2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Speedometer Error Correction
      05-10-2018, 08:57 PM   #1
WolfGTI
WolfGTI's Avatar
Drives: '17 F22,15 E84 M Sport,02 R53
2017 BMW M240i  [0.00]
2002 MINI Cooper S  [0.00]
2015 BMW X1  [0.00]
Can this be changed through coding - thinking of changing tire size and want to eliminate the error.
      05-11-2018, 10:43 AM   #2
aerobod
Car Geek
aerobod's Avatar
3626
Drives: Caterham R500, M2-G87, Macan S
On my M240i, the speedometer is 4% over reading with standard 245/35-18 rear tyres (629mm nominal diameter) and 1% under with 225/45-18 (660mm nominal diameter) rear tyres. You may find that changing your tyre size makes the speedometer more accurate. Speed was checked using GPS while the car is on cruise control at 100km/h on a level surface in each case.
      05-14-2018, 08:50 PM   #3
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
KOMBI 3000 BC_V_KORREKTUR aktiv nicht_aktiv BC calculation with the speedometer curve - correction for analog / Head up display speed - disabling those corrections , you will be able to see the real speed.
      05-17-2018, 08:39 PM   #4
WolfGTI
WolfGTI's Avatar
2015 BMW X1  [0.00]
Thank you - however the speedometer will still read inaccurately correct?
      05-17-2018, 11:19 PM   #5
pikcachu
pikcachu's Avatar
1403
never actually tried it so not quite sure
2addicts
