TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > NGK spark plug upgrade white smoke issue
      06-02-2018, 08:00 PM   #1
n0tm3
could-be bmw tech
n0tm3's Avatar
Drives: %E2%80%9809 335i
2014 435i xdrive  [10.00]
2009 BMW 335i  [10.00]
So today I replaced my OEM bosch plugs with some NGK's from BMS (1 step colder), gapped them to 0.022, and torqued down to slightly below 20ft-lbs (this was the lowest numeral on my torque wrench). Pretty sure the coils are all the way but the first cold start seemed slightly rough before calming down and the second startup after a few minutes I noticed a decent amount of white smoke coming out the back. Any ideas what I could have done wrong or need to do?
The old plugs were pretty dirty and needed to be replaced.
      06-02-2018, 09:14 PM   #2
320IN54
123
Drives: 2007 BMW 335i, 2021 BMW M2C
Was there oil in the spark plug well? If you have oil in there, it usually gets pushed in and ignited when swapping spark plugs.
      06-02-2018, 10:14 PM   #3
n0tm3
could-be bmw tech
n0tm3's Avatar
Cylinder 4 had a little on it, that might have been the issue. Drove the car down the street and it had stopped and idle'd better. I'll do a cold start tomorrow to see if i need to pull them and double check the gaps as well
