05-20-2018, 01:10 PM | #1 |
13
Rep 60
Upgrading brakes
After my last HPDE I feel like I need to upgrade my brakes. I'm considering EBC Yellowstuffs and Stoptech slotted rotors for the front, getting SS brake lines all around and upgrading the fluid to Motul 600.
I'd like to leave the rears on OEM pads and rotors as they are still covered by the maintenance plan. Does it make sense to just upgrade the pads in the front and keep the rears OEM? |
05-20-2018, 08:27 PM | #2 |
3074
Rep 5,577
Mixing pads on the track is common. But I don’t like it.
mazerrackham13.00 |
05-20-2018, 08:29 PM | #3 | |
1400
Rep 5,262
Keep the same stock rotors and just upgrade the pads, lines and fluids. I have the yellow stuff and they are pretty good I just leave them on for the track season and then switch back to stock at the end That way you can still get free pads and rotors from bmw |
mazerrackham13.00 |
05-20-2018, 08:49 PM | #4 | |
454
Rep 986
I like EBC Yellowstuff, they've got a good bite and pad life, but they sure are abrasive pads. They will wear out your rotors after a few HPDE's
The stock calipers/rotors are sufficient. Pads, lines, and fluid will help. If you still under warranty, just swap out your fluid.... Get some more free pads while you can lol They are decent for just doing HPDE's, but once you get past "novice" you'll want something with a little more initial bite and torque. Once you get into "Race" pads like Pagid or Hawk, you'll need new slotted rotors as most of them tend to out-gas. Quote:
mazerrackham13.00 danyosun7.00 |
05-21-2018, 09:12 AM | #5 |
250
Rep 281
1. You don't need new rotors, the stock rotors are great. Slotted doesn't make a big enough difference to prompt swapping out perfectly good rotors. Stock rotors are great and they last a very long time.
2. Yes, please change your fluid ASAP. I would do this first. You don't need the SS lines right away either. There's a chance you won't need them for quite some time. 3. Keeping the rears OEM is definitely an option. It changes the bias but that's not necessarily a bad thing. I tested carbotech XP20s on the track this week and forgot to bring my rear pads with me so I had to run the stock pads. No problem whatsoever and I may venture to say, I like it... Since I didn't have the rear track pads on hand to try them back to back, it's hard to say for sure though.
mazerrackham13.00 Anthony235715.00 |
05-23-2018, 10:23 AM | #8 |
3848
Rep 2,873
Great article, thanks. That vid of the shattering disc was cool, but also a bit sobering (at my last track day my instructor's rotors needed replacement at noon b/c they started cracking, and it made me wonder 'what would that look like if it let go while driving?').
05-23-2018, 10:28 AM | #9 | |
4516
Rep 8,942
I made a left the other day and hit a patch of grime on a wet road in the X5 and the back end came around on me, sending me towards a parked car. Didn't even think about, fixed it, and was happily on my way with a story to tell. If things are gonna go to shit the track is usually a good place to learn and not hurt yourself. I think something like the teen driving car control course should be mandatory to get a license.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
Maynard3848.00 |
05-23-2018, 11:13 AM | #10 |
715
Rep 1,541
Pretty common to run a more aggressive pad up front than in the rear. People do this that like to left foot brake while still in a turn or that tend to brake while still in a corner. I used to do it in my s2000.
bryan_G011164.50 |
05-31-2018, 08:36 AM | #12 |
1165
Rep 1,931
i have the pfc08s as well, a real solid race pad. These will eat your rotors tho.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
