White smoke from engine bay passenger side
05-17-2018, 06:52 AM | #1 |
Rep 19
I was experiencing white smoke from the tailpipe a while ago and neglected it until it started smelling like burnt oil in the interior.
Now the white smoke is coming from the back of the engine and the motor sound is uneven and not steady, its like its switching between rpms when starting the car. This happened after not driving the car for 2 weeks. I don't have a engine light or anything whatsoever. I noticed the oilcap have been loose and theres been a leakage of oil around the engine bay due to the loose cap. I don't know what to do next, im suspecting a faulty valve cover gasket but I need your help finding the culprit of this issue. |
05-17-2018, 06:56 AM | #2 |
602
Rep 2,703
Drives: 2009 335i - Sport PKG
check for leaks and get engine bay washed and keep an eye on it, if it happens again then there is some leak somewhere. or go to indy shop and get it checked for leaks.
05-17-2018, 07:31 AM | #3 |
Rep 10
I’ve delt with this before most likely it’s the valve cover gasket get some engine cleaner at like autozone or something and wash the living crap out of the engine and drive it for a few days and inspect where it’s lenajng with a flash light
05-17-2018, 07:47 AM | #4 |
205
Rep 349
Not sure about smoke from tail pipe but smoke in engine bay near the passenger side at start up is certainly VCG. It may be bad enough to leak into your spark plug well and cause misfire but then you should definite see a code. Inspect the spark plugs and look for oil.
05-17-2018, 08:18 AM | #5 |
Rep 19
Thank you all for fast response!
I'm a bit frightened about washing the engine as there are electrical part that might be damaged. Is there a DIY for this? Should I rinse wash with water or just spray with a special motor spray and clean it off? Thanks! |
05-17-2018, 09:23 AM | #8 |
Hoonigan
6848
Rep 3,000
Drives: '09 328i, '98 Wrangler
Here is how I wash my engine bay on all my vehicles:
1. Cover computer and major electrical components with plastic bag 2. Spray coating of Simple Green degreaser and let sit for a few minutes 3. Lightly rinse with a hose (not a pressure washer) trying to avoid soaking electrical components. 4. Let air dry
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
05-22-2018, 11:34 AM | #11 |
Rep 19
The problem has evolved.. I’m upset as hell now. Nerver getting a bimmer with high miles again.
When starting it starts VERY rough. Like it doesnt have any power. Struggling to get a steady rpm, and the white smoke from behind the motor is now a cloud of smoke and smells pretty chemically.. what next? Is it trash? |
05-22-2018, 12:08 PM | #12 |
Rep 19
This is the area of white smoke
View post on imgur.com |
05-22-2018, 12:19 PM | #14 |
Rep 19
05-22-2018, 12:40 PM | #16 |
Rep 19
05-22-2018, 04:56 PM | #18 |
205
Rep 349
VCG replacement is about $1000 at indie, $1500 at dealer. Almost all labor.
If it is misfiring due to VCG leak in spark plugs you should be getting a misfire code. |
05-23-2018, 12:27 PM | #19 |
46
Rep 117
not necessarily just did a VCG where it was leaking into two sparkplug holes where plugs where saturated in oil oddly enough car was not shooting out any codes for misfires.
05-23-2018, 01:03 PM | #20 |
Rep 19
Gave it a wash and cleaned the leaky oil spills. Started it roday and no more smoke!
But the first startup it immediately shut down. Second start it went up to 1300 rpm and then a steady 700rpm. I havent driven it for about 3 weeks. |
05-23-2018, 01:49 PM | #22 |
226
Rep 1,130
Drives: '11 E92 328i LCI & '06 Z4MR
My '11 328i had smoke coming out from the same exact area pointed in your picture danne.m. I knew it was the valve cover gasket. I checked under the car and could see the oil leaking into the exhaust manifold (headers). That section being extremely hot, caused the smoke. As it got worse with time, white smoke started puffing out of the mufflers even when it was cold outside. I replaced the valve cover gasket (VCG) and voila! Instantly the car stopped smoking from the rear of the engine and the mufflers. That very well could be your problem. It's an expensive job unless you do it yourself (spent less than $150 in gaskets for the job). Pretty simple, here's the youtube video i followed (that song in the video will stick in your head for about 2 days);
2014 BMW X5 Sdrive35i F15
2011 BMW 328i E92 LCI 2006 BMW Z4 M Roadster E85 2013 BMW S1000RR K46 R.I.P. 1998 BMW Z3 Roadster 1.9L E36 SOLD |
