Messed up oil filter housing bolt
06-04-2018, 03:28 PM | #1 |
39
Rep 155
Help!
Was trying to replace my oil filter housing gasket on my 2008 E93. Could'nt get this last bolt on the front bottom out. I tried with a E10 1/4 socket + a swivel joint but there wasn't enough space to remove. Then I put the circular end of a 5/16 spanner and I think I damaged the bolt a bit. Not sure how to take this off, im worried that im going to continue to damage the bolt. Pic attached. Pic is here (couldnt figure out how to attach it in the post): imgur.com/a/wSKKHJk Last edited by greenberet123; 06-04-2018 at 03:29 PM.. Reason: Pic didnt show up |
06-04-2018, 03:37 PM | #2 |
2124
Rep 2,758
You need(should) to remove the coolant hose that goes into the head right there, then you have plenty of room to get to the bolt. Be aware that if you pull that hose out of the had you run a big risk(75%) that the plastic fitting on the end will break off in the head and you will also have to buy a new hose to replace it.
06-04-2018, 03:39 PM | #3 | |
Art Collector
2425
Rep 3,448
Here is the pic:
Dammmmmn look at all that resolution! Quote:
06-04-2018, 03:42 PM | #4 |
27
Rep 38
Drives: 2011 335i Coupe
You have to remove the coolant hose blocking access to the bolt, very easy and saves agrivation
- 2011 335i 6MT
06-04-2018, 03:57 PM | #5 |
68
Rep 211
you need a racheting E10 box wrench to get that thing off. Like this: https://www.amazon.com/Apex-Tool-Gro...e10+box+wrench
If you undo that one last, you can walk the filter housing off the bolt by pulling it away from the head as you undo it. This will enable you to get the filter housing off without undoing the coolant hose. Once you have the filter housing off, undo the 2 bolts holding the coolant neck in, and using something blunt that wont split the coolant hose fitting and wont scratch the coolant passage, knock the coolant hose out from inside the filter housing port. If you grab it and twist it from the front of the engine you're bound to bust the plastic fitting. Once you have the coolant hose off, you can remove the bolt from the hole and replace it, as well as now seat the filter housing gasket on the head before tightening. |
06-04-2018, 03:59 PM | #6 |
Rep 6
Another trick is to remove the other bolts 1st and leave that one until last - that way the head of that bolt does not have to move out/back and the movement is rather on the actual housing side.
As you unscrew it keep pulling the the oil filter housing back. Hope that makes sense. EDIT - OP3NAIR beat me to it on how to easiest remove that bolt. |
e90yyc2425.00 |
06-05-2018, 01:36 AM | #7 |
39
Rep 155
Thanks everyone!
Is there any DIY or youtube video that shows how to carefully remove the coolant hose without breaking anything? e90yyc - Thanks for posting the pic! OP3NAIR - A bit confused. If I remove that bolt using that ratcheting wrench, why do I need to then remove the hose? |
06-05-2018, 05:14 AM | #8 |
68
Rep 211
A variety of reasons:
1. You said you damaged the bolt. That would make me want to replace it. 2. You won’t get the new gasket to sit against the head with the bolt in there. You’d have to get it started with the housing floating, it just invites the gasket to shift before the housing seats. 3. You’re not gonna fit a torque wrench in there to tighten it back down with the water fitting in the way. |
06-05-2018, 08:51 AM | #9 |
718
Rep 1,753
NEVER do a micky mouse job on your car.. it will ALWAYS bite you later. Proper tools and dont skip steps.. take your time. I have removed that bolt without moving the hose. But you need the ratcheting wrench torx or 12 point. And very small length. Now you have to use some sort of vice type pliers with more room needed... not even sure how its gonna work
feuer4275.50 |
06-05-2018, 08:54 AM | #10 |
287
Rep 1,710
You can remove that without disconnecting the hose. Get a swivel head ratchet or box-end wrench. You'll need some M-A-N to break the torque since there isn't much room for leverage to break that torque.
DONE: Seibon CF Hood, M3 Rep, MSport rear w/DD CF Diffuser, M3 Rep Skirts, Seibon CSL trunklid, Forgestar F14 18s w/Michelin PSS, Eisenmann catback, AA Headers, BPC Stage 2, Charcoal Delete+revMotor+AFE Drop In filter
FUTURE MODS: LED headlights, CF rooftop, M3 Suspension Conversion, Dinan CAI Mod |
feuer4275.50 |
06-05-2018, 09:46 AM | #11 | |
Art Collector
2425
Rep 3,448
I could see trying to work with limited clearance if the bolt hadn't been rounded off yet, but it seems to me this might not work so well given OP's situation... Just an inkling -- I might be totally wrong. |
06-05-2018, 11:26 AM | #12 | ||
287
Rep 1,710
06-05-2018, 11:41 AM | #13 |
130
Rep 315
Home Depot has an inexpensive ratcheting wrench I successfully used for $7:
https://www.homedepot.com/p/Husky-10...10MM/202942588 |
06-05-2018, 11:49 AM | #14 |
Hoonigan
6848
Rep 3,000
Drives: '09 328i, '98 Wrangler
Ratcheting wrenches are your friend on this job. If the bolt is stripped I would try some vice grips or a tiny pipe wrench. Removing that plastic pipe will make it easier, but the plastic end breaks 99% of the time. It broke on my 06 and I replaced it with a metal end from ebay.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
Eagle1oh7286.50 |
06-05-2018, 11:50 AM | #15 | |
4276
Rep 9,206
06-05-2018, 12:48 PM | #16 |
39
Rep 155
Any video out there on removing the hose? Definitely don't want to break anything. Thanks all!
OP3NAIR Are these single bolts available to purchase online or would I need to purchase the entire housing? Pladi Totally agree. I wan't to do this properly. I will try with a ratcheting wrench torx and if it doesnt come out, I will remove the hose. |
06-05-2018, 03:42 PM | #19 |
65
Rep 218
RM European has the bolts. They are steel and I reuse.
I used 5/16 because the torx I have is a tad too long on u-joint. With Elring Klinger gasket. I do remove both hoses. Do need to pick up that all-aluminum connector on eBay, or at least keep a new hose that comes with a plastic connector. |
06-05-2018, 07:09 PM | #20 | |
Robot
1685
Rep 2,191
I also discovered that the hose end that connects to the plastic coupler is swollen, probably from the exposure to so much oil leaking from the filter housing gasket. It's not cracked but I don't trust it so I ordered a replacement hose. The previous owner of my car had a new water pump and thermostat installed last year and whatever shop installed it refilled the system using generic green coolant. I temporarily reinstalled the old swollen hose just so I can fill my system with distilled water , and drain and fill again to flush out all the old coolant and then I plan to refill with genuine BMW coolant. I'm fortunate that I have other cars to use while waiting to finish this project but I wish I had everything up front. If you want to minimize downtime do yourself a favor and order the aluminum adapter and a new hose at the same time |
06-07-2018, 12:56 PM | #21 |
Robot
1685
Rep 2,191
Once you get that coolant line out of the way you can probably tap a socket onto that bolt to remove it. Torx bolts are somewhat forgiving. I was trying a box end wrench and just barely started to strip the head, but after removing the coolant line I was able to tap a torx socket on there and used the ratchet to remove it.
Tags |
oil filter housing gasket |
