Tail light malfunction
05-21-2018, 11:23 PM | #1 |
eBay Special
3066
Rep 3,028
Drives: E90 330xi
[IMG]undefined[/IMG]
I just noticed my tail lights are acting up. The bars that stay on in the middle is out on one side while the brake light is on. I'm quite confused. I moved the light housing and it came on so I believe there's a wire acting up. There doesn't appear to be any damage to the wires from the outside. Do I strip the wires to see whats up?
Common sense is a flower that does not bloom in everyone's garden
05-22-2018, 10:03 AM | #2 |
204
Rep 525
The computer is supposed to do that if you have a tail light out. It brings the brake light on at a dimmer setting to compensate for the lost tail light.
It is pretty common for a burnt-out bulb to have a loose filament. When you whack the housing or remove and replace the bulb, it may work for a short while. Just go buy a new bulb. The computer will automatically use the new bulb and turn the brake light function back to normal. |
05-22-2018, 10:46 AM | #4 |
eBay Special
3066
Rep 3,028
Drives: E90 330xi
The bulbs looked pretty old so I replaced all of them, same problem. Maybe I need to clear the code for that light? I'll try that now.
05-22-2018, 11:09 AM | #7 |
eBay Special
3066
Rep 3,028
Drives: E90 330xi
Just saw that all my tail lights are throwing codes now, I heard it was because it was a different type of contact than OEM? I believe I replaced them with Sylvania Silverstar or something among those lines. The license plate lights are good as well.
Edit: Went to tension the tabs and saw the bottom right brake light hole is broken all the way to the middle bulb. Could this be a reason?
05-22-2018, 11:59 AM | #8 |
58
Rep 494
Could be broken wires in the trunk rubber boot. Maybe something like this . I had same thing in my car, it all started with random light faults, which would go away then come back until they became permanent.
05-22-2018, 12:11 PM | #9 | |
eBay Special
3066
Rep 3,028
Drives: E90 330xi
https://www.e90post.com/forums/showthread.php?t=683942 Perhaps it is this, in which I would need to strip some wires huh? |
05-22-2018, 01:04 PM | #10 | |
58
Rep 494
05-22-2018, 06:37 PM | #11 | |
eBay Special
3066
Rep 3,028
Drives: E90 330xi
Edit: After following the video I managed to get them to work properly. Thank you guys for the help |
