Understeer after new suspension
05-28-2018, 09:09 AM | #1 |
43
Rep 450
I recently went through a suspension overhaul and now getting horrible understeer on twisty roads and corners. Most noticeably after getting new tires. Previously had Hankook V12s.
Here's what I did so far. Koni FSD with front lowering perches and new top mounts Sway bar endlinks and bushings. Front only M3 TRW control arm and wishbone Front M3 TRW guide rods upper and lower Rear New Michelin PS4 tires 265/35/18 rear and 235/40/18 front.[IMG][/IMG] Alignment specs attached. I am thinking I do need stiffer sway bars and looking Eibach kit which includes 28mm front and 15mm back. Should I even bother with rear sway bar or just upgrade the front to e93 28mm?. Any other suggestions?. |
05-28-2018, 11:23 AM | #2 | |
102
Rep 343
I would recommend Eibach, yes. your Koni suspension is not as good as something like Bilstein, but it should suffice. lastly, you need to adjust your alignment. get some camber plates for the front axle and dial in your front negative camber just a little more. if you like to push your car hard, around -1.5 should be good. this will help increase your front-axle grip. what sort of wheels are you running? if your new tires are not run-flats, you may want to get an alignment to compensate for that as well. non run-flat tires require a different alignment for optimal performance. |
05-28-2018, 09:40 PM | #3 |
43
Rep 450
I went Koni for a comfortable ride. Atlanta freeways are very uneven and not paved.
My front camber is maxed out with alignment pins removed. Wheels are stock style 197s. Tires are Michelin PS4. I just bought e92 M3 sway bar set locally. Will install next week and report. Thanks |
05-29-2018, 03:51 PM | #4 | |
23
Rep 38
07-03-2018, 10:51 AM | #5 |
43
Rep 450
Update: installed front e92 M3 sway bar and felt some improvement. Now I can feel the rear is a little loose. Next week I'll install rear sway bar and subframe inserts.
