BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > How do I get this downpipe out????
      05-06-2018, 06:47 PM   #1
000ooo000
17
Drives: 2011 e92 335xi
I have a an e92 n55 xdrive 335 and Im trying to get the stock downpipe out to replace with with a vrsf one. I got it to the point where the downpipe is moving around freely (v band off, all exhaust bolt nuts off, bolts to the thing that holds it to the transmission off, and o2 sensors unplugged from the top).
It keeps hitting on the midpipe, so I unscrewed everything connecting the exhaust in order to push it back a couple inches. That helped a little but the dp is still getting caught on the midpipe. I also tried to drop the subframe for more room but one bolt on the passenger side would not come out no matter what I do (torch, pb blaster, impact wrench multiple times). Maybe I need a giant breaker bar or something?
How else can I get this thing out? Do I need to take the o2 sensors off first? They were pretty stuck on there. Or do I need to remove the whole exhaust so it's not in the way? Do I need to try harder to drop the subframe (although I read a couple people did it without dropping it)? Any other ideas
Thanks!
      05-06-2018, 08:36 PM   #2
tbmd
Drives: 2013 335i M-Sport E92/N55
Thanks!
I have an e92 n55 RWD. This video helped me a lot when I installed mine...
2013 N55 E92 / 5" Stepped FMIC, Catless DP, and Chargepipe
      05-06-2018, 09:22 PM   #3
000ooo000
17
Thanks for that, the only thing I didn't do from that video is take off the bracket on the transmission, just unscrewed it from the downpipe maybe that will help. But it looks so much easier there, no subframe in the way and just slides right out
      05-06-2018, 09:47 PM   #4
weehe126
1161
Drives: 2017 340i
Pretty sure you have to drop the subframe for XI.
      05-06-2018, 10:07 PM   #5
000ooo000
17
I read where a couple people that did it on n55 without dropping it (somehow), I know n54 you absolutely have to drop it. How do you get a stuck subframe bolt out when using pb blaster and heating it up multiple times and using an impact wrench doesn't work?
      05-06-2018, 11:31 PM   #6
weehe126
1161
Drives: 2017 340i
Heat it up even more/continually soak in PB blaster over night.
      05-07-2018, 04:47 PM   #7
000ooo000
17
It soaked in PB blaster for almost 24 hours, then I took a propane torch to it for a couple minutes and it still won't budge. The only other thing I can think of is to use an acetylene torch or a very long breaker bar (neither of which I happen to have).
Edit: a couple more minutes with the propane torch followed by some water and it's finally out thank jesus
      05-07-2018, 08:19 PM   #8
Rotorocious
Rotorocious's Avatar
103
Drives: 335xi
Been dreading this on my xi. Are you doing it in a garage on ramps or stands?
      05-07-2018, 09:02 PM   #9
000ooo000
17
Doing it on stands. The worst part of it is getting the stupid rusty bolts out of everything. Everything else is easy compared to that. You'll want an impact wrench, some pb blaster and a torch (and then cool it off with water after heating like 10 different times). Also for the bolts that connect to the midpipe they were so rusted that I had to use some special rusty bolt socket extractor things and hammer a size smaller on it after they sat with pb blaster overnight.
You can get the v flange thing from the wheel well area no problem. And get an engine support bar from harbor freight, six bolts and 4 motor mount bolts off to drop the sub frame completely and some finagling and it finally comes out. It's pretty easy to drop as long as one of your bolts isn't destroyed like mine.
Also where do I get new subframe bolts? I can't find the right ones.
