M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Stiffening Plate (Belly Pan) Bolts
      05-18-2018, 01:39 AM   #1
Nezil
Nezil's Avatar
1403
Drives: LCI '18 6MT M2
Last weekend I fitted my Fabspeed Sport Cat, which required removal of the front chassis stiffening plate. I know a few people have done this before, and in the DIY threads, no-one has ever posted about replacing the bolts that hold this on, even though ISTA+ gives torque settings of 56Nm + 90 degree rotation, and states that the bolts must be replaced.
This evening I had to remove the stiffening plate again to fit an upgraded Charge Pipe, and as I was putting the plate back on, I started to get concerned that these bolts might sheer if I don't replace them. I know the torque + angle tightening sequence is designed to stretch the bolts, and that doing this is only possible a few times.
I have an upgraded FMIC on its way, and will likely need to remove the stiffening plate again... I'm thinking of getting some new bolts this time, but wanted to hear feedback from others on the forum... is this really necessary?
Thanks in advance!
2018 ///M2 LCI, LBB, 6MT...
Current Performance Mods:
CSF FMIC, ER CP, Fabspeed Cat, Aquamist WMI, GFB DV+, NGK 97506, BM3 (Stage 2 93 OTS), CDV delete, UCP, M2C/M3/M4 Strut Brace, M3/M4 Reinforcement Rings
      05-18-2018, 12:02 PM   #2
Nezil
Nezil's Avatar
1403
Just got a quote for these bolts from my local dealer... $8.65 each!
They offered to give me a discount to bring it down to ~$5.20 each... still very very expensive for an M10 x 33 bolt.
      05-18-2018, 01:07 PM   #3
greasypeanut
230
Drives: F87
I didn't replace my bolts but I did manage to damage the threads on one of the bolts. I am currently missing one bolt securing the belly pan lol. Need to visit the dealership and get a quote. Cheap online but shipping ruins it.
      06-01-2018, 05:28 AM   #4
cookiesowns
cookiesowns's Avatar
587
Drives: X5 45e, 535i N54, X3 N55
I've done this twice already without replacing them. I'm probably going to replace them soon.. these are definitely torque to yield bolts and the belly pan acts as a lower chassis brace.
BM3, MHD, ECUTek Calibrator | N55/S58 specialist | 2023 X5 45e Frozen Marina Bay Blue
      06-03-2018, 09:37 AM   #5
nothingman
Private NumNuts
nothingman's Avatar
Drives: 2021 GT4
Do you by chance have the part number for them?
      06-03-2018, 11:08 AM   #6
Nezil
Nezil's Avatar
1403
33326768354
      07-06-2021, 11:22 AM   #7
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
325
Drives: 2018 BMW M2 LCI
I’m sorry but these bolts are ONE time use—Seriously?!! So I installed my CP, change. FMIC, change. Down pipe, changed?!! Isn’t that a bit extreme?
      07-07-2021, 12:39 AM   #8
F87source
F87source's Avatar
7238
Drives: Bmw M2
Yes these bolts are torque to yield meaning they are stretched. If you reuse a stretched bolt and restretch them as per bmw's torque spec you risk the bolt snapping. If you do not yield the bolt then you will not apply the correct amount of load and an even load onto the head of the bolt and threads, so chassis stiffness is not as it should be.
Also water pump bolts are single use torque to yield as well. So are strut tower bolts, differential drain bolts etc.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242
      07-14-2021, 02:46 AM   #9
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
325
I was just watching brake servicing on M2 Competition. It says 30 Nm + 90 deg.... but if re-use 110 Nm. Made me think about these one-time-use bolts. Why can't we re-use these bolts on stiffener plates but for (IMO) even more critical areas like what's holding our brake calipers or wheels are just torque to 110 or 140 and not need replacing w/ a new one.
Just throwing it out here.
Time: 17:13
2018 BMW M2 LCI BM3 Stage 2 + MPE + FTP charge pipe + MST V2 Inlet + TurboSmart DV + CSF FMIC + AA Hi-flow Downpipe + Turner Rear Shifter Bushing + Wiechers Strut Brace + Bilstein B16 PSS10 + Apex VS-5RS
      07-14-2021, 03:22 AM   #10
F87source
F87source's Avatar
7238
Drives: Bmw M2
Time: 17:13
First off some people reuse bolts that are single use because they either:
1) didn't know they must be replaced because they don't have ISTA.
2) Don't want to spend the kind of crazy price for bmw bolts.
3) Don't care.
But either way bmw says the bolts are single use so if you want to do it right the bolts must be replaced.
Well I just looked at ISTA and they do specify that both front and rear bolts must be replaced whenever removing them. Real oem says they are also the exact same bolt so despite bmw not specifying that the front bolt must be yielded as they only give a torque spec, since they are the same as the rear caliper bolts which do need to be yielded and thus stretched we know these bolts will stretch when subjected to torques past 30 nm.
This means they MUST be replaced and you really shouldn't reuse a previously stretched bolt. Because a previously stretch bolt is now weaker and is susceptible to snapping. It will also not be able to apply the same clamping load after the material is stretched (a bolt is stretched to enable it to provide a more equal clamping load along its whole thread length and prevent it from vibrating loose, once stretched its elastic properties change and clamping loads won't be the same anymore) so that bolt really shouldn't be reused.
So imo FaRKle! shouldn't have put a used bolt torque spec, he should have said new bolts are required...
      07-14-2021, 06:49 AM   #11
M Fifty
844
Drives: M2 & 330CI
Interestingly, BMW also recommend replacing some bolts that aren't obviously being torqued to the point of being stretched - but are being screwed into aluminium.
Made me wonder about the plating on them being some kind of passivating layer designed to prevent electrolytic corrosion, and hence the need to replace them with new each time they are removed.
      07-14-2021, 01:12 PM   #12
F87source
F87source's Avatar
7238
Drives: Bmw M2
Interesting point.
      07-14-2021, 07:44 PM   #13
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
325
1) what’s ISTA?
I tried google first but couldn’t get. One really learn something new every day about this car.
      07-14-2021, 09:28 PM   #14
F87source
F87source's Avatar
7238
Drives: Bmw M2
1) what’s ISTA?
Bmws dealership software which allows for full diagnostics of the car, programming, software updates, and full repair guides with step by step instructions + pictures and toque specs. Some parts of ista can brick your car if you don't know what you're doing so be careful.
      07-14-2021, 10:03 PM   #15
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
325
Oh don’t worry I’m not thinking of touching that.
m2
