Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > No Heat
      05-30-2018, 09:01 PM   #1
lowrydr310
Robot
1685
Drives: 2006 330i, 2007 E93 335i
No Heat
I searched and read numerous posts about the issue of no heat, but couldn't find any definitive answers.
I have no heat in my car. Not that I need it, but there are a few days in January and February where it would be nice to warm up a bit. I've read about clogged heater cores or improperly functioning heater control valves but didn't see any real solutions.
My engine is up to operating temperature (205+), the selector between the vents is on the red setting, temperature is turned up all the way, AC is off, and the blower moves a nice volume of air, yet it's the same temperature as the outside air.
The coolant was topped off and not low, no leaks in the system (not before tonight when I replace the oil filter housing gasket and the coupler from the thermostat hose to the cylinder head split). My radiator and thermostat were replaced in November so it's not likely the thermostat is bad. My car gets to operating temperature somewhat quickly and maintains normal temperatures (viewed in INPA).
How do I start diagnosing this?
      05-31-2018, 12:24 AM   #2
ptpending
ptpending's Avatar
456
Drives: e91
did you ever replaced you engine pump ?
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes.
      05-31-2018, 01:29 AM   #3
Big Mexican Women
102
Drives: 2011 528i
clogged heater core. expensive to fix. living in LA I wouldnt bother
      05-31-2018, 07:08 AM   #4
e90yyc
Art Collector
e90yyc's Avatar
2425
Drives: 2007 328xi (GM-delete 6MT)
If you’re feeling brave and patient, here’s another members excellent DIY:
https://www.e90post.com/forums/attac...6&d=1331031264
      05-31-2018, 09:44 AM   #5
ptpending
ptpending's Avatar
456
Drives: e91
it is possible to wash out heater core without removing heater
simply disconnect heater pipes from engine compartment, connect external pump with reservoir with prepared mix and this can help
my friend on e83 with N52 did so and it helped
      05-31-2018, 09:46 AM   #6
e90yyc
Art Collector
e90yyc's Avatar
2425
Good advice.
Silly question, but what causes this? Corrosion in system? Impurities, or buildup of some kind?
      05-31-2018, 11:44 AM   #7
Big Mexican Women
102
Drives: 2011 528i
Originally Posted by e90yyc View Post
Good advice.
generally caused by corrosion. OP, what did you use to top-up your coolant with?
      05-31-2018, 12:43 PM   #8
lowrydr310
Robot
1685
"Please allow for an entire weekend to get this done (even with a helper). You never know if/when you will run into a snag. It took me approximately 16 hours to get this done and I had a helper."
Yeah.. not looking forward to that. I'll try the flush first.
I was afraid this question would be asked. I didn't add any coolant as it wasn't low, I meant that it was full and set at the appropriate level in the expansion tank. The previous owner of my car had some cooling system work done last year and there is green coolant in the reservoir. The repair receipts have no specific indication of what coolant was added. I see where you're headed with this, mixed coolant types could have caused corrosion or a clog.
I'll be losing a bit of coolant when I replace the coupler from the head to the thermostat, so I will first try flushing the heater core. At the same time, I think I'll flush the entire system with distilled water and then replace with the proper coolant.
      05-31-2018, 02:03 PM   #9
ptpending
ptpending's Avatar
456
Drives: e91
Good advice.
if you perform such flushing as i described before you'll see what it can be, because i truly do not understand how aluminium core can corrode when using bmw coolant
      05-31-2018, 02:21 PM   #10
e90yyc
Art Collector
e90yyc's Avatar
2425
Agreed. Sounds like a not-so-fun job.
Sounds like PO used the wrong coolant. Good call on the flush. Hope it helps.
Option 2 would be to find some heated seats (or just seat: fuck the passenger) and swap them in. I'm sure it'll be impossible to find them since you're in Cali, but I once had blower motor issues when temps were hovering around 0 degress F, and the heated seat made a world of difference. I'm sure with the temps where you are, this might be enough to stay comfortable.
Ghetto, sure, but it would help and take no time compared to doing the core.
      06-01-2018, 09:57 AM   #11
robthewrench
266
Drives: 11 E90 335i
Good advice.
Corrosion. All coolant types come with corrosion inhibitors to slow the rate of corrosion of the metals (iron / aluminum) in the cooling system. The problem is that these inhibitors get used up / worn out over time. This is one of the reasons a coolant change is part of the maintenance schedule.
You could put perfect BMW coolant in the system, but if you don't change it in the next 10 years, you'll start having corrosion issues. Change your coolant every 5 years or so.
In addition to corrosion, oil contamination is fairly common on the e90 platform due to the leaking OFHG.
As a note, I don't recommend a flush as this can loosen build-up in the block and send it into the heater core, where it will plug up the heater core.
bone stock
      06-02-2018, 06:12 AM   #12
GMe90
GMe90's Avatar
356
Drives: 2007 328i Coupe, ZSP, Premium
2003 BMW Z4 3.0i  [6.00]
2007 BMW 328i  [10.00]
I have the same issue in my car. I had the dealer do the flush (which is apparently the recommended fix, and it didn't really work). Probably the only remaining option is to replace the heater core, which is too expensive. So I rely on my heated seats. While the auto heat function does not work, after the car engine heats up, if you mess around with the controls a little bit (crank up the heat manually and aim the air to your face), you can sometimes get some warm air to come out of the vents. Not much, and it typically does not work when the temperatures are really low (in the teens). I also bought a small portable car space heater. It's not great but can keep your hands warm at least. If it's really cold outside, I just keep my coat on while driving.
I am curious to see if this heater recall will improve anything.
      06-13-2018, 11:27 AM   #13
lowrydr310
Robot
1685
UPDATE
While replacing the hose from the thermostat to the head, I did two drain and fills using just distilled water (to get all the old green coolant out so I can fill the system with the correct BMW coolant). I now have some heat! It isn't as hot as it should be, but there is definitely heat.
Perhaps there is hope and a proper heater core flush can resolve it.
      06-13-2018, 12:55 PM   #14
330istocknot
185
Drives: 330chino
I had this problem on my e46, took out the heater valve and cleaned it up! Heat started coming out after that. I made a video long ago, you can see here
