Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > IDEA FOR E90 AMBER BLINKER / DIFFUSER???
      06-20-2005, 10:27 PM   #1
WirelessX
Drives: 2006 BMW 330i
Lightbulb IDEA FOR E90 AMBER BLINKER / DIFFUSER???
Do you guys think it would be possible to open up the light casing and tinting the amber part to be black instead of the yellow color?????
lmk what you guys think
thanks dan
      06-20-2005, 10:32 PM   #2
dmbigs
Drives: AW 335i
im not that knowledgable when it comes to cars tuning and modification, but that sounds like a really good idea.......anybody?
06 Silver 330i, black leather, sport and premium
      06-20-2005, 10:35 PM   #3
res_ipsa
res_ipsa's Avatar
14
Drives: 325i SparkGraphite
Unfortunately I think this isn't a possibility. The reason that the only option for getting rid of the orange diffuser part so far is to swap out the whole headlight for an eurospec headlight is because nobody has been able to open up the headlights, or else you'd be seeing just clear diffusers for swapping already.
      06-20-2005, 10:37 PM   #4
dmbigs
Drives: AW 335i
i didnt know that was the case i just thought the orange was affixed to the whole headlight, and not removable.either way the orange has to go
http://www.cardomain.com/ride/1440202
      06-21-2005, 06:04 AM   #5
egtlover74
Photographer
egtlover74's Avatar
40
Drives: 335is Coupe
What is the tint vlt? is it 50% or 35% ?
Are they different % front and back?
They loook goooooood
      06-21-2005, 02:20 PM   #6
dmbigs
Drives: AW 335i
35% all around, thank you
      06-21-2005, 02:25 PM   #7
LWL
LWL's Avatar
Drives: G05 X5
One way I can think of, without changing the whole housing to Euro spec, is by "opening up" the housing. I mentioned this before, S2000 has the same type of headlight as E90 as well. It has the orange reflector inside the housing. I knew S2K owners were able to open up the housing and take the orange part out, but this required cutting the seal of the housing and "baking" the headlights. Its kinda complicated. I am sure someone on this board knows about this. Anyone owned a S2K??
      06-21-2005, 04:21 PM   #8
romeo26
44
Drives: e30 325 (no lette)
how would the xneons hold up to the baking prosses?
      06-21-2005, 05:27 PM   #9
LWL
LWL's Avatar
Drives: G05 X5
I would assume we take out the xenon bulb while baking. S2K has xenon standard too, so it gotta to have some way to do this.
      06-21-2005, 07:09 PM   #10
Jason
Administrator
Jason's Avatar
Drives: F80 M3
I baked my S2k lights when I had the car and left the xenons in there (just like everyone else). The xenons get hotter than the temperatures you bake at so they're fine.
      06-21-2005, 07:38 PM   #11
LWL
LWL's Avatar
Drives: G05 X5
Since you have the experience of taking out orange reflector on your S2K, do you think the same theory works for E90's headlight too?? Are you going to try it??
      06-21-2005, 11:51 PM   #12
romeo26
44
what do use to put the headlights back together?
      06-22-2005, 10:11 AM   #13
Jason
Administrator
Jason's Avatar
Drives: F80 M3
I've done some inspection/work on an E90 headlight and I can confirm that the E90 headlights are not like the E46 - you cannot simply snap the front clear cover off to access the corner diffuser.
The clear cover is glued tightly to the rest of the headlight assembly using butyl glue. There's definitely a lot more glue than on the S2K headlight and it seems like it's not possible to get the E90 headlight open using the baking method (I've tried). There's so much glue and it's so thick and abundant that it's hard to get any portion of headlight open without damaging the assembly itself. Also there's so much glue that by the time you bake the headlight for a long enough period and high enough temperature to get the glue to a soft enough form to work with, you're at a temperature/duration that is starting to destroy the plastic headlight assembly itself. You could probably crack open a part of the assembly somehow but I don't know how many owners are willing to do that. This seems like a highly desirable mod so I'm sure there will be many others out there who try to bake and open the headlight and maybe someone will be able to get it open, but based on my experience it may be too difficult a job for most people to try (too much risk of damaging or destroying the assembly).
I don't know if BMW made the headlights like this on purpose to prevent every owner from switching to non-DOT approved clear diffusers, but in any case that's the effect.
      06-22-2005, 01:27 PM   #14
LWL
LWL's Avatar
Drives: G05 X5
Since the "baking" option isn't working, I guess we have to wait until aftermarket ones come out. Sighhhh
      06-23-2005, 08:16 AM   #15
YYdoodle
115
Drives: E92 M3 fanatic
Hrm is there such thing as smoked or semi-clear film you can tape over the amber diffuser areas to tone down the orange color? Seems like that'd be a way to dealing with it.
      05-13-2007, 08:33 PM   #16
P8ntplayer
P8ntplayer's Avatar
Drives: black 2006 325i sport package
Def not 50 or you wouldnt be able to see , its 35
      05-13-2007, 09:35 PM   #17
gerbs
woof
gerbs's Avatar
Drives: M6
I hope that guy found the answer by now, since it's been 11 months and all.
2013 F13 ///M6 Sakhir Orange
2013 F30 335i Estoril Blue II
2008 E92 ///M3 Interlagos Blue
2007 E92 335i Montego Blue
      05-13-2007, 10:11 PM   #18
ksfrogman
ksfrogman's Avatar
Drives: E90 330i 6MT
2006 330i  [0.00]
2006 330i  [0.00]
You mean 23 months. The question was posted in June of 2005.
It's fun to see this old thread. I didn't realize LWL was a member way back then. Wow, Elaine, you're old. Heh.
      05-13-2007, 10:40 PM   #19
ALPINE6SPD
ALPINE6SPD's Avatar
Drives: 2010 BMW 328i Sport
not this again
lock this please
2010 AW e90 328i: 6 speed, Black Leather, Dark Wood trim, ZPP, ZCW, ZVP,ZSP, Nav, Xenon
BMW Performance CF Rear spolier and Gloss black grills
2008 Candy White MKV GTI 2.0T 6 Speed Manul Gone
2008 AW X3 3.0si: 6 speed Returned
2006 AW e90 330i: 6 speed Dinan Stage 1 Returned
      05-14-2007, 11:30 AM   #20
mds82
mds82's Avatar
364
Drives: 2006 325xi
this thread is awesome!!!!
Yes you can open the headlights - not easily.... not recommended. and not for the faint hearted.... you VERY easily could ruin them. be carefull
      05-14-2007, 12:30 PM   #21
canucklion
pull my finger to get your kinder® surprise
canucklion's Avatar
148
Drives: circles around you
haha, but I prefer back-from-the-dead threads over people not searching
Originally Posted by ALPINE6SPD View Post
not this again
lock this please
