DIY Aggresive rear Diffuser
05-07-2018, 10:17 PM | #1 |
69
Rep 404
Been working on a diffuser for my e90 LCI 335.
With my aeronautical background and the fact that I have access to most materials for pretty cheap I decided to try my hand at this. Essentially, I am trying to reduce the parachute effect of the rear bumper, while at the same time improving the look of the car. This is the test car First Side slat tryout (all mockups are made with corrugated plastic) I guess it worked out okay, least gave me something to work with, I then got busy with the middle part Mockup slats ''glued'' in place Testing on the car Finished ish product Basically, the front of the plate attaches to the flat part between the LCAs and the curves are ment to stay close but not touch the exhaust pipes, the entire Diffuser maintains about 3/4 inch clearance with the OEM exhaust (PE in my case) I got busy with CATIA and crew the entire base plate, I then cut/shaped the plate at work. I was hesitant between bedliner coating and wrap it in CF, I had the CF, decided to go with that. Here is the end result Now I need to decide on my Fin profile, I decided I didnt like the one I did initially, I am REALLY OPEN to any ideas or suggestions, looking to do 4 fins on the plate (larger space in the middle) and one under each side. Here is another one I mocked up (excuse the mess) Last edited by Evochuck; 07-31-2018 at 02:10 PM.. |
05-08-2018, 12:20 AM | #4 |
44
Rep 165
^ Last two pictures aren't visible.
Cool idea I like the finished product. What kind of testing are you going to do to see what difference it makes? I worked on the underbody/diffuser subsection for my school sae team, learned a lot about the impacts of the diffuser on performance. I'm curious as to how you decided the dimensions and placements of pretty much everything on it. Is it just a random mockup or is it influenced by your aeronautical background?
@balxoscar
@1visionperformance |
Evochuck69.00 |
05-08-2018, 01:29 AM | #5 |
Rep 16
Looks good so far would like to see how the final product turns out. If it turns out the way I think it could would you be willing to make one for me at all? I only ask cause I have the same car and model as you
05-08-2018, 07:07 AM | #6 | ||
69
Rep 404
Thanks! Looking forward to finishing it!
My aeronautical background mostly helped me drawing it and fabbing it up. If I had access to more equipment I would have done the large bend with a much larger radius to smooth out the airflow. Quote:
Sill looking for Ideas for the fins! |
05-08-2018, 01:19 PM | #11 |
540
Rep 1,040
I'm interested in hearing more about the parachute effect you're referencing. Assuming you're talking about air from forward motion being caught up in the bumper, how much are we really talking about here? This seems like something that would have a pretty big effect on performance and fuel efficiency, I would assume the Bavarian engineers would have minimized this as much as possible, without compromising looks.
Also, the 335is comes stock with a finned rear diffuser. I am now wondering if they made this change to later models based on the same issue you're tackling now?
2011 E92 335is, Space Grey/Coral Red, 6MT.
RB 2+, Wedge tuned. E85 PI coming soon. |
05-08-2018, 09:00 PM | #12 | |
69
Rep 404
05-08-2018, 09:03 PM | #13 |
69
Rep 404
I'm REALLY digging the FancyWide diffuser, unfortunately, it is not as funtional and well, they don't make them from the 335, but I might take inspiration for the sides!
Made a bit of progress tonight, mocked up the side pieces, these will be one piece with two bends. Also test fitted the center piece to the car, seems like if I want it to stick out a bit I will have to fab another small piece to connect to the frame, its all part of the RnD process I guess. I will also have to unbend the piece a bit so it does not touch the mufflers, as this would probably be insanely noisy if left as is. Last edited by Evochuck; 05-09-2018 at 09:24 AM.. |
05-10-2018, 07:39 AM | #15 |
772
Rep 1,419
Wow, pretty cool project.
2011 335is DCT BQ Tuning / BMS CAI / VRSF kittyless DP's / Synapse BOV and charge pipe / 7" VRSF Race FMIC / Walbro 535 and 450 on BMP4 / E90 tune / Diff Brace / PR Coils / Relocation Inlets / DAW Stage3+ Turbos / MMP port injection / xHP Stage 3 / FPR and -6 fuel lines
07-31-2018, 02:08 PM | #16 |
69
Rep 404
Here is the mostly completed product, I might add slats between the fins under the muffler tips but ill run like that for a while.
Drifter2090909.50 |
