2007 BMW 335i will start with jump/booster but not on its own
05-08-2018, 03:02 AM | #1 |
Rep 11
Strange problem with my 335i. Car suddenly wouldn't start, lights/dash would turn on but wouldn't fire up. I checked the battery compartment and it was partially flooded with water
I pulled the battery out and cleaned out all the water and reconnected everything, put the battery on a charge just in case. Tried starting the car a again and still wouldn't crank. Final solution was to hook up a battery booster with the leads under the car and the car cranked and started Figured it was the battery was toast, so I replaced it with a new one. But same problem persists, car will start if I boost/jump it but not on its own.... am I missing something? Doesn't appear to be any of the fuses or anything... |
05-08-2018, 04:20 AM | #2 |
10
Rep 203
Hmm if it's starting with the battery booster but not with a brand new fully charged battery I suspect it would be a connection or a fuse. The red cover above the battery actually has blades that although don't look like fuses act as them. So it could be under there. I don't have a picture to hand but if you clip off the top red battery cover from the black retainer you should see where wires connect up for the distribution rail/fuse blades. If ones of those has gone or broken connection that could be the cause. Seems odd that it would start with battery booster otherwise.
05-08-2018, 04:44 AM | #3 |
729
Rep 1,815
Bad ibs?
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
05-08-2018, 07:38 AM | #4 |
277
Rep 1,575
If your battery is in a pool of wster. The connection st the red cables that go through the body are probably rusty. I have seen it before. Because it started with a jumper gives the starter direct power in a cable 5 ft long. You may be replacing your whole positive cable from trunk to fire wall jump service port along with the valvetronic motor supply cable also.
05-08-2018, 09:04 AM | #5 |
205
Rep 349
How did you get a pool of water in your battery compartment 😲???
Probably messed up the conductors, distribution/overcutrent protection components. Maybe blown fuse. Check positive connection from trunk to the front, and measure positive to ground resistance. |
05-08-2018, 12:16 PM | #6 |
110
Rep 2,017
Drives: AW 07 e92 335i + AW 11 X5 35d
Where are you putting the boost pack? Under the hood or at the battery in the trunk? If under the hood, try at the battery and report. The little thing that sits on top of the battery that connects to the positive terminal is a fuse block. There is a fused circuit that sits between the battery itself and the underhood jumper terminal / alternator / starter.
05-08-2018, 12:57 PM | #7 |
277
Rep 1,575
05-08-2018, 07:50 PM | #11 |
1209
Rep 2,476
Dude, BMW screwed you with the old "Let's not put a ground anywhere in engine compartment" trick...like, maybe an engine block, or a metal component bolted to said block, or...
05-08-2018, 07:56 PM | #12 |
488
Rep 1,309
I know I can get ground anywhere. If I put the ground cable to the body (extra long nut near coolant tank, or the suspension crossbeam bolt for example) then the ground to the starter has to feed through that crappy ground strap that corrodes through. If I connect it to the engine, it doesn't go through that strap.
Knowing where the OP connected his jump box will help with diagnosis. Last edited by vilord; 05-09-2018 at 06:53 AM.. |
05-09-2018, 01:33 AM | #13 | |
729
Rep 1,815
You can see it in the left of this picture and almost every modern bmw has it in a similar location.
05-09-2018, 07:26 AM | #15 |
729
Rep 1,815
I have just wanted to use that smiley. It was the perfect opportunity. But joking aside, BMW always has the best grounding point available for you already established to use under the hood.
05-09-2018, 08:49 AM | #16 |
488
Rep 1,309
I pulled out my manual, and sure enough, there it is. Now to find some touch-up paint to fix where I scratched the strut tower from the last 5 years of jump-starting other people's cars.
david in germany729.00 |
05-09-2018, 03:53 PM | #17 | |
1209
Rep 2,476
05-09-2018, 11:49 PM | #18 | |
729
Rep 1,815
The real point of this thread is the issue with infraboy having problems with starting. infraboy, have you checked the IBS on the battery?
05-10-2018, 06:29 AM | #19 | |
4542
Rep 11,903
05-10-2018, 07:02 AM | #20 | ||
119
Rep 228
05-10-2018, 07:38 AM | #21 | |
1209
Rep 2,476
05-10-2018, 07:41 AM | #22 |
729
Rep 1,815
I type with a smile 80% of the time. Ever heard of going "ranger"?
