Car stuttering with acceleration
06-09-2018, 01:41 PM | #1 |
Rep 16
When accelerating at a fast speed/rate (merging on highway) usually around 4th gear, car starts stuttering/struggling pretty bad. As I let off gas (still accelerating) it'll go away for the most part. But once I get on it, it stammers, but only in 4th gear or higher.
2008 328xi E92 124k Any thoughts on what might be causing it? |
06-09-2018, 02:04 PM | #2 | |
102
Rep 343
Might be helpful for us to know what car your have |
06-09-2018, 02:44 PM | #3 | ||
Rep 16
06-09-2018, 02:56 PM | #4 | |
102
Rep 343
did you use a comprehensive BMW scanner? your generic autozone car scanner will not always pick up codes. try doing a full throttle pull to redline and see if you get a warning message for reduced power (your check engine light will come on saying reduced power but the light will go away once you restart your car) this is your opportunity to scan the car and check which cylinder is misfiring. or, just replace all your spark plugs and ignition coils. this will almost certainly solve the misfire. |
06-09-2018, 04:03 PM | #5 |
205
Rep 349
if there are no codes and only it happens in 4th gear then it is probably a transmission issue. I know BMW does not recommend tranny fluid change but I had tranny problem with my old 328i which completely went away after fluid/filter/gasket change. My problem was different though.
06-09-2018, 05:56 PM | #6 | |
102
Rep 343
06-09-2018, 10:37 PM | #7 |
45
Rep 158
Drives: White Buffalo
similar thing happens with my n55 e92. It puffs a dusty brownish color smoke during the stuttering at wot. I recently changed plugs and got no codes when it happen.
currently dealing with stuttering after a delayed cold start. car starts tripping, rpms bounce and then it dies. Check all reachable vac lines-no issues. In the process of cleaning maf sensor now, next, not sure about how to go about check the pcv. Car does whistle somewhat which is why I thought pcv. Changed out the crank seal, ofhg/oc, new radiator, wp/therm and hoses. |
06-09-2018, 11:02 PM | #8 | |
102
Rep 343
does your car have trouble starting, like it cranks longer than usual before starting? Sounds like you need a new fuel pump. Could also be fuel injector or ignition coil issue |
06-12-2018, 03:33 PM | #9 | ||||
45
Rep 158
I checked all possibilities. Have yet to try the bag trick, but the culprit was intercooler coupling popped off. I don't think the clip seated correctly. I do hear a slight whistle upon acceleration so I am gonna try the bag. Thanks. I'll update and get back to you. |
06-12-2018, 03:44 PM | #10 | |
39
Rep 161
AND to test the PCV this is copied from the pcv valve of doom thread: "You can easily test the PCV valve for failure by holding a smoke source (match, cigarette) close to the hose barb with the engine idling. If smoke is continuously ingested into the valve the diaphragm is leaking. Alternatively you could check that tissue paper clings to the barb tip, or for absolute certainty you can attach a clear hose and see if motor oil or water is continuously drawn in. More scientifically you could apply 38mbar positive pressure to the barb with the engine off and confirm that the pressure is held for a reasonable time but few shops have the equipment for that. Do not connect a pressure gauge to the barb while the engine is running, you will interfere with the PCV operation and will not get any useful information anyway." |
06-12-2018, 07:05 PM | #11 |
Retired US Army/Police Officer
30
Rep 161
Drives: F10 M-Sport, E-92
Having the same issues with my 2013 328i coupe. Getting no codes so I will just drive it until a code pops up, Will pull engine cover off tomorrow and see if there is anything obvious can be spotted. Car has around 40,000 miles on it. Hope you find out what’s wrong.
318IS-330IC-E90-E92 328i F10 535i M
