BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Vanos solenoid cleaning
      05-18-2018, 01:52 PM   #1
Ian mead
United Kingdom
Drives: E93 m330i
Hi guys are the vanos solenoids easy to take out and clean
Car is a e93 330i euro spec
Had a fault pop up twice this week. So was thinking to clean these first in case they are sticking
      05-18-2018, 01:53 PM   #2
e90yyc
Art Collector
e90yyc's Avatar
2425
Drives: 2007 328xi (GM-delete 6MT)
Yes. Follow this guide.
https://www.pelicanparts.com/BMW/tec..._Replacing.htm
Fritzer944.50
      05-18-2018, 06:16 PM   #3
Ian mead
United Kingdom
Drives: E93 m330i
Thanks for that
      05-19-2018, 08:37 AM   #4
Boland01
Drives: 2010 535ix, 2008, 2007 335i
After I cleaned ours on our 2007 335i I reversed their position. I read somewhere that they wear differently and that helps. so far after 2K miles no further issues.
      05-20-2018, 10:23 AM   #5
90c4
60
Drives: 2009 335i xdrive coupe
Yes, very easy and reversing their position to see if the fault follows the solenoid will let you know if you have a bigger problem
      05-21-2018, 07:30 AM   #6
sorin1987
38
Drives: BMW 520i G31 MSport
Yes, very easy and you can find tons of DIY videos on youtube.
However when I cleaned mine I had a little bit of trouble pulling them out and my hands are big and didn't have the most comfortable position and space. But it's very easy.
      05-22-2018, 12:04 PM   #7
330istocknot
185
Drives: 330chino
What codes did you get?
      05-23-2018, 01:00 PM   #8
Ian mead
United Kingdom
Drives: E93 m330i
002a87 outlet vanos
Only happened twice now.
Also throws up fuel pump plausibility.
I think that just comes up because of the vanos fault.
I’ve not had a chance to clean them yet,hoping this weekend to get a can of brake cleaner to give them a good blast out.
      05-24-2018, 02:09 PM   #9
330istocknot
185
Drives: 330chino
Check how i fixed it here: http://www.e90post.com/forums/showth...4#post23206034
      05-24-2018, 10:12 PM   #10
labrador
65
Drives: E90
2A82, 2A87 codes:
https://static.nhtsa.gov/odi/tsbs/2012/SB-10032779-2821.pdf
It may also be the result of worn cam ledge plugging up Vanos solenoids.
Originally Posted by Ian mead View Post
002a87 outlet vanos
      04-11-2019, 08:45 AM   #11
LBC28704
Drives: E30, E38, E60, E90
Just a note:
The reason it's suggested to swap the solenoids is to see if the code moves, therefore explicitly identifying the faulty solenoid.
Due to the conditions that can cause these faults, the act of removing and replacing the solenoids could potentially dislodge whatever is causing the fault condition.
While "uneven wear" isn't completely out of the question, the Δ in wear over the two is ultimately negligible.
*Edit.
Hahah I just noticed how old this thread was, sorry to bring it back, hopefully it's helpful to someone.
