Pass restraint system fault after removing seats
06-10-2018, 11:57 AM | #1 |
Rep 8
Last week I picked up a e92 08 335i space grey on red leather with 100k mi for 12k.
Yesterday I removed the seats without disconnecting the battery, shampooed the carpet, and cleaned the leather. Getting the seats slightly wet. After letting the car dry and plugging in the seats I get a pass restraint fault. I dig som digging and I found a few things that can cause this fault. The seat mat senor getting wet and not disconnecting the battery when removing seats. I am wondering if there is a computer in the footwells that I could have gotten wet that would cause that fault as well? Does anyone have experience with this or have any insight on what caused this fault and how I should go about diagnosing or resetting the fault completely? Apreaciate it. [IMG][/IMG] Last edited by Kipperskipper; 07-27-2018 at 05:45 PM.. |
06-10-2018, 04:02 PM | #2 |
398
Rep 1,579
Double check that the pins are not out of line on the yellow connector. The Y pin can pop out of it's slot sometimes. You don't need to disconnect he battery. You just can't turn the car on with the seats disconnected. If you turned the ignition on, you will need to reset the code.
06-10-2018, 05:24 PM | #3 |
Rep 8
Ohh ok. I might have tripped the fault by turning on the ignition without seats. Hopefully i can just clear that code. How do I clear it? I'm under the impression that I need a special cable and computer software?
06-11-2018, 02:27 PM | #4 |
110
Rep 2,017
Drives: AW 07 e92 335i + AW 11 X5 35d
yes you will need a cable. You can use bmw icarly or INPA.
06-30-2018, 02:27 AM | #5 |
Rep 65
Glad I came across this. I did the same exact thing. Oddly enough, I removed the seats before but never turned the car on and no light. This time around, I removed the seats and had to move the car - thus triggering the light. My seat removal was for sub upgrade on my E93. Good to know it's just a simple reset needed. Just hate looking at the fault indicator.
06-30-2018, 04:19 AM | #6 |
729
Rep 1,815
Disconnecting the seats with the battery connected will cause a fault 99999.999999% of the time.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
06-30-2018, 10:27 AM | #7 | |
Is it the shoes!?
3884
Rep 5,112
There are some exceptions to this (e.g. passenger occupancy sensor), but that's the general rule of thumb. |
07-02-2018, 02:42 AM | #8 |
Rep 65
I disagree. I have removed my front seats (convertible), with battery connected a few times for running wires, speaker sub upgrades, etc and have never tripped a code UNTIL I turned the car on this last time. I just cleared everything with my computer and I’m all good again.
07-02-2018, 06:49 AM | #9 | |
729
Rep 1,815
07-04-2018, 01:47 PM | #10 |
Rep 65
david in germany729.00 |
07-05-2018, 03:59 AM | #11 |
75
Rep 630
Drives: '09 335 E93 6MT
Did you read the fault code?
Convertible | Manual | M-Sport | MHD Stage 1 + FMIC | 335is Clutch | ER CP | RB Inlets | VRSF 5" Stepped FMIC | M3 F/R Control Arms | KW V3 | Hawk HPS Pads | Stoptech Slotted Rotors | Blackvue DR650-2CH Dash Cam | LCI Taillights
07-08-2018, 04:33 AM | #12 |
Rep 65
