Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > N54 30FF after everything has been fixed
      06-02-2018, 11:15 AM   #1
vam0s
Drives: 335i
Where do I start... I have problem with building boost.
New vacuum lines (every single one) also tested to be working.
New boost solenoids
New turbos
New intercooler
New chargepipe
New bov
New valve cover and gasket
Every gasket is new regarding boost
New rb pcv valve.
Car can peak 18psi but drops towards the end radically to 13psi even when target is 18psi.
Im just so tired of this problem.. Help.
Theres one log I just took:
21https://datazap.me/u/vam0s/log-15279...og=0&data=3-21
      06-02-2018, 11:30 AM   #2
E92booost
Drives: E92 6 speed 335i
Change your map sensor
Gv
      06-02-2018, 11:34 AM   #3
mweisdorfer
mweisdorfer's Avatar
Drives: 2007 Black/Black 335i e90
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
New boost solenoids
New turbos
New intercooler
New chargepipe
New bov
New rb pcv valve.
21https://datazap.me/u/vam0s/log-1527953381?log=0&data=3-21
Have you been over every connection and double checked them ?
      06-02-2018, 12:20 PM   #4
vam0s
Drives: 335i
Yes, I re tested everything after changing everything to brand new.
Also map sensor is new.
      06-02-2018, 12:25 PM   #5
Silent9n54
574
Drives: 2007 E92 335i
as far as i know no tune keeps 18 psi all the way to red line unless you have aftermarket turbos, they all taper off to 12-13 close to red line
and your wdgc is already at 100% at 4900rpm ...boost leak somewhere ?? turbos are working OVERTIMEEEE at 100%
      06-03-2018, 05:35 PM   #6
vam0s
Drives: 335i
Im aware theres a boost leak thats what im trying to figure out..
Here's a log with mhd E40 map https://datazap.me/u/vam0s/log-15280...=0&data=3-5-21
      06-04-2018, 10:41 AM   #7
mweisdorfer
2008 bmw x5  [0.00]
Here's a log with mhd E40 map https://datazap.me/u/vam0s/log-1528065231?log=0&data=3-5-21
Did you check the connections to the inlets? If you still have OEM, the connection is pretty flimsy. It literally just sits in there with a gasket. There's no banjo type clamp there to secure them to the turbo.
      06-04-2018, 04:00 PM   #8
vam0s
Drives: 335i
How does inlets affect boost leak? I tried to pressurize the car but the rear inlet started leaking at the end even when i tried to keep it with hand.
      06-04-2018, 05:18 PM   #9
mweisdorfer
2008 bmw x5  [0.00]
That's air going into the turbo. If the connection isn't solid, that's a leak in the amount of pressure that can be made.
      06-04-2018, 09:36 PM   #10
mad1stgen
Master Wagon Builder
mad1stgen's Avatar
409
Drives: 2015 F wagon S55/6MT
That doesn't make any sense. Inlets have absolutely zero impact on 30FF issues.
      06-05-2018, 03:18 PM   #11
vam0s
Drives: 335i
One thing ive noticed is that i get quite a lot of Oil in the charge pipe but where does it Come from? I also tried wastegates 100% shut mechaniclly and still 30ff
      06-05-2018, 03:28 PM   #12
srey
srey's Avatar
220
Drives: 2007 E90 335i 6mt
Oil in the charge pipe is coming from your turbos. A little bit is normal. A lot means leaky turbo seals. If it's not the wastegates then it must be a leak somewhere else. How did you mechanically shut the wastegates and keep them shut? With a JB4? That doesn't necessarily mean they are completely shut and sealed. You might have worn wastegates that don't seal or faulty boost solenoids or actuators that don't close the wastegates. Have you used a hand pump to check the wastegate and actuator function?
      06-05-2018, 03:50 PM   #13
vam0s
Drives: 335i
I have new turbos. Also I double checked that wastegates have been adjusted/installed right. I used hand pump to mechaniclly shut the wastegates. Also solenoids are brand new and tested.
      06-08-2018, 02:50 AM   #14
vam0s
Drives: 335i
Got the car working.. Car had sucked dci so deep it couldnt get Any air.. But now after driving 500km turbos are broken AGAIN!
      06-08-2018, 07:27 AM   #15
mweisdorfer
2008 bmw x5  [0.00]
Did you check to see if the turbo actuators are holding pressure?
The oil in the charge pipe is from the PCV system. The only way to reduce or eliminate oil on the intake system is to get a Rob Beck PCV valve and a catch can.
      06-08-2018, 06:03 PM   #16
vam0s
Drives: 335i
Yes I did check them even tho I have new turbos. I also have rb pcv and catch can. Rear turbo broke again.. Axle moves alot..
Oil lines for turbo were clean. Any ideas why rear turbo keeps breaking?
Sick of this.. Sucks even more that there Isnt Any local People with real knowledge about these cars.
      06-08-2018, 06:22 PM   #17
mweisdorfer
2008 bmw x5  [0.00]
Which turbos did you get ?
      06-08-2018, 07:34 PM   #18
halik008
58
Drives: e90
If you choked off your turbos with poorly installed DCIs you likely pulled a lot of oil thru the seals from the resulting vacuum.
What are the turbos you bought? OEM or something else?
      06-08-2018, 07:36 PM   #19
IllSic_Design
IllSic_Design's Avatar
Drives: 09 E92 335i
Originally Posted by halik008 View Post
If you choked off your turbos with poorly installed turbos you likely pulled a lot of oil thru the seals from the resulting vacuum.
I concur. Could have killed the turbo(s) easily if they were trying to do their job with blocked off inlets/air supply.
      06-09-2018, 01:50 AM   #20
vam0s
Drives: 335i
I got oem turbos. When the dci's had been sucked in and I was getting 30ff
I probably drove about 10k till I suddenly lost all boost and then got a huge
whine from turbo + smoke. Now I drove 200km with dci still sucked in then fixed it and another 300km and the turbo is now gone.
Turbo is doing now same as Last time, blowing huge amount of Oil to the exhaust side thus making a huge smoke..
      06-09-2018, 08:35 AM   #21
halik008
58
Drives: e90
Brand new OEM turbos from dealer? or brand new "oem" turbos from mainland china?
      06-09-2018, 09:13 AM   #22
vam0s
Drives: 335i
OEM dealer.
