The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > funny squeak going over some bumps, please help out
      06-16-2008, 02:09 PM   #1
hov333
Armenia
63
Drives: 2016 M5
A few days after having a local shop install my kw v3's i noticed a highpitched, metal on metal type of squeak when driving over mild bumps. Its coming from the front passenger side. I took the car to a local bmw service shop to get an alignment done and had them check out the problem. They verified that its NOT coming from any of my suspension components but rather something in the back of the engine bay may be loose. They said they would need the car for the whole day to take things apart to find the problem.
Has anyone encountered a problem like this after having suspension work done on the car? or just in general seen this problem?
*it will only happen a 2-4 times each time i drive the car so its not a constant squeaking either.
      06-16-2008, 05:04 PM   #2
hov333
Armenia
63
Drives: 2016 M5
bump
      06-17-2008, 05:48 PM   #3
dakine
23
Drives: mineral white e92 M3
when my car was brand new, it had this kind of sound. I was kind of pissed and was going to take it back to the dealer, but it went away in 2 days... i think it was the springs settling in or something.
      06-18-2008, 08:49 AM   #4
hov333
Armenia
63
Drives: 2016 M5
bump. My car has been doing this for a few weeks now already and it doesnt happen on every bump. I've been told its not my suspension by an independent shop which I had check the car
      06-18-2008, 10:21 AM   #5
danniexi
danniexi's Avatar
3056
Drives: 2022 F97 X3M Comp LCI
well, if the dealer AND an independent body shop say its not coming from the suspension, i say just take it to the dealer again and let the diagnose the problem. squeaks are always an annoyance, even if it happens occasionally. hope it works out for ya.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE
BMW MY08 E92 335XI - GONE
BMW MY06 E46 325XI - GONE
      06-18-2008, 10:23 AM   #6
hov333
Armenia
63
Drives: 2016 M5
yea i'm thinking of just taking it to the dealer eventho I'm worried they may mess up something else, i hate going to them.
      06-23-2008, 03:18 PM   #7
catcher22
294
Drives: 2008 335xi Coupe
I have a similar issue when I go over bumps. I can hear a squeaking when I go over larger bumps, and it still happens at slow speeds (under 10mph). If my springs don't compress (if I go very slow over the bumps), I don't hear it. The squeaking sounds like it's coming from the suspension because the number of times it squeaks is in relation to how many times my car goes up/down from going over the bump. Haven't gotten it checked out yet, but I'm in the same boat.
      06-23-2008, 03:19 PM   #8
hov333
Armenia
63
Drives: 2016 M5
wow interesting that we both have 335xi coupes as well. are you on stock suspension?
      06-23-2008, 07:13 PM   #9
Andrew@ET
181
Drives: Red thing
i get this as well 328i coupe non x
      06-23-2008, 07:22 PM   #10
jettie1767
142
Drives: '23 BMW i7 xdrive60
Yes, squeaks from time to time over bumps. Stock suspension for now.
      06-23-2008, 10:31 PM   #11
Two Sheds
10
Drives: Mini Cooper JCW
Is it cold where you are at the moment? My car (330xi) was squeaking over speed bumps during winter and I kept thinking about taking it in, but never did. Now spring has come and all the snow has gone no more squeaking!
      06-23-2008, 11:21 PM   #12
hov333
Armenia
63
Drives: 2016 M5
wow funny, when the car hasn't been driven for a day or so, or even when i drive it in the morning it does it like crazy but then it settles down and does it much less often after driving the car throughout the day. i still want to know what that sound is tho. I have coilovers on the car and dont want to deal with the dealership telling me it has to do with those. As we know now, some of you guys are hearing it too and you're stock, goodluck convincing the dealer tho. please update this thread if you guys have any updates
      06-24-2008, 08:10 PM   #13
hov333
Armenia
63
Drives: 2016 M5
bump
      06-25-2008, 02:25 PM   #14
AWD Addict
Chief Executive
AWD Addict's Avatar
300
Drives: 2008 335xi 6spd Coupe
2008 335xi  [0.00]
Based on that, it sounds like a bushing is just a little noisy.
      06-25-2008, 02:44 PM   #15
hov333
Armenia
63
Drives: 2016 M5
i wish it was "just a little noisy" its not the bushing we checked. its a high pitched, metal on metal type of sound, not at all a rubbery squeeking. may be something with the brake rotors
      06-25-2008, 05:14 PM   #16
equ
22
Drives: Croc & toaster
Here's an idea. My s4 had a similar noise. It was the brake calipers. The test is going over a bump that produces a squeak with your foot lightly on the brakes, if it gets quiet it has to do with something rattling behind your brakes. Supposed to be harmless.
      07-01-2008, 02:24 AM   #17
kumiorava
kumiorava's Avatar
Finland
27
Drives: e84 X1 xDrive23d A X-Line 2010
2008 e91 330xi  [0.00]
I have the exact same thing with my e91 330xi '08 w KWV3 setup! Very loud squeak metal on metal or rubber on metal kind of noise. It doesn't happen always when driving over a bump, maybe every other bump or so.. Very annoying. Local BMW dealer checked it out, everything was fine in the suspension. I have had this problem since January 2008 when it was very cold here in Finland and the same thing goes on now as it is summer and warm. I'll try the braking trick, but it is hard to tell whether it helps or not, as the noise doesn't come always..
X1 xDrive23d A / X-Line / Space Grey / Dakota Beige / OEM 18" Y-spoke 322 w 225/45/18 Potenza RE 050A / Eibach Pro-Kit / WWW.NIITTYLA.COM
      07-01-2008, 08:44 AM   #18
hov333
Armenia
63
Drives: 2016 M5
^ please keep me informed if you find anything, i will do the same. I will be going to the dealer in about a week to have them check it out.
      07-02-2008, 12:04 AM   #19
kumiorava
kumiorava's Avatar
Finland
27
Yes, sure! Hope that the problem can be solved..
      07-10-2008, 12:33 AM   #20
hov333
Armenia
63
Drives: 2016 M5
any updates yet? haven't had time to visit the dealer yet
      07-10-2008, 06:51 AM   #21
sapperelite
Drives: 07 335XI, 03 Wrangler Sport
I don't get the squeak but I do get a clunking sound from my stock 335 XI at times. I used to live in an apartment with a parking garage and when coming up the steep hill at an angle, I would get a clunk coming from the engine compartment. The car arrives on the 19th and will go to the Dealer for services, I will post any results.
Anyone else get this same sound?
      07-11-2008, 09:11 PM   #22
nospleeny
21
Drives: 2012 528xi
When I go over bumps... like sewer caps.. I hear like some squeeking sounds... but these squeeking sounds sound like wooshing sound like the gas shocks compressing.
