Dads Car in limp mode Please help
05-08-2018, 08:44 AM | #1 |
Rep 5
hello my dad has an 07 328XI and it has been going into limp mode, He brought it to a shop and they charged him 700 to change the accelerator pedal. and the problem came back two days later. These are the codes it has
2D20 P0155 5F77 2E98 2E8B Any help or direction would be greatly appreciated |
05-08-2018, 09:04 AM | #3 |
Rep 5
thanks, I understand that lol the problem is the pedal was changed, the one is an o2 sensor but that shouldn't cause limp mode? I don't know what the dme is, and the other two codes seam to be with the battery. The car was running fine so I am trying to figure out which component needs to be changed that would be causing the limp mode.
Thanks, Joseph |
05-08-2018, 09:17 AM | #5 |
277
Rep 1,575
I could tell you everything to check but I won't post it here. Spent too much time with these cars to throw out a bunch of free info
05-08-2018, 11:01 AM | #8 |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
changed the pedal?! First thing he should go get his money back for that bs so he has an extra $700 to spend on ACTUALLY fixing the issue jc smh
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
05-08-2018, 11:14 AM | #10 |
Save the manuals!
6015
Rep 6,746
Lol you need a new mechanic, I'd be demanding a refund from that piss poor shop.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
05-08-2018, 03:03 PM | #11 |
Rep 5
its the accelerator module, actually a very common problem on these cars. And turns out that was the problem "again" apparently the guy didn't push the connector on all the way and it came loose
01-24-2020, 01:46 AM | #12 |
57
Rep 276
This is a 2d20 link
https://www.google.com/amp/s/amp.red...i_solved_2d20/ I found the issue after many many wire tests I tested every wire coming from the pedal for continuity, obviously not the issue, then I loosened the grounds under the hood and retightened them one at a time and found the ground, it was the one located on the pass side strut tower under the hood, as a recap I was getting the 2d20 code constantly and the reduced power mode, also would see other faults popping up randomly but the 2d20 was consistant. That is a quote from the link below the first link I found when searching your trouble code . https://www.n54tech.com/forums/showthread.php?t=52064 So not sure about these codes all together but as far as 2d20 you can either test wires and grounds? Still looking at more links ! |
