How would you remove the crappy plastic fitting for the hose that goes into the OFH?
05-09-2018, 02:06 PM | #1 |
220
Rep 418
I was doing the OFHG last night in my garage and the plastic fitting on that hose practically disintegrated when I pulled it out. I've ordered an aluminum replacement, but I'm having a tough time figuring out how I'm going to remove the plastic one without damaging the hose. There is metal band without any seams holding it on. In the space I'm working in it's not feasible to use a cutting wheel. Any suggestions? The hose is in great shape, FWIW.
The best I could find searching the forums is in the link below, but I can't see how I would use side cutters on the band without damaging the hose. https://www.e90post.com/forums/showthread.php?t=1117422 |
05-09-2018, 03:54 PM | #2 |
2124
Rep 2,758
Cut off wheel on a dremel, just did another one last weekend. Make sure not to go all the way through into the hose, just get a nice groove/cut in the clamp, then use a screwdriver/chisel to split the clamp in half.
05-09-2018, 04:47 PM | #3 |
126
Rep 482
I just squeezed what was inside with a pliers. The hose was wrapped with a cloth, once the plastic bits were out, it was easy to cut off the metal flat band ring. Then replace the broken plastic nipple with the metal (aluminum).
Stable:
e92is f25 N52 e83 N52 e46ci M54B25 (e53 N62 - sold, R.I.P. e39 M54B30) |
srey220.00 |
05-09-2018, 06:40 PM | #4 |
68
Rep 211
2 choices:
Cut the ring off with a dremel, like described above. Break the rest of the plastic so you can flex the ring off the hose. Hit it with a hammer, crush it in a vise, whatever, just get it to split so you can take it out in pieces. I'd recommend removing the entire hose from the engine bay so you can flush the inside of it out when you're done. |
srey220.00 |
05-09-2018, 06:41 PM | #5 | |
220
Rep 418
Thanks for the advice all. |
05-09-2018, 06:50 PM | #6 | |
2124
Rep 2,758
05-10-2018, 06:30 AM | #7 |
4542
Rep 11,903
have to cut with dremel as stated above
