Vrsf coupler touching oil lines ok?
05-13-2018, 03:59 PM | #1 |
Rep 58
Just installed 7in vrsf intercooler, and noticed that the 90 degree coupler on the driver side is pushed up against some of the oil lines. I understand I can cut off an inch of two off the coupler to make it fit proper, but will running it likes this be an issues in the meantime / does that oil line get hot enough the melt into the coupler?
Thanks! |
05-13-2018, 07:03 PM | #2 |
1209
Rep 2,476
I don't think the oil in the lines would melt the coupler, but I wouldn't want anything rubbing up against them for fear of wear through and leakage.
05-13-2018, 07:31 PM | #3 |
Rep 58
True, I'm just going to run it for a few days until I have time to get back down there then I will take the ic and coupler out so I can cut it down. Just wish I would have known to cut it before installing everything.
05-14-2018, 12:39 AM | #5 |
Rep 58
05-14-2018, 12:47 AM | #6 |
2095
Rep 43,350
If it’s all the way up on the intercooler you can trim 1/4” off that section to make it sitting closer to the front of the car. We always included more coupler than less coupler since you can always trim but you can’t add on.
OTN5538.50 |
05-15-2018, 12:40 PM | #7 |
41
Rep 220
I had the same issue installing mine over the weekend, you just need to push the coupler further up on the lower charge pipe.
And when I die, make sure you spread my blood on a BMW 2012 E92 335i xdrive | KW V1 Coilovers | ER Chargepipe | VRSF 7" HD | VRSF Catless DP | MHD Stage 2+ | xHP Stage 3 |
05-16-2018, 09:21 AM | #8 |
Rep 58
