Wheel wobble under braking
05-18-2018, 04:05 PM | #1 |
9
Rep 31
Hi
I've got an e91 m sport 2007. I've had it 18 months and done 40k miles in it. Since I have had it there has been wheel and brake pedal wobble under braking which gets worse the longer the distance having been driven. I've changed the pads and discs, recently changed both sets of front control arms and it hasn't made any difference. I've suggested to the independent garage I normally go to that it may be a gearbox or brake system error and they keep pointing me back to warped discs or pads. Any help would be greatly appreciated. |
05-18-2018, 04:39 PM | #2 |
263
Rep 1,225
When you last replaced the pads and discs, did you flush/bleed brake system and put new brake fluid?
Just a thought.
2010 BMW 335i: Monaco blue metallic/Premium+Sport Auto-Steptronic, BMW PE, Cobb Stage 2
2005 Mustang GT: Redfire metallic/5-spd/Ford Racing (Axle backs, silver Bullitt wheels)/K&N CAI/ Diablo Sport Predator Tuner 1997 Toyota Corolla 1983 Mercedes Benz 380SL Roadster |
05-18-2018, 08:10 PM | #3 | |
681
Rep 3,696
05-18-2018, 10:21 PM | #4 |
Chief Warrant Officer 4
53
Rep 726
Drives: 335I, E46 M3, X5M
Get the front tires balanced. If that does not do it yours rotors should be next.
05-19-2018, 01:37 AM | #5 |
9
Rep 31
05-19-2018, 01:40 AM | #6 | |
9
Rep 31
When the car was MOT'd last week, they brake tested it and there's uneven braking forces to the front wheels but I'm not sure what could be causing this. |
05-19-2018, 02:20 AM | #7 |
1073
Rep 1,957
Drives: E90 M3 LCI Jerez Black
Removed calipers / pins and given them a good clean?
Maybe rebuild them with new seals. |
05-19-2018, 12:54 PM | #8 | |
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
05-19-2018, 01:03 PM | #9 | |
9
Rep 31
I wonder whether it could be ABS system related or to do with the master cylinder. It's not the DTC or DSC as when they are both fully off the problem is still there. On short distances sometimes it won't be present and then as soon as more than 5 miles is covered it vibrates the wheel and pulsates the brake pedal which gets quite violent after a motorway run and shakes the whole car. |
05-19-2018, 01:07 PM | #10 |
9
Rep 31
It had one caliper last year as it was leaking. The calipers are quite clean and all else looks ok. The problem was there before and still after, unless its the other caliper that's knackered that's causing uneven braking forces to be applied to each side and then a side to side action.
05-19-2018, 09:02 PM | #12 | ||
1903
Rep 6,968
Did you check the caliper pins? Are they sticking or does the caliper slide on the pins as they are supposed to do when braking..... |
05-19-2018, 11:28 PM | #13 |
Rep 12
If I remember correctly I had an issue like this with an older car of mine. Something was installed backwards or upside down with the brakes/rotor/caliper/something but I don't exactly recall which part.. that was a long time ago and I've partied way too hard since then. But sounds like everyone's thinking similarly here so that sounds the way to go!
05-30-2018, 09:17 PM | #14 |
224
Rep 699
Check the bolts for both the upper and lower control arms on the front. I was having the same issue and replaced pads, rotors, and inspected everything brake related but it was just a loose control arm bolt.
2021 M2C HS DCT
2007 Wedge 335i E92 FBO, Stage 2 LPFP,VTT STG 2+, VTT Shotgun E50 w/ Inlets MT-SOLD |
05-31-2018, 01:35 AM | #15 | |
102
Rep 343
if you show us a way to change brakes without needing to flush your brake fluid, I will personally congratulate you. what does a brake fluid flush have to do with wobble under braking anyways? |
05-31-2018, 07:55 AM | #16 |
65
Rep 411
I know you said you replaced the control arms, but did you also replace the bushings. I replaced my CA, but not the bushing and it continued until I replaced the thrust bushings.
09-07-2018, 10:45 AM | #18 |
9
Rep 31
I spoke to an independent garage who I've had some work with in the past and he suggested, as others had in this thread, to change the discs. I changed them and was very careful to clean up the hubs and pins, grease everything that needed greasing and the issue disappeared. I've since done 10k miles in the car and it's started to come back.
I spoke with the independent again and he said he's had a few come in with similar issues. The way he's got around it was to use OEM discs. I used Brembo the first time I changed them and then Pagids with the Pagids surprisingly lasting a lot longer before the issue came back. |
09-07-2018, 02:04 PM | #19 | |
718
Rep 1,753
What i mean by front or back is there are two monted at the fron. One seats more front another more rear. |
09-07-2018, 02:43 PM | #20 | |
729
Rep 1,815
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
09-07-2018, 02:49 PM | #21 |
729
Rep 1,815
Please do a bit of research on this before using the term again, modern rotors don't warp.. Gone are the days of non vented single disks.. We now have issues with pad deposits and hot spots caused by overheating the rotor surfaces. Mechanics will use the term warped rotors because it is an easy sell as well, and the fact that most of them will not turn (resurface) rotors anymore. It just does not make profit and takes too much time over swapping on a new rotor.
