335i 2009 front splitter removal
05-06-2018, 07:46 PM | #1 |
Rep 3
Hi,
Does anyone know how the OEM front splitters are attached? I have a very damaged splitter that I would like to remove but do not want to damage the bumper. Hoping heat gun or some product can be used to break down the glue (assuming they are glued). Splitter came on the car as part of M Sport kit. Thanks in advance. Daniel |
05-07-2018, 12:28 AM | #2 | |
4542
Rep 11,903
05-09-2018, 06:29 AM | #4 |
4542
Rep 11,903
I see what you mean
That is a mess I'm guessing these are glued or double sided taped in place Not sure how you can get them off without damaging the paint underneath Buy a replacement set before removing the old ones At least you can hide any damage under the new splitters Otherwise a great excuse to upgrade to M3 rep or M1 front end |
05-09-2018, 07:25 AM | #5 |
97
Rep 361
Use a heat gun but be very careful not to apply to much heat
05-09-2018, 07:32 AM | #6 |
730
Rep 1,815
If they were installed by BMW they most likely used Betalink.... Not easy to remove but having your splitters already damaged makes it easier for you. Be gentle, use a plastic scraper and some heat to soften it a bit prior to trying to remove it. Take your time or you will pull the paint from the bumper.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
05-09-2018, 04:43 PM | #7 |
Rep 3
Thanks for the advice guys. I'll get the heat gun out this weekend and go softly softly
Like you say, they already wasted so it can't get much worse. Cheers, Daniel |
05-09-2018, 11:56 PM | #8 |
730
Rep 1,815
I agree, you may want to remove them piece by piece.
05-10-2018, 12:20 AM | #9 |
392
Rep 2,367
Drives: 2011 335i
I envy one that has pdc in front msport bumper
05-10-2018, 01:23 AM | #10 |
730
Rep 1,815
05-10-2018, 12:47 PM | #11 |
392
Rep 2,367
Drives: 2011 335i
Ehh too much work. I will prolly rarely use it
Tags |
335i, body kit, splitter |
