05-21-2018, 03:52 PM | #1 |
e90noob
1588
Rep 1,862
f30 USR Depo angel eyes headlights + DDM HID kit
do you have a f30 with halogen headlights? then you know how much they SUCK swapping the headlight probably makes the biggest difference in your car's appearance before and after photos had these USR depo headlights + DDM HID kit installed on my 2016 328i for a little over 1 year https://www.uniquestyleracings.com/i...roduct_id=1023 the headlights were purchased from USR in early 2017. it was after some of the earlier kinks were worked out and fixed this sale includes the USR headlights and the DDM HID kit (angel eyes + projectors, H7 bulb inner housing - meaning you can use your stock headlight connection) (you can see my original post after installation in the ongoing thread here http://f30.bimmerpost.com/forums/sho...274932&page=51) DDM plus can bus HID kit http://www.ddmtuning.com/Products/DDMPlusCanbus35W 35w 5500k No flicker, no error, no coding Auto headlight works fine my friend and I did the hard part for you already drilled a hole in back of depo headlight cover to accommodate the HID kit made sure the wires reach when installed it is a true plug-and-play upgrade (H7 bulb holder bracket thing included as well) i'm located in the Los Angeles area prefer local sale but willing to ship set aside a couple of hours with a buddy remove front bumper swap headlights zip tie the ballast to the frame ??? profit
2008 E90 M3 / LCI trunk + euro tail swap
Production date - 2008-04-22 Last edited by XKxRome0ox; 05-25-2018 at 11:35 AM.. |
05-23-2018, 02:06 PM | #2 |
e90noob
1588
Rep 1,862
never had any issue with water getting into the lights it's a pretty good tight seal in the back the wires are for the HID kit no broken tabs a little dirty that's it
Production date - 2008-04-22 |
