2011 E90 DIY Log
06-10-2018, 11:41 PM | #1 |
535
Rep 432
2011 E90 DIY Log
This is my DIY log to keep track of all the changes I have done to the car. The goal is to upgrade weak points of the stock car while maintaining an overall OEM style.
2011 335i M-Sport 6 Speed Black Sapphire Metallic Exterior Black Dakota Interior Glacier Aluminum Cube Trim CIC/Nav Start 6/11/2018 46,000 Miles
Current 10/15/2023 89,000 Miles Upgrade List Engine
06-11-2018, 09:28 PM | #2 |
535
Rep 432
Battery Discharge High Warning
I kept getting a Battery discharge high alarm when the car would sit for a while, ended up replaced the 80ah with a 70ah AGM from BMW and coded it to the car.
DIY Used to Code Battery: https://www.e90post.com/forums/showthread.php?t=1338302 Seems to be okay now, no more risk of being stranded. Last edited by bmw335ie90; 08-03-2020 at 12:04 AM.. |
06-11-2018, 10:14 PM | #3 | |
39
Rep 161
That being said, i replaced my battery with an exact item from BMW; I installed it without coding and no issues so far. I don't plan to keep the vehicle extremely long so I didnt pay to have it coded. Will do it if I keep the vehicle. It's more detrimental to the battery than the vehicle from what I understand if not coded it. as far as your bluetooth streaming I also have a 2011. Mine also has no music streaming. What is your build date? It was a feature added for later build dates. |
06-11-2018, 10:24 PM | #4 | |
535
Rep 432
Build date 03/10. For Bluetooth streaming music I had to retrofit a combox from a newer model BMW (build date on combox is 2014). I'll post that up eventually |
06-12-2018, 10:11 AM | #5 | |
39
Rep 161
06-17-2018, 08:40 PM | #7 |
535
Rep 432
Combox Retrofit
Sick of not having Bluetooth music, so i retrofitted a telematics combox from a 2014 BMW. Coding and wiring were fairly simple as there were very good DIYs posted on the forums. Since I decided not to do make adapters the wires are a bit too short to bolt the combox to the MULF/TCU rack, I will eventually cut and extend the wires but it is temporarily Velcro'd to the trunk. Whole thing cost me about $150, should be able to sell the old TCU/MULF and make back some cost.
DIY Links General/Wiring: http://www.bimmerfest.com/forums/sho...d.php?t=772784 Coding: http://www.e90post.com/forums/showthread.php?t=1364741 Disable SOS Error: http://www.e90post.com/forums/showthread.php?t=805677 Current setup, the two unused cables are for GSM Signal I believe (BMW Assist/SOS) which have been disable via coding: Album Art via USB thumbdrive or iPod: Bluetooth Audio: Last edited by bmw335ie90; 12-10-2022 at 06:16 PM.. |
07-01-2018, 02:32 AM | #8 |
535
Rep 432
Wheels, Misc. Exterior Upgrades
Swapped out the original style 193 wheels, the runflat tires on them were almost bald:
18x9 Square Apex Arc-8 ET30, Hyper Black Continental DWS06 255/35 New side indicators: Arc Angel Halogen Angel eyes. Coded them to run brighter at 12.0V with headlights on (original was 6 or 7V if i remember correctly): Last edited by bmw335ie90; 12-10-2022 at 06:16 PM.. |
lab_rat394.50 Mosaud19983940.50 |
07-01-2018, 05:32 PM | #10 | |
395
Rep 662
I like seeing cars bought at auction (that were most likely neglected) and brought back to health.
No messing around either! Serious elbow grease with maintenance & great mods right away. I love these kind of threads...keeps me motivated.
07-02-2018, 12:42 PM | #12 |
535
Rep 432
They are OEM, the quality doesn't seem much better than aftermarket ones to be honest, I was just hoping that they resist the sun fade more. You can always sand the yellow varnish off and spray some clear coat on them like you would a headlight if you want to save some cash.
07-02-2018, 02:47 PM | #13 |
682
Rep 1,155
I seriously need to do the Bluetooth retrofit. is the module from the 2014 the same as what came in the 2011?
07-02-2018, 04:46 PM | #14 | |
2188
Rep 5,002
You buy the TYR ones? |
07-02-2018, 11:41 PM | #15 | |||
535
Rep 432
https://www.ecstuning.com/b-genuine-...y/63137253325/ https://www.ecstuning.com/b-genuine-...y/63137253326/ --------------------------------------------------- Anyways, I just found some oil leaking from the passenger thrust arm bushing. Both have quite a bit of play when you move them around, I guess this gives me a chance to put some upgraded ones that are more solid. Last edited by bmw335ie90; 07-02-2018 at 11:47 PM.. |
07-22-2018, 05:58 PM | #16 |
535
Rep 432
Finished Combox Install
Extended the wiring on the combox so it could be mounted in the OEM spot.
Before: After: Last edited by bmw335ie90; 12-10-2022 at 06:16 PM.. |
Drifter2090909.50 |
05-27-2019, 02:30 AM | #17 |
535
Rep 432
Some miscellaneous stuff:
05-27-2019, 08:15 AM | #18 |
17315
Rep 18,737
Nice thread. I'm interested in why you changed out the lug bolts at just 51,000 miles. I thought I was the only one who did stuff like that. But mine were well worn out after 100 or so tire rotations/wheel removals; they kept jamming in my 17MM impact sockets.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
05-27-2019, 08:48 AM | #19 |
2657
Rep 6,290
Omg hahaha I was wondering if I was the only one who found those wack.
My car is lowered and in picture you can easily see them. One side was already cut off so I figured eh let's pull em of. I wonder how much of a purpose they serve. I think BMW call that part a debris deflector or something. |
05-27-2019, 02:26 PM | #20 | ||
535
Rep 432
01-12-2020, 07:31 PM | #22 |
535
Rep 432
Engine Modifications/Tune-up:
