BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > H&R Wheel Spacer
      06-09-2018, 01:10 AM   #1
bmwstve
65
Drives: BMW X6, MHD Stage 2
H&R Wheel Spacer
Installed H&R Wheel Spacers several months ago, followed all instructions for installation, prepping of surfaces, torque wrench etc..
Removed them today for regular inspection
noticed on the Rear Passenger Side that there is a visible line that goes AROUND the spacer (inner side)
The line is not deep but can be felt with fingernails.
I checked all wheels
front wheels don't have this line
on the Rear Driver Side, there is also a line but it does not go around the whole inner side of the spacer.
When installed on the car, the Hubcentric ring of the car GOES OVER the visible line on the spacer.
I'm concerned, is the line a crack or maybe a weak spot?
Thanks
      06-09-2018, 07:51 PM   #2
Big Mexican Women
102
Drives: 2011 528i
No idea but I would not be installing that back into my car
      06-10-2018, 04:31 AM   #3
bmwstve
65
ok thanks
it seems to be a scratch
but i dont know what's causing it
      06-10-2018, 04:49 AM   #4
dmatre
Drives: 2011 328i Sedan
Opposite opinion.
It's a scratch, nothing to worry about.
When mounted, the spacer is under compression. Even if the spacer was cut into several pieces, once the wheel was mounted and bolts tightened, there could be no movement. Aluminum is a soft metal, and will bend rather than 'cracking' spontaneously in the middle of an unstressed area.
My spacers are marked/scarred all over. Doesn't make them less safe.
If you like them, use them.
      06-10-2018, 06:13 AM   #5
bmwstve
65
Originally Posted by dmatre View Post
Opposite opinion.
Let me check on them
the line or scratch is perfectly straight and even, that goes around the whole inner circle.
I'm thinking its probably caused by the hubcentric ring on the car itselft, but when installed on the car, the hubcentric ring goes "over" the line/scratch, thats why I'm unsure.
      06-10-2018, 08:30 AM   #6
Emilime75
1209
Drives: 2010 335i E92 LeMans Blue
It's possibly just a remnant of the machining process...which is now more noticable because some dirt/grime got in it. Hardly anything to be concerned about.
      06-10-2018, 12:01 PM   #7
Shane335
Drives: 07 335i E90, E36 M3
I wouldn't worry to much I've installed hundreds of them. Mine have a similar mark.
      06-11-2018, 06:11 AM   #8
bmwstve
65
thanks for the replies
