Brake Pedal Soft - Master Cylinder Replacement?
05-07-2018, 07:54 PM | #1 |
Member
15
Rep 78
Hello All, having an issue with a softer brake pedal. It has been like that for a while now. Once the car starts with your foot on the brake, the pedal sinks a couple of inches and is soft. Driving the car, the brakes work fine, they stop well and if you hit them hard the car stops really quick but all with an inch or two of travel before the brakes engage. I want to get a firm pedal back though.
I have bleed the brakes twice now and still have the squishy feel. There are no visible leaks so I am coming to the conclusion that it must be the master cylinder. Is there any DIY for the correct process to replace the master cylinder. I have been searching the forms and cannot seem to find one. Any ideas? Thanks. |
11-20-2018, 06:45 AM | #4 |
4542
Rep 11,903
usually just air in the brake lines
I had to bleed mine about 6 or 7 times on one fluid change There is a DIY on how to do the fluid change and use the ABS to prime the lines Good luck |
11-20-2018, 10:10 AM | #6 | |
705
Rep 2,605
Drives: 06 330i E90, 18 530xe G30
https://www.e90post.com/forums/showthread.php?t=1421826 I also posted a video of what I was experiencing which sounds exactly what you have. As I said a whole new master cylinder didn't fix this. |
