2011 E93 335i M-sport wheel spacer width?
05-18-2018, 11:02 AM | #1 |
26
Rep 88
Long story short, my dealer must've removed the wheel locks and now I'm running with 4 bolts each...
I'm looking at getting a set of spacers as well as wheel stud conversion Going for ECS tuning studs and they ask you to choose studs that fits up to 10mm spacer or 20mm spacer How wide can spacers on these wheels be? It's a LCI E93, 335i, with M sports suspension I have the stock 193M wheels with 225 front 255 rear |
05-18-2018, 11:18 AM | #2 |
Is it the shoes!?
3884
Rep 5,112
I got away with 12.5mm F and 15mm R. ExtremeContact DWS06's rubbed just slightly over very hard bumps when I had people in the back, but it has stopped.
05-18-2018, 11:39 AM | #3 |
Basic Bimmer
518
Rep 935
Drives: E92 328i 6MT ///M
Go for the up to 20mm option for sure.. if you plan on getting spacers that is.
05-18-2018, 02:25 PM | #4 |
26
Rep 88
05-18-2018, 02:25 PM | #5 |
26
Rep 88
Is there a thing that the hubcentric lips are tall on these wheels and it's not good to use 10mm spacers?
05-18-2018, 02:47 PM | #6 |
Basic Bimmer
518
Rep 935
Yes, 10mm spacers are a no-go for E9x BMW's.. if you want to do it right. As you understand, the hub/wheel-centric lip on the hub is about 10mm, so with a 10mm spacer there is no way for the spacer to be both hub-centric as well as wheel-centric ("extending" the hub's center into the wheel).
The reason I say go for the up to 20mm stud option is because you will surely be able to use larger than a 10mm spacer, at least on the rear axle. I have 20mm spacers on my rear axle, but I'm an LCI coupe and, while I cannot confirm, people here have posted that the sedans/coupes LCI/pre-LCI can have different track and/or body widths. |
05-18-2018, 03:09 PM | #7 | |
26
Rep 88
05-18-2018, 03:20 PM | #8 |
Basic Bimmer
518
Rep 935
Don't be too scared of larger spacers. I initially went 18mm because of what the general consensus here was.. only to immediately change to 20mm. Many here are quite conservative. Unfortunately, sometimes trial and error is the only way to get it perfect. On my LCI E92, 20mm is the perfect width for non-rolled fenders, IMO. Any more and it would rub. I confirm this by compressing the suspension so that the wheels are up in the fenders and then checking clearance.
dominick.han26.00 |
05-18-2018, 03:31 PM | #9 |
319
Rep 1,023
When I put the stock wheels on during the winter, I have 12mm front and 18mm rear on both my pre-LCI e90 and my wife's LCI e90. Places them nicely.
Why are you doing the stud conversion? The spacers from ECS Tuning come with proper-length lug bolts. Unless you remove and reinstall the wheels every week, I can't imagine it would make a time difference either, plus bolts look cleaner.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
05-18-2018, 03:46 PM | #10 | |
26
Rep 88
Yeah now I guess chrome lug bolts are nice too |
05-18-2018, 04:48 PM | #11 | |
665
Rep 740
Car is 2011 MSport. |
05-18-2018, 08:53 PM | #12 |
26
Rep 88
E90 is different with E92/93 tho...That's why I'm so confused about all the different spacers
05-20-2018, 08:46 AM | #13 |
863
Rep 5,448
On my 2008 E93 I ran 15mm rears with the OEM Bridgestones on the 18 OEM 193M wheels, when I switched to Michelin PS2's they rubbed a tiny bit and I switched to 12.5mm spacers in the rear as the PS2's are just a touch wider.
Hope that helps - I don't run any spacers up front. Rob
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
