turbo failure 320d
03-13-2006, 05:25 PM | #2 |
First Officer
14
Rep 187
No experience of this as I haven't even picked up my car yet, but would be interested to hear what happens if the dealers tell you anything.
E90 320d M Sport | Black Sapphire |6 Speed Manual | Blue Shadow Cloth/Alcantara | 193s | Individual Sun Protection | Rain Sensor + Automatic Headlight Control | 6 CD | Hi-Fi Loudspeaker System
03-13-2006, 06:37 PM | #3 |
Rep 235
Drives: 320d SE;Mazda MX-5
sorry not heard of that. only lag I've had is waiting until it hits 1500rpm
03-13-2006, 07:00 PM | #4 |
15
Rep 171
turbo's can't "reset".. if there is a problem with your engine you should take it into the dealership and have them find it.. if the problem comes and goes, and you don't hear very bad noises (loud humming under heavy engine load, which indicates a failing turbo) coming from the engine bay you likely have another problem.
03-14-2006, 12:31 AM | #5 |
Torque junky
115
Rep 1,688
Drives: Remapped e90 330d
Are you sure it's the turbo? It may be a problem with the catalyser.
www.greenkeepers.fr - spécialiste des tondeuses à gazon hélicoïdales atco qualcast ransomes lawnflite
03-14-2006, 01:29 AM | #6 | |
Addict
203
Rep 2,074
Maybe give your service dept a call - and explain it all to them. They might know. |
03-18-2006, 04:54 AM | #7 |
Rep 11
had the same problem with my E90 320d... sometimes powerfull and from time to time not powerfull....
SO I told this to my garage and guess what.... they told me they know the problem with the turbo. They have to change it now (in garantee of course). The problem is with a wire in the turbo wich is fault. As they told me, the computer of the car (engine) is giviing information to the turbo and in this case sometimes it is not understood well by the compressor. So they will change it next week and the problem should be solved! |
03-18-2006, 02:11 PM | #9 |
8
Rep 174
Drives: bmw e90 320d m sport
yes there are currently 3 diesel e90's to be had 118d, 320d, and 330d, the 330d makes a mockery of the 330i, nearly as quick to 60 mph, cliamed 42 mpg but really 36 mpg but more torque than a 545i, still with limited 155 mph
03-18-2006, 03:12 PM | #10 |
59
Rep 410
Year ago, our dealer's demo 320d had a faulty turbo and had to be replaced. I believe there was something wrong with the variable geometry system of the turbo.
No wonder that the engine felt laggy during the test-drive. |
03-19-2006, 06:09 AM | #11 |
Rep 11
I contacted my dealer and they know the problem... from the moment I said I had problems with acceleration....
I should be something with the turbo and the connection to the main computer system in the car. They are not communicating well... so next thursday my turbo will be changed (on warranty).. AND I HOPE THE PROBLEM WILL BE SOLVED! 320D Sport package Belgium |
09-17-2007, 03:06 AM | #12 |
28
Rep 1,832
they had to change the turbo in my car last week and my car only has 20000kms on it, my god the car sucks
e90 320d,arktis,lumber support, hifi speaker, alarm, dakota beige, 162 18", xenon with washer spray,window chrome trimmings, professional radio, 6 cd changer wood trimmings
6 speed manual. |
09-17-2007, 03:24 AM | #13 |
128
Rep 2,426
Drives: E93 335i M-sport
might be woth asking on the UK forums...
more oil burners over there. SJ |
09-17-2007, 06:03 AM | #14 |
The Tarmac Terrorist
948
Rep 29,345
Drives: 997.2 GT3
and what about the 335d
997.2 GT3
11-04-2007, 05:17 PM | #15 |
Rep 1
no turbo!
i also have problem with 118 d 122 hp...no torque till 2700-3000rpm..the turbo comes only at this level instead of 1700rpm...what can be wrong?
it has no pwer between relanti and 2700..what can be wrong? |
06-09-2008, 05:20 AM | #16 |
Rep 2
Same turbine problem with e90 320d
E90 320d, brand new, 1900km, the problem started appearing at 1500-1600km.
after driving about 30km, engine off for about 2-3 hours, when I drove off....omfg?! this ain't bmw!!! it's a clio...no torque, no feeling of getting sucked into the chair...nothing.. I have the same problem. I think it's due to the fuel or due to the turbine, but the fuel wouldn't cause the 'scratching of a tire against sand' noise when I rev the engine. The problem is random, sometimes when I start the engine it would have torque and great acceleration, and sometimes it's like a Renault...wtf?! Also the problem doesn't appear after a long drive, massive speed etc....or nor does it appear when the engine is cool or hot. I'm guessing I'm not the lucky one to have a faulty wire cause of the MECHANICAL noise that I hear when I rev the engine above 2000rpm, and the noise dissapears when it comes to rilanty (800-900smt rpm). I'm taking the car to the service on friday, hope it will be taken cared of fast. |
07-21-2008, 09:46 AM | #17 |
Rep 3
320d turbo boost problem
my car used to boost at around 3000 rpm and reverts back to normal after i swith off and leave for a few mins, i took it to the dealer and had the turbo changed, problem now is that with the previous turbo i had better top end as it was boosting much later, now my car is flat at bout 200km/h as compared to before where it had oomph stil around 230km/h, does any1 know what the problem is
