance. If the accelerator is released very suddenly for instance, the powertrain stays connected in order to use the engine’s drag torque to decelerate.
Premium Upgrade Options
  • Climate seats for driver and front passenger
  • Bowers & Wilkins Diamond Surround Sound System with 16-channel amplifier with 1,375 watts output, and 16 partly illuminated speakers
  • Optional glass applications (gear selector, iDrive controller, start/stop button, volume button)
Pricing
  • The 2019 BMW M850i xDrive Coupe is priced at $111,900 plus $995 Destination and Handling
Product Highlights
Wallpapers
BMW M850i Exterior in Barcelona Blue and Sunset Orange
BMW M850i Interior
BMW M850i Sketches
BMW M850i at Le Mans
Videos
Tech Specs
Full Press Releases
Full Press Release [PDF]
Full Specs For All Models [PDF]
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook
Follow us on Bimmerpost Twitter
Subscribe to Bimmerpost Youtube Channel
Appreciate 6
      06-15-2018, 12:29 PM   #2
Seba77W
Seba77W's Avatar
401
Drives: BMW 435i Xdrive Coupe
Awesome!
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
Appreciate 3
Alexxxx52.00
omg61872.00
      06-15-2018, 12:29 PM   #3
infamousq
infamousq's Avatar
Drives: 2018 Ford Raptor
Nice!!!!
2021 M5 (COMING SOON)
2015 M5 Imola Red (sold)
2008 Monaco Blue (sold)
2002 M5 Carbon Black (sold) should have never sold her
Appreciate 2
      06-15-2018, 12:31 PM   #4
Fugly M3
Fugly M3's Avatar
5071
Drives: 2023 M3CX
really like it...but kinda looks like a fancier mustang?! Especially from the side view...stretched rear portion.
      06-15-2018, 12:33 PM   #5
zuschnell
zuschnell's Avatar
556
Drives: '19 m5, '18 991.2 gt3,
Car looks good, but the back is a bit busy. Overall, looks pretty clean. I hope this thing outperforms the competition and that Bmw continues the current trend of making drivers cars once again.
Gone but not forgotten: '10 X5M, '14 550ix, '17 M3 zcp, '11 aw e90 M3 zcp, ?11 sg e90 M3, '17 X5M, 19 F90 M5
Current: ?13 e92 m3 ESS 585, 22 f95 x5m Comp, Track - '18 manual 991.2 GT3, Wife's family truckster - '20 Volvo XC90 T8
      06-15-2018, 12:33 PM   #6
Drj161
Drives: bmw x5 e53
Been dying for this post to happen.
Appreciate 2
Ibiza3611.50
      06-15-2018, 12:33 PM   #7
Btyler227
Btyler227's Avatar
Drives: 2017 X4 M40i
Even better than I expected. WOW!
F26 X4 ///M40i Carbon Black
Appreciate 2
      06-15-2018, 12:35 PM   #8
E92LNGCGY
434
Drives: F97/Q5/982 GT4
3.6 to 60mph for the M850?? Wow. Realistically this is a low 3 sec car. Can't imagine what the M8 could do.
      06-15-2018, 12:35 PM   #9
JustChris
JustChris's Avatar
17488
Drives: Tesla MYRWD
That's a cracking looking GT car!!
PS
8ers Gonna Hate. (Stolen from Car Mag)
My car made front page of Bimmerpost
      06-15-2018, 12:38 PM   #10
JasonCSU
Drives: '08 135i, '88 325is
1988 BMW 325is  [0.00]
2008 BMW 135i  [0.00]
I must say, I really like how it turned out.
Delivered in Munich, broken in on the Nurburgring.
Appreciate 4
omg61872.00
Toome159.00
      06-15-2018, 12:39 PM   #11
The J-Man
626
Drives: BMW
Any speculation on price point? Guessing $110K+ fully loaded?
Interior is decent but not really up to snuff for this price point.
      06-15-2018, 12:41 PM   #12
Stepanyan
Stepanyan's Avatar
47
Drives: 23 M4cx Convertible
Wow. Those real life pics are amazing!
Appreciate 3
F85Matt217.00
omg61872.00
      06-15-2018, 12:42 PM   #13
ellipsis212
ellipsis212's Avatar
1618
Drives: 2017 M3
2018 BMW M3  [0.00]
Bravo BMW!
Appreciate 2
      06-15-2018, 12:43 PM   #14
goj
goj's Avatar
Drives: 2016 EBII 340i 6-MT
God damn that is HOT
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04
Instagram: @brandons340i
Appreciate 2
      06-15-2018, 12:43 PM   #15
vinny84
vinny84's Avatar
Drives: 2005 BMW X5
Best BMW in their current lineup!
      06-15-2018, 12:44 PM   #16
jmg
jmg's Avatar
18704
Drives: G82 M4C X-Drive
2022 G82 M4C X-Drive  [9.85]
2018 F80 M3 CS  [9.87]
2019 i3 BEV  [0.00]
I think it looks really good. Any speculation on price? $110k?
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing
Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3
IG: Raging_G82
      06-15-2018, 12:44 PM   #17
ThugzZ BunnY
ThugzZ BunnY's Avatar
Drives: 2011 335i
I cant help but see a mustang. those lines on the rear and the shape of the windows are almost identical.
IG: @andy__wise
Inquiries: Andrew.Wise@bmwofchattanooga.com
      06-15-2018, 12:44 PM   #18
RyanRBurt
Australia
17
Drives: BMW 125i F20 Msport
The thing is gorgeous. So stoked on how it turned out. Looks amazing in that orange with black accents
      06-15-2018, 12:45 PM   #19
frankiebones
frankiebones's Avatar
5299
Drives: Fire Orange G80 6MT
why so heavy? 4,400 pounds is a boat!
Fire Orange 6MT G80 (Miss July, 2021 Cover of Bimmerpost)
SMB M3 CS (gone)
YMB F80 6MT (gone)
Appreciate 3
      06-15-2018, 12:45 PM   #20
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Videos uploaded
      06-15-2018, 12:45 PM   #21
M-Pilot
M-Pilot's Avatar
Drives: 981 Cayman GTS
Is that Sunset Orange?
Appreciate 2
      06-15-2018, 12:46 PM   #22
sward
sward's Avatar
Sweden
632
Drives: i7 xDrive60
2023 BMW i7  [0.00]
Love it. Saw it in April with the X5 G05 on a private event. It's even more stunning irl
/Fredrik
i7 xDrive60 -23 Sold: iX -22, X5MC -20 (F95), X5M50d -19 (G05), X5M50d -17 (F15), X5M50d -14 (F15), 116d -13 (F20), X5 3.0D -10 (E70), M3 -10 (E93), 320DX -10 (E91), 320D -08 (E91), X3 30D -07 (E83), 335 -07 (E92), 325 -05 (E90), 320 -02 (E46), 318 -00 (E46), 320 -93 (E36), 318 -89 (E30)
Appreciate 2
Ibiza3611.50
m8
