The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Help! Traction, abs, brake. Air conditioning won't work and turn signals
      06-03-2018, 04:14 PM   #1
Stephenj007
20
Drives: 2008 328i Metallic Silver
Hello, I recently installed a subwoofer in my car and had to power it to the battery and the fuse box. However, after wiring it all up. The car air conditioner won't blow air, the turn signals don't turn off automatically and the traction lights are on as if there is a bad abs sensor. Idk what to do, I unplugged the battery while installing the sub with built in amp. I had to also remove the trunk lining to run the cord through. What did i mess up?
      06-04-2018, 01:47 PM   #2
Bimmer Pleaser
Bimmer Pleaser's Avatar
205
Drives: nothing
Did try disconnecting thr subs? BMW electronics hate voltage fluctuations. What is your voltage when engine off and when on?
      06-04-2018, 03:11 PM   #3
e90yyc
Art Collector
e90yyc's Avatar
2425
Drives: 2007 328xi (GM-delete 6MT)
Pull the fuse from amp, get a baseline, and then go from there.
Another possibility is that your car is having an allergic reaction to the subwoofer, similar to when a human body rejects a transplant. The likelihood of this depends on how large the sub is, and what genre of music is usually playing through it.
Tags
abs, air conditioner, power, signal, subwoofer
