Front wheel bearing sound?
05-07-2018, 09:47 PM | #1 |
108
Rep 473
Can somebody tell me if my front wheel bearings are shot? Have vibrations in my car at all speeds crusing along the road. Here is the video of both sides left and right. The left side has sort of a slight whining sound.
05-08-2018, 07:38 AM | #2 |
Art Collector
2425
Rep 3,448
It’s hard to tell for sure, but the noise from your left wheel sounds like the brake pad just skimming the surface of the caliper...
If you spin the wheel while grabbing a control arm or something else attached to the hub, can you feel a vibration that coincides with the wheel’s rotation? |
05-08-2018, 11:40 AM | #3 |
718
Rep 1,753
Generally a wheel bearing failure will not cause vibration. If a wheel bearing fail is so bad that it causes vibration you can check that by grabbing the tire at 12-6 position and tug it should have no play. Same with 9-3 position. If it has play bearing is shot but it still should not cause vibration.
Your interior vibration is most likely control arms. Thats if you feel vibration when car is in neutral too. Otherwise could be drive train related. |
05-08-2018, 12:10 PM | #4 | |
263
Rep 1,225
2010 BMW 335i: Monaco blue metallic/Premium+Sport Auto-Steptronic, BMW PE, Cobb Stage 2
2005 Mustang GT: Redfire metallic/5-spd/Ford Racing (Axle backs, silver Bullitt wheels)/K&N CAI/ Diablo Sport Predator Tuner 1997 Toyota Corolla 1983 Mercedes Benz 380SL Roadster |
05-08-2018, 12:47 PM | #5 | |
108
Rep 473
A wheel bearing doesnt cause vibrations? Not sure why they wouldn't. Also the wheel bearing sometimes won't have play all the time if it's bad. |
05-08-2018, 12:57 PM | #6 |
718
Rep 1,753
05-08-2018, 06:49 PM | #7 |
108
Rep 473
05-08-2018, 06:51 PM | #8 | |
108
Rep 473
