Car shaking on startup
05-22-2018, 10:22 PM | #1 |
8
Rep 77
Hi Everyone,
New here, I've read many posts on this forum and some of them sound similar to what I'm experiencing but nothing really matches 100% Backstory, recently picked up an 07 e92 328i with 160,000 KM, had it inspected prior to purchase and everything came back great. Well now for the past couple weeks on startup, the car will shake, and not a little shake it's very noticeable. I've spoken with a few other people who have or have had BMW's and they said they haven't experienced this before. The car will start and hover around 1000rpm then slowly decrease and that's when the shaking starts, almost feels like a side to side movement. If I hold the revs above 1000 it doesn't occur but if I let them drop then it comes back. Once I start driving the car, the shaking stops. The RPM's don't bounce around or fluctuate like I've seen other people experience when idling This only seems to occur when it's a cold start or if the car has sat for a few hours, if I stop the car after a period of driving and start again there's no shaking. There's nothing noticeable under acceleration or during normal stop and go traffic As a start, I've ordered new NGK spark plugs as I can't get the recommended ones locally Thanks for taking the time to read |
05-22-2018, 10:25 PM | #2 |
Crazy Frog
543
Rep 1,211
Change plugs, and coils, clean out the MAF sensor.
Is the car throwing any codes? SES light or CEL on?
05-22-2018, 11:00 PM | #4 | |
356
Rep 928
Drives: 2007 328i Coupe, ZSP, Premium
05-22-2018, 11:05 PM | #5 |
Crazy Frog
543
Rep 1,211
Change the coils too, grab a can of CRC MAF sensor cleaner and blast clean the shit out of the MAF sensor. Then start it up and test drive it.
05-23-2018, 12:29 AM | #7 |
729
Rep 1,815
I am going to bet changing your coils and plugs will do nothing for you. The symptoms you have described fit the description of leaky injectors.
Cold rough start in the morning or after sitting for a while. Yes Car smooth out after revving a little or running for a minute or two. yes Get an OBD2 code reader before you buy anything else. When you run the diagnostic you will have a misfire on one of the cylinders. Swap that coil with the coil from another cylinder and then clear the codes. The next time you experience the issue, check the error codes again and most likely it will be the original cylinder again. If you have BMW change out the injector change them all at the same time. This is just preventative but it will save you the money later if another fails.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
Drifter2090909.50 |
05-23-2018, 11:33 AM | #10 |
2188
Rep 5,002
HOW do you know not throwing codes? Get BMW specific code scanner or you’re just wasting time.
Sounds like could be vanos solenoids. Even light misfires throw codes when it’s a coil/spark plug |
05-23-2018, 12:21 PM | #11 |
521
Rep 1,485
i would do coils and spark plugs. i agree with coffeebean, the n52 isn't known for leaky injectors.
Probably start with cleaning the MAF first, since its the cheapest. Given your mileages new plugs and coils will help with your mpg and performance anyways. |
05-23-2018, 12:28 PM | #12 |
964
Rep 3,854
Drives: 330i, 135i
if you havent replaced the coils and plugs yeah its a good step, but you could have just dumped a bottle of Techron fuel injector cleaner to start...
05-23-2018, 01:21 PM | #13 |
Robot
1685
Rep 2,191
I just went through a similar issue with a similar car (06 325i with the same N52 engine). My car would sometimes start up fine idling around 1000 RPMs and then after it warmed up the RPMs would drop and it would shake violently with the side to side shaking you describe.
If you don't have any record of the plugs or coils ever being changed, then I highly recommend starting there and replacing them first, that way you can easily rule those out if it ends up being some other issue. However, those symptoms sound exactly like bad coils and/or plugs. When coils begin to fail, they may not necessarily throw a code right away. In my case I had several coils starting to go bad intermittently and when I got the misfire codes it was difficult to diagnose exactly which one was bad since I had about three different ones intermittently failing. I ended up replacing all six coils ($20 for Bosch, $27 for Delphi which are apparently better but I'm cheap so I stuck with Bosch) and six spark plugs (NGK Iridium LFR6AIX-11) and it resolved my issues. If you're doing the work yourself, just make sure the electrical connectors are seated on the coils properly. Don't rely on just the lever on top of the coil to pull the connector in, push the connector in all the way as you push the lever down. |
05-23-2018, 01:49 PM | #14 |
729
Rep 1,815
Good call, mine happened on my n43 118i (direct injection).
I would like to recall my bet.
05-23-2018, 02:21 PM | #15 |
8
Rep 77
Thanks everyone for the responses, glad we can rule out the injectors for now
Perhaps since I'm not used to BMW vehicles, they can throw codes without generating CEL? |
05-23-2018, 02:33 PM | #16 |
964
Rep 3,854
Drives: 330i, 135i
05-23-2018, 03:00 PM | #17 |
203
Rep 437
i had a similar issue mine was the 02 sensors. I just keept resetting adaption values in inpa and eventually it went away.
idle issues would sometimes come back but i have several things i have to replace to fix it like like ccv hoses and 2 new 02 sensors 1 vanos solenoid and fuel tank vent valve just so i can pump gas without the damn fuel nozzle shutting down on me every 2 secs. |
05-23-2018, 03:05 PM | #18 |
Crazy Frog
543
Rep 1,211
Return that OBD2 reader to Amazon, it's useless for our cars. Get a BMW specific scanner such as the Foxwell NT510 for BMW or the newer NT520 for BMW. If you're tight on cash and are only looking to read BMW specific codes, get a Creator C310 for BMW. The Creator is a little cheaper, does the same code reading as the NT510/520 but it doesn't have other features like battery registration and airbag reset.
05-23-2018, 03:07 PM | #19 | |
2188
Rep 5,002
Despite what a lot of people are saying in here the coils in these cars are pretty good. It's normally a waste of money to replace them all 'just because'. They mostly fail in high load situations which is not what you are describing. Their failure mode does vary, however, so the only way to really move forward without guessing is to get a BMW specific scanner. There are lots of them, Carly, Foxwell, etc.. If you are handy with a computer and programming there are also DIY solutions that mimic BMW software called ISTA. The most reliable way to fix your car is to start with a code scanner. |
05-23-2018, 09:27 PM | #21 | |
97
Rep 119
Drives: 325xi Touring MT X1 x28i
my problem cleared up immediately after installing the new coils. I think I could have gotten by with changing just the offending coil but figured it may be time as the car has 163k miles. I purchased the car last year. Symptom wise there are a few differences. The shake on my engine did not clear up even after idling for several minutes. Also the engine revved very sluggishly and rough at all speeds. But if you can diagnose the problem before acting that is the best approach, and one I would normally take. However I had been planning to replace the coils and plugs for some time anyway, so I felt I had nothing to lose. |
05-24-2018, 01:46 AM | #22 | |
2188
Rep 5,002
http://blog.uobdii.com/inpa-vs-ista-...r-inpa-easier/ |
