Replace valve cover bolts or not?
06-11-2018, 08:33 AM | #1 |
11
Rep 39
Hi,
I have a bit of a conundrum here. I need to know whether I need to replace the valve cover bolts when replacing the gasket or not. It's a 2011 E90 (328i) with an N52 engine (I'm fairly sure it's not N51 - at least when I enter the last seven digits of the VIN on realoem.com, it says N52). Some sources say that with the N52, I definitely need to replace the bolts as they're made of aluminum. Some sources, however, say that after 2007, BMW switched back to steel bolts. Now, is there any surefire way to figure out whether I need new bolts or not BEFORE taking the engine apart and checking the bolts with a magnet? If I need to replace the bolts, I would need to order them online and it would be great to order them beforehand, not when I've taken the engine apart and already have all other parts, and then wait for a week for the bolts to arrive. Thank you! |
06-11-2018, 09:00 AM | #3 |
11
Rep 39
06-11-2018, 09:50 AM | #4 |
Hoonigan
6849
Rep 3,000
Drives: '09 328i, '98 Wrangler
If yours is a 2011, you will have the plastic valve cover. Only the early engines from 2006 with the magnesium valve cover have the aluminum valve cover bolts, since the magnesium cover would react with steel bolts.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
06-11-2018, 09:51 AM | #5 |
Because Racecar
126
Rep 266
Inside your door you can find a the date of production of your car. Once you know the production date you can figure out which engine you've got. Although, if I was you, I would just order the bolts to be safe.
06-11-2018, 09:58 AM | #6 |
Grandmaster
768
Rep 798
2011 328i with N52B30 engine has plastic valve cover with steel bolts that do not need to be replaced.
However you may wish to replace the metal park plug hole liners, I had a tough time getting them out without damaging them. In the end I did get them back in and everything it was just a hassle. If I had to do it again, I would take out the valve cover bolts, pop the cover loose to get the metal liners popped out of the head and then take the liners out. That would have been easiest.
Daily - 2018 Alpinweiß ///M2 6MT Exec Rain/Snow/Winter - 2011 328i 6MT Sedan - Black on Black, Sport Package Sold, But Not Forgotten - 2009 135i 6MT - Black on Black, M-sport, JB4 |
06-11-2018, 10:08 AM | #7 |
11
Rep 39
Yes, it does have a plastic cover. So the rule of thumb is, plastic cover=steel bolts, i.e. I don't need to replace them?
06-11-2018, 10:09 AM | #8 | |
11
Rep 39
06-11-2018, 11:12 AM | #9 | |
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
06-11-2018, 11:24 AM | #10 | |
11
Rep 39
And I didn't order an OEM gasket, I ordered a genuine BMW gasket. Do I still need the Ultra Black? |
06-11-2018, 11:37 AM | #11 |
douchebaggo
186
Rep 972
The RTV is to hold the gaskets in place when you reinstall the cover. It's not needed for sealing. Without it you run the risk of the gaskets falling out of the grooves. You then roll/fold the gaskets therefore resulting in a leak. You probably won't need it if you are experienced and being extra careful.
06-11-2018, 11:40 AM | #12 |
295
Rep 2,202
Though I did not replace the bolts when I did my VCG job I would advise you to replace them.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
06-11-2018, 11:45 AM | #13 | |
Grandmaster
768
Rep 798
The service manual makes no mention of doing this, the service manual just says to "cover the gaskets and gasket grooves in a small amount of anti-friction compound, such as glycerin". In my experience (and yes I actually do have experience in this on my old VW golf lol) in using ultra-black to seal valve cover gaskets is that it doesn't really work that great, its the preload in the rubber seal that actually makes the seal work. If you put ultra black on there you may just make a mess to clean up at the next replacement without actually making it last any longer. Ultra-black is great at making metal-metal seals like on gasketless oil pans, but on a flexible part like a rubber gasket I dont think it does much. Important to note that I'm not saying it makes it worse, but rather that I don't personally think there's any good evidence that it makes the seal better or last longer... but it definitely creates a mess for the next person to replace the VCG to clean up! YMMV. Ultra-black in the groove will definitely help hold the gasket in place though there is no arguing that. Also somewhat concerning that multiple people are suggesting blindly replacing all the bolts backed by no reasoning. I suggest that instead you take that money you don't want and I can give you my paypal address.
06-11-2018, 11:53 AM | #14 | |
277
Rep 1,575
06-11-2018, 11:53 AM | #15 | |
11
Rep 39
Can you please explain to me, what does "starting with inside fasteners" mean? Is "inside" the passenger side? |
06-11-2018, 11:54 AM | #16 | |
277
Rep 1,575
Dont put it on top of the gasket Sigh. People messing up their cars and wonder why |
06-11-2018, 11:56 AM | #17 | |
Grandmaster
768
Rep 798
Really just DONT start at one bolt and then go around in a circle. Thats how you cause problems.
Daily - 2018 Alpinweiß ///M2 6MT Exec Rain/Snow/Winter - 2011 328i 6MT Sedan - Black on Black, Sport Package Sold, But Not Forgotten - 2009 135i 6MT - Black on Black, M-sport, JB4 Last edited by Joebie; 06-11-2018 at 12:01 PM.. |
06-11-2018, 11:57 AM | #18 |
Grandmaster
768
Rep 798
I felt as though it made pulling the cover out easier although I know many people replace the cover without ever removing the sleeves.
I had a hard enough time getting the thing back in without worrying about the fragile sleeves lol
06-11-2018, 12:05 PM | #19 |
277
Rep 1,575
Easy. The less you touch them. The less they get deformed.
06-11-2018, 12:07 PM | #20 |
Grandmaster
768
Rep 798
Maybe I'll try it without taking them out next time I do a VCG then (hopefully in another 100k miles lol)
06-11-2018, 12:29 PM | #22 | |
11
Rep 39
Tags |
valve cover, valve cover gasket replacement |
