Cruise control disabled, 4X4 warning, DSC sign on, turn signal doesn not turn off
06-04-2018, 05:49 PM | #1 |
Rep 4
Hi everyone,
Your great input will be highly appreciated, i drive a 2008 e92 335xi and recently i had got there warning signs for 4X4, DSC, and brake in yellow, after these signs showed up my cruise control does not respond and my turn signal does not turn off by itself. I am attaching the warning signs im getting. Thanks. |
06-04-2018, 09:24 PM | #3 |
119
Rep 228
Scan your car and post codes. I just fixed 4x4, abs, traction control, and red brake light by replacing transfer case actuator motor, 150$ used. My lights were intermittent and would come on at startup, but never while driving Cruise wouldn't work when lights were on.
06-05-2018, 12:49 AM | #4 |
Resident Pedant
503
Rep 792
Might be your steering angle sensor. You need to read the codes, as suggested.
'15 F30 335i 8AT Estoril II/Black (12.218 @ 114.94mph)
MHD Stage 2+ 93 / XHP Stage 3 / M-Goodies / K&N Filter / ER CP / CSF IC / NGK 97506 / ER DP / Michelin A/S 3+ |
06-07-2018, 03:00 PM | #5 |
Rep 4
recalibrate steering angle sensor
After checking the codes I got the errors with Steering angle sensor, is it possible to recalibrate the system? and make the warning signs to go away? I tried to clear the codes but these do not go away. I am attaching the fault codes here.
