Do all e90s have play in the steering?
06-03-2018, 09:01 AM | #1 |
eBay Special
3066
Rep 3,028
Drives: E90 330xi
I've known of the hard steering which is fine, but I've noticed some play in the steering. I could be going 30mph and turn the steering wheel left and right (to a certain individual extent of course but there's a fairly large gap) and I'll still be going straight.
Tire pressure's fine, though I am due for some new tires. This sounds like an alignment problem, thoughts?
Common sense is a flower that does not bloom in everyone's garden
06-03-2018, 09:08 AM | #3 |
eBay Special
3066
Rep 3,028
Drives: E90 330xi
I think you're right, I'll check them when I have the chance.
06-03-2018, 09:44 AM | #5 |
851
Rep 2,793
All E90's can have play....I found a couple culprits,namely the steering linkage(U-joints) and the telescopic and tilting have some effect to the feeling of"play".
06-03-2018, 09:50 AM | #6 |
eBay Special
3066
Rep 3,028
Drives: E90 330xi
Could be.. Have any of you noticed when taking a right turn on an intersection (not a stoplight, just a regular 90 degree) that once you turn the corner you gotta turn the wheel left a bit to straighten it out?
06-03-2018, 09:58 AM | #7 | |
851
Rep 2,793
I find the car handles differently even based on weather temperatures and tire pressures...and to keep it at optimum feeling is a tightrope walk at best. Try adjusting these variables during times where steering doesn't feel right.....but only after eliminating the probability of damaged/worn components. |
06-03-2018, 12:28 PM | #9 | |
Crazy Frog
543
Rep 1,211
Driving 50 mph on the parkway, even very slight steering inputs will yield some directional change. The steering feel is nicely heavy, crisp, and responsive. The way a BMW should be!
06-03-2018, 01:09 PM | #11 |
eBay Special
3066
Rep 3,028
Drives: E90 330xi
06 w/ 130k, not the first owner. Wouldn't be surprised if the tie rods were a little worn. They might even be original
06-03-2018, 08:31 PM | #12 | |
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
06-03-2018, 08:40 PM | #13 | ||
eBay Special
3066
Rep 3,028
Drives: E90 330xi
