electrical failure
06-09-2018, 01:59 AM | #1 |
11
Rep 103
electrical failure
I had a belt break which. caused damage throughout the engine. The BMW service center says I need to replace the following:
Cooling fan Power steering pump Belt and Tensioner Oil Filter Housing Gasket Oil Service Battery He is quoting me $3600 plus tax. I am the original owner, the car has 125K miles, and I have maintained it meticulously. I have also spent a lot of money replacing parts, censors, breaks, etc over the past 2 years. I am not prepared to dump another 4K into the car. I have been looking for a independent service center within towing range of my area (car is in Syracuse presently) who might do the work for a more reasonable price. But so far, no luck. Any suggestions? Any ideas on selling a car that is not running and cannot be driven? |
06-09-2018, 03:49 AM | #2 |
264
Rep 459
That estimate is way too high.
Do you work on cars? Most of that work is pretty straight forward. I'm having a hard time imagining how that much damage could occur from a belt failing. Definitely get a second opinion. Keep in mind that the e90 engines are known to ingest the belts. Basically the belt shreds get wrapped around the crank pulley and stuffed through the seal. Once inside the engine, they get chopped up and plug the oil pickup, then serious damage can occur. Make sure there aren't belt pieces behind the crank pulley, and make sure that seal is in good shape. |
lab_rat394.50 |
06-09-2018, 04:53 PM | #3 | |
395
Rep 662
Rocketsurgeon is correct, that estimate is an extremely high dollar amount - if it is only for the parts you listed. Both the BMW & Bentley manuals show the repair/replace procedures for the listed parts as straightforward and relatively simple.
Bonus: the parts are not that expensive, either. If possible, I would try the repair myself. If that's not possible, then it's time for a second (or third?) shop's estimate. Good luck, and let us know how it turns out.
kylerwinters10.00 |
06-10-2018, 08:23 PM | #5 | |
205
Rep 349
As others have pointed out OFHG leak on e90 engines may cause the belt to get dislodged and wrapped around the shaft. Make sure belt did not get sucked into engine. |
