05-24-2018, 11:18 AM | #1 |
628
Rep 2,808
Thinking ahead for winter wheels
Hi, was going to Consider picking them up now in case I can get a good deal on them. From what I've been reading, Because of the new upgraded brakes, 18 inch wheels will not fit on this car.
Is it safe to say that any 19 inch wheel that fits the existing M2, in terms of width and offset, would fit the new Comp model too? |
05-24-2018, 11:29 AM | #3 |
this is the way
18348
Rep 8,553
You should be fine. We know the 437M and the 763M both fit with the BBK. Only thing you need to possibly worry about is caliper clearance with the spokes. That said you're jumping the gun a little prematurely getting winter wheels, don't you think? You have at least 1/2 a year to figure things out, why rush it? Also, not sure how stock is in Canada, but in the states most winter tires aren't even available right now. They don't start to show up until later in the year, around September/October. If you get winter tires now they might be old stock left over from last season and your selection will be very limited.
05-24-2018, 02:08 PM | #4 | |
628
Rep 2,808
The tire shouldn't be too old in 6 months, if it's This year's stock, but worth considering, as who knows, maybe it's a 2 year old tire they're selling me. I'll wait until they officially confirm the wheels for the 19 M2. The deal now that I looked it is not exactly a smoking deal anyway… Thanks for saving me From possibly making a bad purchase! |
05-24-2018, 02:15 PM | #5 |
this is the way
18348
Rep 8,553
It depends on the wheel and how far the spokes intrude into the wheel barrel. A safe rule would be if it fits the M3/4 with CCB's, it will fit the M2c with the BBK. Just beware of the offset (wheel rub) as the M3/4 have larger wheel wells.
05-24-2018, 02:33 PM | #6 |
Rep 11
M2 is a great winter car, works great in swedish winter
I have 19" AEZ with Nokkian Hakka 8 245/35 19. |
seis-speed2435.00 ZPrime611.50 |
05-24-2018, 02:37 PM | #7 |
I used to be conceited, now I'm perfect.
571
Rep 1,826
Drives: 2018 M3 CS
These wheels are 18" from an M3 and they fit fine. Albeit my car is a 2017.
2018 M3 CS - Alpine White l l
"I used to be conceited. Now I'm perfect" |
05-24-2018, 05:18 PM | #8 | |
628
Rep 2,808
Those I can't even seem to buy here. And Nokian tires are In general hard to find in Canada. The closest I found Were the Hakkapeliitta R2, and they cost 1/3 more per tire than the awesomely rated PA4's! They cost $480 CDN each compared to $350 for the PA4. |
05-24-2018, 07:23 PM | #9 | |
628
Rep 2,808
Hope that's not what we end up using as winters! On the other hand, when I do a search for 19's for the M2, and filter for lower offsets like 29, some 8 inch wide wheels show up. I would have thought that an 8 inch wheel is too narrow for a 245 tire, no? Would these fit in your opinion? They're 8.5 inch wide and have a low offset of 30 mm. The only thing is they're 0.5 inches narrower on the front, but 1.5" narrower on the rear, compared to stock. Could that pose a problem? I'm not buying them now, just trying to figure out how to go about it… THESE When I plug it into Willtheyfit, it says for the front and rear respectively: Compared to your existing wheel, this new wheel will have an inner rim which is 5.4mm further away from the suspension strut. The outer rim will poke out 7.4mm less than before. Compared to your existing wheel, this new wheel will have an inner rim which is 29.1mm further away from the suspension strut. The outer rim will poke out 9.1mm less than before. Which seems good to me, as in both cases, the wheel is moving AWAY from the suspension, no? Or does that have no bearing upon how much clearance there would be between the calipers and the wheel? I thought that's determined by the offset, which seems okay to me. |
05-24-2018, 07:33 PM | #10 |
55
Rep 817
APEX has had a winter wheel and tire group buy for M cars the past two years.
I picked up a 18" set last fall. A number of different finishes available and two tire choices. http://f87.bimmerpost.com/forums/sho....php?t=1423763 Keep an eye on the wheel and tire forum in September. |
Lotus99628.00 ScreamingChicken94.50 |
05-24-2018, 08:11 PM | #11 |
4143
Rep 6,926
05-24-2018, 08:12 PM | #12 | |
this is the way
18348
Rep 8,553
05-24-2018, 09:05 PM | #13 | ||
634
Rep 1,083
Having said that my oem m2 winter wheels came with Michelin pa4 and they are also excellent. Tried them out for a bit this spring in calgary. |
05-24-2018, 11:21 PM | #14 | |
628
Rep 2,808
https://www.apexraceparts.com/wheels...wheel_model=46 As you and others pointed out in that thread, paying $600 CDN in taxes, brokerage and duty on top kind of negates the savings... Wonder how it will work out this year. This morning I had placed an order for a set of these, then backed out. Their price seems amazing, at $200 CDN each. I know they're not Apex quality and looks, but good enough for me. If it works out this winter once all the specs are sorted out, that seems like half the cost of the Group Buy. https://pmctire.com/en/wheels/rssw/s...deport-45.tire And here's the total I would have paid, which includes no duty and brokerage, and savings of PST, because they're shipping from Quebec. If I do the Group Buy, I'll try to get them shipped across the border at least to save a bit. . |
05-25-2018, 01:12 AM | #15 | |
628
Rep 2,808
For the fronts, as I guessed, says they are 1 mm closer for brakes. https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm For the rear, it says "100% clear (leaves even more room than OE)" https://www.wheel-size.com/calc/?whe...cl=30mm&sr=0mm I'll still wait it out, as you suggest, but hoping we don't end up having to spend $500 a wheel for winters and something basic like the above works... |
05-25-2018, 02:17 AM | #16 |
1784
Rep 4,522
Realoem/M4 GTS shows OE 19" style 641m as being compatible with std fit BBK on GTS so stands to reason 641m work with M2C MPBBK...
http://www.realoem.com/bmw/enUS/show...diagId=36_2031
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
05-25-2018, 10:03 AM | #17 | |
628
Rep 2,808
8,5JX19 ET:27 2 36102284907 only for front axle 9JX19 ET:29 2 36102284908 only for rear axle As a staggered setup. The front should be tighter with the narrower wheel, So I'd think the key is that as long as it's an 8.5 wide wheel, with an ET of 29 or less, it should be fine all around. I'm thinking that because the OEM fronts are 29 offset, and rears are 40. . Last edited by Lotus99; 05-31-2018 at 08:07 PM.. |
05-25-2018, 01:35 PM | #18 | |
84
Rep 91
05-25-2018, 02:20 PM | #19 | |
628
Rep 2,808
I priced out the same thing Yesterday from Tire Rack and it came to $2400 US, all in, to my door. |
05-25-2018, 02:34 PM | #20 |
571
Rep 1,826
Drives: 2018 M3 CS
Be careful with those cheap wheels. They bend and crack with the slightest of ease. They're cheap for a reason.
05-25-2018, 02:40 PM | #21 |
7346
Rep 7,302
Possibly, but I've had good luck with really cheap Tire Rack Sport Edition wheels on my Z4M and Mazda 3 in the winter, and that's driving around NY/NJ area full of potholes. Granted, I am running narrower / higher profile than stock. They suck but I have not bent one yet.
Kid Eh570.50 |
05-25-2018, 05:51 PM | #22 | ||
1784
Rep 4,522
Caliper clearance is the issue and aftermarket wheels maybe less bbk calliper friendly.
